Question about Sony SLV-D300P DVD Player/VCR
When I put a tape in, it loads, then stops.
When i put a tape in it starts to play, then it stops. It wont rewind, or ff. When i eject, it eats the tape. I have two of these units, the other one overheats. check out my profile.
  • mybradley7
    mybradley7 Jul 15, 2010
    Thank you so much! this helped! please check out my other problem for this vcr
    President:
  • 1,653 Answers
It sounds like the machine needs a thoro cleaning especially around the guide pins and tape head. Also make sure that the tape is not being excessively tensioned in the cassette housing. If it happens on more than 1 tape then thoro cleaning of the transport mechanism in the machine is required. You may need to run a cleaning cycle more than once or get it to a repair shop to do it for you. If it happens on all tapes then it is possible that one of the guides has become worn or bent, or the drive mechanism is at fault or the drive belt has become stretched and will need replacing.
Posted on Jul 15, 2010
Testimonial: "Thank you so much! "
Harmon kardon dc520
Dual cassette deck are often poorly built and full of problem with age. They are typically not worth repair. Get a good deck like the Tascam 122 Mk II as these can be repairs.
I have consulted with clients that have dual decks and the cost to repair will get you a Tascam 122 Mk II in restored condition and it works much much better. I should know as I have been repairing decks for 40 years so far.
Sep 20, 2016 | Audio Players & Recorders
VHS tape is running at high speed when insert it to VCR. no playback..buttons doesnot work.
Check if the fast forward button is more inside than the rest of the buttons. May be its stuck in the ff position. After all they were just micro switches below the plastic buttons strip. The specific ff micro switch may be stuck, if I were you I would try some switch cleaning spray to loosen it. But be prepared that the control ic is busted.
Jun 21, 2014 | Panasonic Televison & Video
Close when play vcr
Problem in the mechanism that moves the tape in play,ff,rewind and also winds tape back into cassette and ejects it.
Likely a bad or worn belt or drive idler(rubber).
Nov 04, 2012 | Televison & Video
I've a Mitsubishi HS-U770 that has not been used for several years. When I tried to use it today, the tape loaded but would not play, rewind, or fast forward (I hear what sounds like gears slipping). The...
Mine did that, and when I opened it I found that a small drive belt (visible from the bottom with the cover removed) had deteriorated into goo. This unit had been in storage a while and the rubber just deteriorated, I guess. The trouble is that now I cant tell what size it is, or what length. I think this belt drives the mechanism that loads the tape in and out, and the rest of the mechanism is triggered by the tape cassette moving into position. Since it cant get loaded properly, the rest of the machine doesnt work right, either.
Jan 17, 2011 | Mitsubishi HS-U770 S-VHS VCR
Tape won't play, FF, or eject.
sorry to say that none.no trip button for that.i assumed that the magnetic strip of the tape is already wind up inside.you'll need to open the unit up and gently rotate the flywheel of the tape player until you can open the door of the tape compartment.no need to force or it will just break.
Jun 22, 2009 | Sony EVC100 Hi8 VCR
Sharp VCR Model VC-685U
Actually the problem is in the capstan drive. If you replace or clean the idler, the problem will likely disappear....accordianman
Feb 15, 2008 | Televison & Video
Vcr eating and/or ejects tape
Tape heads should be cleaned first and gears lubricated. This job can be done at home if you purchase lithium grease and are very careful not to get it on the heads or spools. Greasing should only be done if you are confident in opening it up. Otherwise, seek a cheap professional.
Oct 26, 2007 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Camcorder has problems
I've had mine for about 3 years and just last year it started giving me playback problems....the screen would have blue stripes across it and sound won't play. I could usually fix it by rewinding and playing again...but it's not correcting itself right now... I hope I didn't waste 60000 yen on this c_c;
Oct 07, 2007 | Video Cameras
VCR eats tape when rewinding
A couple of possibilities: 1. Braking problems: When VCR goes from FFWD, REW, Play to stop, there are a pair of "brake pads" engaged to stop the reels, and prevent tape spillage out into the machine. These pads, often rubber like, are on levers which contact one side of each reel. If you take the cover off the VCR, and look down where the tape is loaded, you will like see these brake assemblies. If the rubber pad is missing, or lever pivot points gummied up, then this is your issue. 2. Take up reel isn't being engaged to take up the tape on tape eject. When a tape is loaded into the machine, tape is pulled from the cartridge and threaded into play ready position. When eject mode is engaged, the tape must be pulled back into the cartridge, or you will have tape hanging out the front end of the cartridge, and may get caught on the VCR internals, or at least be mangled by the cartridge door. The often issue here is likely the idler assembly pivot point is sticky. This idler pivots, moving from the take-up reel (right reel) to the supply reel reel (left one), depending on what mode is selected. FFWD & play to the right, left for REW. If this idler is gummed up at it's pivot point, movement will be sluggish at best, and might not be engaging the right reel quickly enough to pull tape in before tape eject. This idler is sitting right between the reels down where the tape sits. A little light oil on the pivot point may be enough to loosen it up. Otherwise it might need to be removed and the old grease removed, and a drop or two of light oil applied.
Jul 09, 2007 | Mitsubishi HS-U781 S-VHS VCR
Eats tapes
When a VCR eats a tape, it can be cause by a couple things.
1. There is a rubber wheel called a "pincher wheel" that compresses the tape against the "capstan". The capstan is a shiny metal spindle connected to a motor. The pincher wheel can become worn and/or dirty (slick) from the oxide coating off of the tape. You can try cleaning the pincher wheel and capstan with alcohol or try using a re-grip solution on the pincher wheel. Last thing to do is replace the pincher wheel. Look to see that the pincher wheel is doing its job by pulling the tape through. The pincher wheel & capstan are not used during a fast forward or fast rewind, so if your tape is getting caught during the FF or RW and not Play, it's probably not related to capstan & pincher wheel.
2. There is a small tire wheel called an idler tire. This tire pivots between the sending and pickup reels of the player. Its also used during fast forward & rewind as well as play. If the tire is worn, the tape won't be wound up as fast on the take-up reel as the sending reel during play. This means more tape is coming out of the cassette than can be wound up on the takeup reel. You can try using a re-grip solution on the idler tire or replace it.
3. You didn't say if the unit played ok. There's also a brake pad that is designed to grab and stop the tape wheels from spinning when you hit stop. If those pads are worn, the wheels will not stop fast enough and the tape will continue to feed (spool) out of the cassette and not be taken up by the other wheel.
So when when you hit eject, the excess tape that should have been wound up tight in the cassette before the eject sequence, is getting caught inside the player.
Let me know if I can be of further assistance to you.
- Jim
Feb 20, 2007 | Symphonic WF803 DVD Player/VCR
Sony SLV-D300P DVD Player/VCR Logo
214 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
