Question about Zenith DBZN-311 Remote Control
I have philips universal remote---won-t turn tv on will not change channel
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 242 Answers
I have the same remote. anyway, reprogram it.
Posted on Jul 15, 2010
I have a Philips tv model 42FD9954/69c but it doesn't have a remote so I cant turn it on how do you get it to work with a universal remote ?!
Most TVs have controls on the side of the TV to operate power, volume and channels, if the power button puts it to standby then use the Chanel up or down to turn it on! Depending on the universal remote being used just select the code relevant to the make of TV you are connecting to!
Nov 01, 2014 | Televison & Video
Need code to program philips universal remote
most philips universal remotes have the "code search" option this is done by:
1: Manually turn on ur tv
2:hold setup untill red indicator stays on and release button
3: press and quickly release what you wanna program (i.e tv,vcr,ect.)
4:press channel up repeatedly untill your t.v changes channels(up to 300 times) if you over shoot the channel change press down til it changes again.
5: press and release MUTE to install the code.
Jun 17, 2009 | RCA Universal Remote Control
I have a philips universal remote and an Rca Tv how can I program
code list is also listed
Great News!! We can program most Philips Universal Remotes with Automatic Code Searh. Here's how it works on most of our remotes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
The above assumes that you want to store the VCR you want under the VCR but, Cable codes under the CBL, etc
Note: if the device does not have a chat channel at a button, you should Play (VCR only) or Power instead.
Here is a Code List on PDF that shoud be universal for most remotes. It worked for me.
http://www.remotecodelist.com/remot...ps-Magnavox_PM525S.pdf
Hope this helps you out, good luck.
Nov 28, 2008 | Philips Magnavox Learning Universal Remote
Philips universal tv remote not working
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
Thisis the user's manual for a Phillips remote control. There is a list ofcodes in it. They should be rather universal. There's also instructionsas to how to program it. I believe that there is a way to program itwithout using the codes.
4.Press the Channel Up button repeatedly (up to 300 times) until thedevice could be controlled changes channel. The red indicator blinks,then stays lit. If you accidentally overshoot the code required, pressthe Channel Down button to backtrack through the library until thedevice changes channel. Pressing Channel Up changes direction toforward again. Press and release the Mute button to install the code.
Hope this helps :)
Jul 29, 2008 | Philips Televison & Video
Need codes for a philips universal remote code sheet
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Hope this helps :)
Jun 21, 2008 | Philips Magnavox Learning Universal Remote
Remote codes for philips universal
Hope this helps :)
May 14, 2008 | Philips Universal PH301S Remote Control
Remotes codes
Hope this helps :)
May 11, 2008 | Philips Universal PH301S Remote Control
Philips universal codes
If you dont have the codes for a philips universal remote you have to press code search and TV at the same time till the led light stays on. Then press the power button a few times untill the power turns your TV off, then press the OK button. After that the code should be in the remote.
Dec 07, 2007 | Philips Magnavox Learning Universal Remote
Zenith DBZN-311 Remote Control Logo
123 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
