Question about LG GSA-H42N 18x DVD RW DL IDE Drive (Black) Burner
My dvd drive isn't working properly.it doesn't read/write any dvd/cd. after check it up the magnet/motor structure can't rotating. Am tired.... what can i do? is there any solution for this ? reply please.....
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 45 Answers
Hi, have you tried uninstalling and reinstalling the software.
if not try that first, then check all connections, failing that I think your drive has had it.
Posted on Dec 09, 2013
  • 624 Answers
SOURCE: Reads all but DVD-Help PLEASE
When you say it won?t read are you trying to play commercial DVD movies or read DVD data disks? If you're trying to play movies then you need a couple of things the first being some type of player program. Real player works as does Windows media player but usually DVD drives come with a striped down version of PowerDVD or WinDVD. If you in fact have a player installed and when a DVD is inserted in your drive it doesn't play it may not be configured to automatically play DVDs. Try opening your player program and trying to manually play your DVD. Let us know if you have any success or if you need more assisted. If you do let us know what player program and operating system you have and any error messages that may appear.
Posted on Jan 01, 2007
JoAT
  • 121 Answers
SOURCE: my dvd combo does not read dvd
There are separate lasers for CD reading, and for DVD reading. This is why it is possible to have a drive that reads only CDs but not DVDs, or the other way around. And your particular combo unit seems to have a lot of these problems. Since the drive doesn't work it's almost definitely a problem with the drive itself (I'm assuming that there is nothing wrong with the discs you tried to read). If that drive is still covered by a warranty period, send it back for repairs. Otherwise, I can't see the harm in trying to tinker with it yourself as the DVD portion of it is dead anyways. Ummm, on a side note...CompUSA is going out of business and they are selling things cheap. I got a DVD lightscribe burner for $40...booyah!
Posted on Mar 26, 2007
SOURCE: Combo drive not reading DVD
i am using alcohol 120% or isobuster to force the dvd rom to read the cd or DVD to read. and it fine
but i still cant get the dvd rom to work fine without any software to force it.
Posted on Jul 14, 2008
SOURCE: cd reading problem
The answer on the LG-site (mailcontact): Go to your dealer.
I think that a new one is cheaper than repairing my combodrive ( 2 yrs old).
P.S. : I'am the guest posted on nov 04
Posted on Nov 07, 2008
richin29
  • 29 Answers
SOURCE: LG DVD RW drive not detecting DVD/CD
Start the Run Command Prompt
Type in "regedit" without the parrenthesis then click ok
Go to HKEY_LOCAL_MACHINE
Then SYSTEM
Then CURRENT CONTROL SET
Then CONTROL
Then CLASS
Then find {4D36E965-E325-11CE-BFC1-08002BE10318}
The whole thing looks like this:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Then delete the upper and lower filters.... (if lower filter is not there then leave it)
RESTART YOUR COMPUTER THEN THERE YA GO!!!! HOPE THIS HELPS
Posted on Feb 06, 2009
Dvd reading error
Try using a known-good (for instance, a movie you just watched on your TV). If it doesn't read that disc, make certain you have seated the disk in the drive properly (Laptop drives have a *CLICK!* when you have seated the disc properly). If that doesn't work- if the laptop is in warranty, get it fixed. If not, use an external drive to fulfill your media needs
Sep 22, 2012 | HP Pavilion dv6775us Notebook
How can I get my dvd to copy videos when it reads, No Disk? when there's a disk in the player?
hi, possible problem with the dvd, the lens doesn't read the disc or the spindle motor not rotating that is why can not read a disc. try to clean first with a cd lens cleaner, just insert a cleaner to the player to remove dirt and might the lens get sticky. now if still doesn't work, you will need to remove the cover of the player to access the internal part. check for broken part or any obstacle that can block the rotation of the spindle motor.if the motor doesn't rotate anymore you can check the resistance if still there using an analog tester. if no resistance at the pin terminal of the motor, the coil was worn out then you will need to replace the motor.
Jun 08, 2012 | Compaq Computers & Internet
Cannot read any DVD/CD
hi welcome to fixya
here is my solution for that problem, first lets verify to narrow down where the main cause it could be. lets use first a dvd cleaner, dust can cause the optic lens not to read. then insert a dvd observe the light indicator ( yellow ) if blinking which mean the optic lens is starting to read the disc, if not it doesn't read. so at this time you are going to remove the cover with your dvd drive just to know and access the mechanism as will as the optic lens. now turn the power on and insert the dvd look for the optic lens if emits red light then moved going up to read the disc which mean the optic lens has supply. then check the spindle motor if rotates normally if not check the motor replace if defective. one way on how will you check the motor if defective through using a analog tester, check the resistance on the positive and negative terminal of the motor if the resistance is almost 0 ohm or shorted which mean it was worn out need to replace. hope this will help thanks for consulting through fixya.
Sep 11, 2011 | Computers & Internet
I HAVE A PRODUCT KEY AND WANT TO DOWNLOAD IT TO THIS COMPUTER BUT THE DISC ISN'T WORKING
you need to do a lot of test, 1. check in bios if your cd-drive or dvd- drive is in enable if not enable it. 2. if your cd drive was enable, try to insert another cd, if the cd you insert was read by cd- drive, the problem is your cd. then if the other cd you insert is also din't work the problem is the cd-drive or dvd- drive. :P
Aug 25, 2011 | Microsoft Office Professional 2007 Full...
My dvd writer\drive isn't reading any disc can any 1 try to tell me what should i do?????
Make sure you have an updated driver then restart your computer. If that doesn't work, comment back.
Jul 17, 2011 | LG GH22NS50 22X DVDRW SATA Drive OEM...
Cd rom does not work. It doesn't read anything, cd, dvd, blanck optical discs1
Check the driver in device manager. You would be looking for any icons with an X or a ? next to them. The driver probably isn't the issue, so I would search for the model number of your laptop plus "cd drive" on ebay. These are pretty cheap and are easily replaced. If that doesn't fixya, then there's possibly something wrong with the motherboard.
May 09, 2011 | Toshiba Satellite M45-S169 Notebook
CD player will not work
Try a different CD. iIf the computer doesn't recognize it at all, listen for the drive to spin and look for a blinking light on the CD tray. These signs do not necessarily mean the CD drive isn't broken. I would find the model number of your laptop and do a search on eBay for a replacement CD drive. These are very easy to switch out. If the new one works, then you're set. If it doesn't work, there may be an issue with your motherboard.
May 07, 2011 | Toshiba Satellite Pro L300 Notebook
Dvd drive wont open , can hear motor working but drive wont come out. we believe the cd holder isnt shifting up/down to allow the drive to activate & open
Turn the computer off,Remove power cable.Use a peper clip insert it through a hole infront of the dvd drive this will eject the door.Make sure once this is opened the tray is aligned properly,slide it in and out.Push it in all the way then power up the computer.This may work for a while,before it goes again,so you might have to replace it.
Good Luck
Jan 17, 2010 | Lite On SHM-165P6S DVD RW Dual Layer...
Cd/dvd drive on my Dell latitude D810 will not read
Try to clean the laser within the dvd drive with a soft material. If this doesn`t work, try to hear if the cd or dvd is rotating in the drive. If not, the drive should be repaired b specialists.
Jul 29, 2009 | Computers & Internet
Hp dvd/rw does not read discs
If the CD or DVD disks you inserted work in some other reader, then your reader is the problem -- even though it is properly connected to your computer, and Windows has the correct device-drivers, it is the "hardware" that is the problem.
When you insert a disk, rotate it to some position, i.e., top-lettering goes in first, and close the drawer. Do you hear the drive start to spin the disk? Open the drawer. Is the disk in the same (non-rotated) position? If so, then the motor that spins the disk is the problem. If the disk does spin, but nothing happens, then it is the "laser" part of the mechanics that is not working.
Replace it.
Apr 21, 2009 | LG GSA-H55N DVD-RAM Burner
LG GSA-H42N 18x DVD RW DL IDE Drive (Black) Burner Logo
103 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
