Question about Yamaha P4500 Power Amplifier 2-Channel
Kindly ineed circuit diagram for p4500 - Yamaha P4500 Power Amplifier 2-Channel
Why wont my cluster lighting on my 1998 cadillac eldorado work how do i fix ineed a wireing diagram
You will find wiring diagrams in both Haynes and Chilton books available in auto parts stores and maybe your local library.
Oct 25, 2014 | 1998 Cadillac Eldorado
YAMAHA p4500 daigrem
This is a service manual of your device and it can be downloaded for free and I hope it is suitable for you (included schematic diagram). Go to this web site:
http://elektrotanya.com/yamaha_p4500.pdf/download.html
When you use the link you get to a page where you have to wait some minutes to be possible the downloading so please be patient.
Thanks.
gylacz
Aug 19, 2011 | Yamaha P4500 Power Amplifier 2-Channel
Shashij_2001@yahoo.com
TURN THE BALANCE CONTROL IN THE MIDLE
Jul 06, 2010 | Yamaha P4500 Power Amplifier 2-Channel
One channel does not receive signal as shown by the led.oudtput stage is perfect the amp is a Yamaha P4500 poer amp
Try reverse connecting the channels, in order to locate where is the problem; at the cables or at the amplifier.
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
Mar 06, 2010 | Yamaha P4500 Power Amplifier 2-Channel
P4500 yamaha amp
first check your input cable-disconnect it and check if the problem finished---you will have a problem in input(cable or device)-start with another cable then your input device.
if the problem still check your out put cables(speakers cables)for short circuit or touch the bare wire with amplifier body.-try to clean volume controls with spray contact cleaner---confirm good connection in amplifier rear and in speakers rear.
Aug 25, 2008 | Yamaha P4500 Power Amplifier 2-Channel
Yamaha P4500 Power Amplifier 2-Channel Logo
318 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
