Question about Jobo Giga One 40GB Portable Storage MP3 Player
Err keeps appearng on screen next to the HDD icon
Hhd security lock reset password
Download the HDD Unlock Wizard diagnostic tool free from the link on the HDD Unlock page. The program allows you to test the program to see if it can recognize your hard disk before you attempt to unlock your drive. Double-click the icon in the "Downloads" folder and click "Run" to launch the program setup, then follow the HDD Unlock Wizard Setup Wizard to install.
Open the Unlock Wizard and click "Next" to get to the drive selection screen. The program automatically displays any drive that it can recognize in the "Drive selection" window and its status.
Select the name of the hard drive from the "Drive selection" window. Click "Next" to move into the status screen of the Wizard, then "Next" again to move to the unlock screen.
Go to the HDD Unlock page and purchase a virtual unlock card code for the program. The code will be emailed the email address you provide on the website. You must have an unlock code in order to complete the unlocking process with the HDD Unlock Wizard.
Enter your code into the provided box in the HDD Unlock Wizard. Once the code is entered, the Wizard will unlock the hard disk by erasing the data and re-certifying the drive, restoring it to its original factory settings.
Shut down the computer and boot it back up after the Unlock Wizard is finished the unlocking process. The computer hard disk should be unlocked and restored to factory settings.
1. Repair Station
Download the Repair Station diagnostic tool from HDD Tools and install it on your computer. Unlike HDD Unlock Wizard, Repair Station attempts to unlock the hard disk without erasing the information on the drive.
Register with your name and email address and create a login and password on the HDD Tools page. You must have a login and password to use the Repair Station tool.
Open Repair Station on your computer and go through the program screens to run the diagnostic test on your hard drive. If the hard disk appears in the list of available drives, Repair Station can unlock it.
Buy a Repair Station license code. The code will be emailed to the email address you provide. Enter the code into the provided box in the Repair Station application. Repair Station will attempt to unlock only the firmware area of the hard disk, without affecting the other information stored on the disk.
Restart the computer when Repair station is finished working. The hard disk should be unlocked without any effect on the rest of the system
Jul 15, 2012 | Gateway NV53A52u
It all started trying to upgrade from xp to vista it was all going smothly until itgot to the point formating hdd then it suddnely stops saying err cant read disk in optical drive !so i try to instal the...
hd password seem to be wrong, double check and try to copied them as display.
if they are lower letter or upper letter, copied them as you see it ..
Feb 14, 2011 | Computers & Internet
My unit keeps chirping every 30 seconds even after replacing the batteries. The unit is over 5 years old.
The manufacturer has written this in their manual for your unit...
"Err" displayed -battery icon may show any state of battery capacity. One quick beep every 30 seconds. Unit is Error condition
Replace batteries. If "Err" (or blank display) continues, unit has malfunctioned. Replace immediately.
Link to manual...
http://portalgb.knowledgebase.net/utility/downloadArticle.aspx?aid=294720
Feb 03, 2011 | Kidde Nighthawk 9000089 Carbon Monoxide...
Error is coming E000002
Error E000002
Press the the " additional functions" button, then the numbers 2 and 8 simaltaneously,and then the additional functions button.
This will bring a new screen with several icons. Press "Coppier".
This will bring several more icons to view. At the top of the screen press "Function" and then "Clear" at this point a new icon will display "ERR". Press it and then "OK"
This should make the coppier recover from its critical error.
Disconnect the machine from the power source for 30 Seconds and power it up. If the reeor returns it will within 5 Minutes or so. If it doesn't, it is now OK, until the next time that is.
Hope this helps.
Nov 11, 2010 | Computers & Internet
"no valid device!" message
Did you connect your HDD correctly?
If so have a look at the back of your HDD, next to the IDE port you will find a small jumper, make sure that jumper is set to master.
Enter your Bios and check that your boot priority is set to boot from the HDD first.
Also make sure that your IDE cables are firmly connected on the motherboard as well as the HDD.
Keep me posted
Aug 16, 2009 | Computers & Internet
Pioneer HDD DVR DVR630H - in Australia
When fitting a replacement hdd the hdd must be paired with the DVR using the Service Remote Controller used only at Pioneer Service Centres.
Mar 17, 2017 | Pioneer DVR630H DVD Recorder
Panasonic says no HDD ERR
Is your HDD full? I've never had this error before, but then I've never filled my HDD either, so is this a possibility?
Oct 17, 2008 | Panasonic DMR-EH57 HDD Recorder Player
Panasonic dmr ex75
HDD ERR is quite a serious error, as it means there is a hardware problem with the internal disk drive. You could try switching off the unit and disconnecting the mains cable overnight, and trying again, but really this will need to be a call to an engineer.
If your unit is still in warranty call them now to arrange a fix. To find your local warranty centre, go to your regional Panasonic website, and look under Customer Support
Nov 21, 2007 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
Blank screen
right mouse click on the desktop now show the desktop icons? was this ok?
Sep 18, 2007 | Dell Inspiron 6000 Notebook
Open Questions:
See all Jobo Giga One 40GB Portable Storage MP3 Player Questions
Jobo Giga One 40GB Portable Storage MP3 Player Logo
100 people viewed this question
Top Jobo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Jobo Audio Player and Recorder Expert? Answer questions, earn points and help others
