Question about IBM Computers & Internet
Whene i want to open my computer then i see this.............post startup errors,the following errors were detected when the system was strated. 206 memory failed configuration. now what can i do. ibm hard disk n mother board,i used windoss xp plz help me
  • rahimabdur78 Jul 16, 2010
    walesarumi
    Rank: Wiz Expert
    Rating: 83.07% , 595 votes
    open up the system, remove the memory chip, clean it and clean the memory slot on the motherboard. Also, remove and fix back the hard disk, makes sure all the motherboard components are well fixed and your computer should pick up again.
    This is a minor problem, I'm sure.
    Take care.
    Jul 15, 2010 - i try to solbe by ur suggetion .........open up the system, remove the memory chip, clean it and clean the memory slot on the motherboard. Also, remove and fix back the hard disk, makes sure all the motherboard components are well fixed and your computer should pick up again.
    but now see that.........1962 no operating system found press f1 to repeat boot sequence, now what can i do step by step tell me.Jul 15, 2010 - Hello,
    if your system tell you that "operating system not found", it means your hard disk is not being recognized, as such the system will not boot.
    So, open the system again, and re-fix the hard disk, make sure the IDE cable s well fixed. or, you can change the position for the hard disk with that of the CD ROM.
    After that, is if the system still does not boot, press f1 as directed by the system, the system will then enter bios setup, go to boot order or boot sequence, you will see the list of your computer components. Makes sure the hard disk comes first before the CD ROM. This will enable the system boot from the hard disk.
    Good luck.i try to solbe the problem, but its not work. so now i want to resetup xp but i dont found the boot from cd i found boot from network. so what can i do now. how i open my computer give me good solution.thank
  • IBM Master
  • 4,737 Answers
It's not a very serious, if you are lucky, only cleaning the Ram will fix this problem. This is a common problem with Ibm Machine when the Ram is bad or when the Ram is not seated correctly.
Turn off the machine, Open the Case, Remove the Ram and clean it (interfaces) with Eraser (Rubber) and Re-seat it. If the problem persists, you need to replace a New or another working Ram. That'll definitely fix your problem.
Laptop Ram
If there are multiple Rams, install one while removing the other and vice versa, it's also possible, that only one of the Ram is functioning incorrectly.
Please let me know if the problem persists.
Good luck.
Thanks for using FixYa.
Posted on Jul 16, 2010
  • 6,993 Answers
Take care.
Posted on Jul 15, 2010
  • rahimabdur78 Jul 15, 2010
  • Walesarumi
    Walesarumi Jul 15, 2010
    Good luck.
Windows error recovery message at startup, tried one key recovery takes me strate to enter my password,i dont have one
Hello, If you don't have your password then you will have to remove your motherboard's cmos clock battery for a few seconds and replace it back. This disables your password..
How to remove a laptop cmos battery.
laptop cmos battery
Hope this helps.
Jul 03, 2015 | Lenovo IdeaPad U550 (374955U) PC Notebook
Cannot detect camera
First, ensure that your camera is on. I know it sounds stupid, but I've forgotten that part before ;) If it's still not working, it could be your USB cable. Even if it's new, it could be faulty. If you have another one available try that. I'm not sure where you bought it but most places would require you to return the entire camera in order to get a new cable for it. I would probably talk to Canon about getting a new one or just buy a new cable.
Jun 12, 2008 | Canon PowerShot A520 Digital Camera
How can I recognize mother board problem if system gives trouble. Could you inform about troubleshooting tricks on motherboard
If the motherboard can detect an error, by itself, it should be in the post Power On Self Test.
If the board did not beep, it could not find an error.
Perhaps you should look in the startup menu, if the post is switched off. Sometimes people switch it of to safe time during startup, but it only takes little time for the computer to do the test.
Perhaps you do have a manual for the board (if you did build the computer yourself, then you can read all about post.
perhaps you copy and paste this line in Google and add the model name and number of your board. See what you can find.
Success
Sep 13, 2014 | Computers & Internet
Bootmgr missing on hp pavilion slimline s5503w
This document pertains to HP and Compaq desktop PCs that came with Windows 7.The following error opens when attempting to start the PC:BOOTMGR is missingPress CTRL+ALT+DEL to restart the PCIf you recently installed an additional hard drive, turn off the computer and remove the drive before using the following steps:
  1. Open HP System Recovery:caution.pngCAUTION:Do not perform a system recovery! Stop at the first recovery screen.
    • Press the F11 key repeatedly while the computer is starting.
    • If you have a recovery disc, turn on the PC and insert the first recovery disc into the drive. Use the disc to enter the system recovery.
  2. Select Microsoft Startup Repair tool and wait for repair to find and fix errors. When finished, restart the computer; even if the startup repair tool finds errors but cannot fix them.
  3. If the error message persists, open the recovery manager screen as was done in step 1.
  4. At the recovery manager screen, press ALT + D.
  5. Enter the following text at the command prompt: bootrec /rebuildbcd
  6. If bootrec displays "Add installation to boot list?", press y .After bootrec completes successfully, the computer displays "The operation completed successfully".
  7. To close the command prompt, enter the following text: exit
  8. At the Recovery Manager screen, select Microsoft Startup Repair tool (again) and wait for startup repair to find and fix errors. When finished, restart the computer.
  9. The error should no longer open. If it does, perform a system recovery, making sure to backup important files.
If you removed a hard drive before using these steps, replace the drive. If the error occurs again, make sure the additional hard drive is not set as an active drive. Only the main bootable drive should be set as active.
Feb 10, 2012 | HEWLETT-PACKARD Pavilion Slimline s5503w...
Computer restarts randomly
If you are using Windows (XP, Vista or 7) then open the Computer properties by clicking on the Computer icon (on desktop or start menu) then go to the Advanced page tab and check if you have the option to automatically restart the system set on in the Startup and Recovery Settings section. If this is on, then Windows will restart the system any time that a critical error is encountered.
The other place to check is in the Windows Event logs (system log) provided this option is enabled.
You should be able to access the event logs by right clicking on the Computer icon and then selecting the Manage option followed by opening the Event viewer where you should look for any critical, error or warning entries that may occur at the times when the computer restarts itself (or posted immediately when it restarts).
Jan 12, 2012 | Toshiba Computers & Internet
Im building a computer in school and the speaker that runs during POST connector but i have no ihad (nor my teacher) as to where it goes on my asus M68MT-S2P diagrams or pictures would help . thanks
Sir you posted a ASUS M68MT-S2P, there is no such model, the image above is a Gigabyte M68MT-S2P. all you have to do is plug your system speaker and follow the polarity.
The system reports system startup status by issuing a beep code. One single short beep will be heard if no problem is detected at system startup. If a problem is detected, the BIOS may issue beeps in different patterns to indicate the problem.
Hopefully this information helps.
Thank you for using FixYa.
Sep 20, 2011 | XION AXP 100 Gaming Series AXP100001BK...
When i am start my hp pavilion this shows Bootmgr is missing alt+cntr+del to restart again it same cycle
1. Error: BOOTMGR is missing:
??¢ If you recently installed an additional hard drive, turn off the computer and remove the drive before using the following steps:
??¢ Open HP System Recovery:
??¢ CAUTION: Do not perform a system recovery! Stop at the first recovery screen.
- Press the F11 key repeatedly while the computer is starting.
- If you have a recovery disc, turn on the PC and insert the first recovery disc into the drive. Use the disc to enter the system recovery.
??¢ Select Microsoft Startup Repair tool and wait for repair to find and fix errors. When finished, restart the computer; even if the startup repair tool finds errors but cannot fix them.
??¢ If the error message persists, open the recovery manager screen as was done in step 1.
??¢ At the recovery manager screen, press ALT + D.
??¢ Enter the following text at the command prompt: bootrec /rebuildbcd
??¢ If bootrec displays "Add installation to boot list?", press y .
??¢ After bootrec completes successfully, the computer displays "The operation completed successfully".
??¢ To close the command prompt, enter the following text: exit
??¢ At the Recovery Manager screen, select Microsoft Startup Repair tool (again) and wait for startup repair to find and fix errors. When finished, restart the computer.
??¢ The error should no longer open. If it does, perform a system recovery, making sure to backup important files.
??¢ If you removed a hard drive before using these steps, replace the drive. If the error occurs again, make sure the additional hard drive is not set as an active drive. Only the main bootable drive should be set as active.
Dec 12, 2010 | HP Pavilion Ze4900 Notebook
Vaio sat survey not working
The VAIO Sat Survey is an Application that loads at the Startup. If the Application in the Computer is corrupted, it will display an error message that the "VAIO Sat Survey has stopped working".
You can just remove the "VAIO Survey/VAIO Sat Survey" from the startup items to fix the error message.
Please follow the below steps to disable the Application from starting automatically and fix the error message.
  1. Open the run window by pressing the "Windows" and the "R" Keys.
  2. Then, in the run window, please type "msconfig".
  3. This will open the "System Configuration Utility" window.
  4. In the System Configuration Utility window, please click the "Startup" tab.
  5. In the startup tab, please scroll down to view the "VAIO Sar Survey/VAIO Survey.
  6. Then, please remove the check mark next to the above items.
  7. Then, please click the "Apply" and "OK" buttons.
  8. The Computer will prompt to restart.
  9. Please restart the Computer.
  10. The error message should not be there when you restart the Computer.
Jul 27, 2010 | Sony VAIO VGN-CS118E/P NoteBook
When I turn my computer on, I get a runtime error.
Clean Boot with Only MoSearch loadTOCNode(2, 'resolution'); The Mosearch.exe (Microsoft Office Search Service) and Mosdmn.exe (Microsoft Office 10 Search Filter Daemon) Startup items may be conflicting with some other program (or programs) running in the background. Therefore, clean boot your computer with only MoSearch selected on the Startup menu to determine whether this program is the source of the conflict. To do this, follow these steps:
  1. Click Start, and then click Run.
  2. In the Open box, type msconfig.exe, and then click OK.
  3. On the General tab, click Selective startup.
  4. On the Startup tab, click to clear all check boxes except for MoSearch.
    NOTE: In Microsoft Windows Millennium Edition (Me), leave the *StateMgr check box selected as well.
  5. Click OK, and then click Yes when you are prompted to restart the computer.
  6. If the error message can be reproduced, repeat the preceding steps. In step 3, also click to clear the Process System.ini file and Process Win.ini file check boxes.
If the error message cannot be reproduced, this indicates that MoSearch is conflicting with some other program or programs running in the background. Follow these steps to locate the conflicting program:
  3. On the Startup tab, click to select one of the check boxes.
  4. Click OK, and then click Yes when you are prompted to restart the computer.
  5. If the preceding steps reproduce the error message, the last item added to the Startup menu is causing the conflict. If the error message is not reproduced, repeat these steps until all Startup menu check boxes are selected.
  6. If all the Startup menu check boxes are selected and the error message is still not reproduced, start Msconfig again, and then click to select the Process System.ini file and Process Win.ini file check boxes.
If this doesn't fix it, let me know and I'll post another, more advanced repair.
Good luck, and please let me know how you do.
~ Spoem
Mar 24, 2009 | HP Computers & Internet
I keep getting an error message when I start up my laptop. the 2 wire gives me a "corruption has been detected in feature manager, backup file has been loaded", and it will not connect. All other programs...
If the machine is a Dell with DellControlPoint, open start, run then type msconfig and hit enter. Choose the Startup tab and find the startup item named "Dell" with the Command from "C:\Program Files\Dell\Dell Control Point\Connection Manager\Dell.UCM.exe" and uncheck the box. Hit Ok, then reboot your computer.
Jan 16, 2009 | Computers & Internet
Computers & Internet Logo
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
