Question about Kenmore 23822 Top Load Washer
I have a Kenmore Series 80 Washing machine that takes about 3 hours to fill up with water. The water just trickles in. Have checked to make sure the hose isn't stopped up. ANything else I can do?
  • Kenmore Master
  • 2,699 Answers
Probably have junk stuck in the water valve,most likely you'll need to change it out or see if you can take the screens out of the back of the valve and clean them,on some you can,let me know what you find,also i would take the water lines off,stick them in the washer and open the water valve to see what kind of pressure you have and to clean out the water pipes before i'd put a new valve on so that doesn't get plugged up
Posted on Jul 16, 2010
My Kenmore 80 series model 110 hot water continues to trickle in even after cycle is complete.
The fill valve is not shutting off completely. Sometimes it is necessary to turn off the water supply between wash sessions to prevent this but then you have to remember to turn the water back on the next time you plan to wash
Feb 10, 2013 | Kenmore 24032\24036 Top Load Washer
My kenmore 80 series washing machine makes a horrible noise and cold side fills about half speed when filling with water. What should I check?
For the slow water issue, you will need to replace the water inlet valve. Here is a link to the part.
Could you describe the noise and where it is coming from?
Oct 19, 2012 | Kenmore Washing Machines
Kenmore series 90 plus model # 4217018 water inlet valve
Hi, some users install those horrible quick-connect hose connectors to water pipes, they tend to cut a very small hole, that corrodes over. This will give the exact symptoms you are getting. Also, the flexible inlet hose, if it is kinked/collapsed internally, you can get this. To check this, turn the inlet supply valve OFF, unscrew the flexible inlet pipe from the back of the machine, and hold over a bucket, and turn on the valve. If is trickles, then it has to be either the flexible pipe, or the valve blocked (and NOT the parts inside your machine at all)! Hope This helps, Tony Davis, of LETSFIXIT.
Jul 12, 2012 | Washing Machines
Washer works fine until it starts filling on the rinse cycle, then the water just flows out of the drain. Last night the water was running for 3 hours, before I realized it. The tub fills fine when it is...
Make sure the drain hose is not sealed to the drain pipe, and that the hose is not shoved into the drain allowing the end of the hose to reach the trap. That will prevent the machine from syphoning out the rinse water as it fills.
Mar 29, 2011 | Washing Machines
Kenmore HD Series 80 - hot water trickles in.
Pull the two screws at the bottom corners of the control panel. Pivot the panel up. Lever the two metal keepers underneath forward and up to remove them. Tilt the housing forward and pull it toward you to remove it. Make sure you unhook the lid switch wiring plug before you remove the housing.
Water inlet valve should all be one piece for hot and cold.
Nov 15, 2009 | Kenmore 26882 Top Load Washer
Kenmore 90 Series Washer : cold water fills at just a trickle:
your hot water goes through the water heater so contaminates settle in the heater. the cold does not, there is a screen inside the fill valve where the hose hooks to the valve on the machine. if this in not plugged then the fill valve will have to be replaced. because of the build up of contaminates..
Jul 08, 2009 | Kenmore Washing Machines
Kenmore Washer 90 series cold water trickle
Hi, You need to remove the fill hose and see what is plugging the inlet valve screen. This should make a guge difference.
Please let me knwo ig I can assist you further.
Thanks
Vic
May 23, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series overflow
Ok, it sounds either your hose from the water level pressure switch has come off or broke, or the pressure switch itself is bad.
Check the pressure switch hose first.
My tubing came loose and I just duct taped it back on and it works perfectly.
You would need to open your console as shown here:
http://www.applianceblog.com/mainfor...ead.php?t=1081
Pull forward and up on the console and you can hinge it open and hanging from the hinges.
Here is your water level pressure switch:
00092478.jpgWater fill level switch
Here is the pressure switch hose:
00021892.jpgHose for water level pressure switch
Dave
Nov 04, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore washing machine 80 series
check for kinks in the pipe or restrictions to the flow in the pipes before it gets to the washer, if all is ok then check the filter on the outside of the water connector on the machine for dirt
if you confirm all is clear and the flow of water is not the problem before the machine, replace the cold water solenoid
Oct 14, 2007 | Washing Machines
Kenmore 23822 Top Load Washer Logo
35 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
