Question about Lexmark X4270 All-In-One InkJet Printer
I found the ink cartridge. I just need to know
I found the ink cartridge. I just need to know how to go about removing them
    Genius:
  • 1,087 Answers
Perhaps the Lexmark X4270 User's Guide will be able to assist you. To download, click on this link: http://bit.ly/cNbUKo . Go to Maintaining your All-in-One for the instructions on replacing the print cartridges. Hope this helps.
Posted on Jul 15, 2010
What does ink threshold exceeded mean?
Sad to say I know how to fix this.
1. Power up the printer
2. set printer's date to the current day.
3. On the keypad press the * and # keys together
Now press one at a time 1,2,3 for the code
"screen stould display a white backround with 2 lines of info"
4. remove all the print cartridges
5. Press the >> arrow button twice until "reset menu" is found
6. Press OK
7. Select Partially full reset Press ok
( the printer will take almost to minutes before it powers down)
8. Power up the printer and follow the steps.
reinstall ink ect......
I don't know why this happens but I sure a lot of printers are in the trash because of this. If you print out a SELF TEST REPORT the
dates on the age of the ink Cartridges are likely out of life range.
Planned obsolescence by HP can be found all over the web. This could be one of those.
HP Photosmart 3000 C6100 C7200 PSC 7280 Printers HP 02 Cartridge...
Press the helpfull Thanks!!!!
May 01, 2014 | HP PhotoSmart Office Equipment & Supplies
Ink threshold exceeded
6. Press OK
Feb 04, 2014 | PrintCountry HP Photosmart C6280 Inkjet...
After printer said ink cartridge was empty I removed it & found it was not-I put it back in printer & now getting error message that the cartridge is used & needs to be replaced. How can I
your only option it to replace it with a new one . printer mfg's have chipped the cartridges and they can not be reused.unless the chip is recoded as new .
Aug 16, 2017 | Ricoh Aficio GX3050N Printer
My iP4200 will not print anything after i change the cartridge and no error or falshing lights were found
This is a common problem and can usually be solved by doing the following:
1.) Remove the cartridge from the printer and ensure that the clear sticker placed over the contacts of the cartridge has been removed.
2.) Clean the contacts of the ink cartridge with tissue paper. Surgical alcohol may be used as a solvent.
3.) Use the software that came with your printer to clean the ink heads. The ink cartridges need to be installed in the printer. You may need to Deep clean the ink heads several times. Around 3-5 times seems to be the magic number.
Tell me how it goes!
Take care!
damnor01
Jun 09, 2011 | Canon PIXMA iP4200 InkJet Photo Printer
PIXMA 450...Keep getting paper jam message and I can't see any paper bits anywhere. Trying to open the machine from the back to look inside. Have removed the 4 screws on the back and still can't remove...
Hi
The paper jammed can be found in the paper tray, remove the paper at the paper tray and inspect the roller for small pieces of paper jammed.
The paper can be found in the ink cartridge compartment, open the cartridge door and remove the ink cartridges, look for posibble paper jammer. Also once remove, check also the cartridge carrier if does not stuck up or jammed (cause this might me the problem). Turn off your printer and then move the cartridge head using your hand moving to the from right to left side and from left side to right side for 2-3 times. Move it gently.
Paper can be found in the rear access door if it is accessible. Inspect some paper jammed there.
Please let me know if you need more help
Mar 10, 2011 | Canon Pixma MP450 All-In-One InkJet...
Canon pixma mp780 not printing. Message says ink out [which it isn't], then says printhead needs replacing....I don't have manual anymore so I don't even know where printhead is found much less how to...
the print heads are found directly under where the ink cart..go in. try this first, remove the ink cartridges and with a eye dropper put a little alcohol where the cartridges seat.. let it set for a few minutes then put a little bit more. then reinstall the cartridges and try to print something.. the heads are most likely gummed up with old ink.. if it does not work at first try again a couple more times... make sure you have some newspaper to set the printer on. also some hand cleaner like gojo for your hands, do not use hot water when washing your hands because heat sets printer ink just cold water.. and you will get it off if you get it on your hands. but it is best to wear surgical rubber gloves..good luck.. let me know how you do..
Nov 12, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Says ink tank level low when it is still half full.Then will say out and still lot of ink in cart left yet.
This usually happens when you are using aftermarket inks. The sensors on the cartridges are not always up to specs. The problem does not occur on OEM cartridges.
Sometimes you can remove and reseat the same cartridge and the printer will resume. If the problem persists after trying the remove and reseat procedure, the cartridge should be replaced and the defective cartridge discarded.
If you are near an office supply that rebates for old cartridges and you are reloading your own cartridges, take the old cartridge in and replace it with an OEM cartridge so the problem doesn't repeat.
Hope this helps.
Aug 10, 2009 | Canon PIXMA MX850 multifunction InkJet...
Epson sx 200 printer cannot change ink cartridge
Ive just pressed the 'stop' button on mine and it moved the cartridge to show which ink needed replacing and then when pressed again it moved to the replacement gap
Mar 24, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Ink
Remove and Install Cartridges Be sure you have your replacement cartridges handy before you begin. You must install new cartridges immediately after removing the old ones. Caution:
Do not open ink cartridge packages until you are ready to install the ink. Cartridges are vacuum packed to maintain reliability. 1. Turn on the Epson Stylus CX8400 Series. If a cartridge is low or expended, you see a message on the Epson Stylus CX8400 Series LCD display screen. If a cartridge is expended, you must replace it to be able to print. If a cartridge is low, you can continue printing until the cartridge needs replacement. If you’re replacing a cartridge before you see a message on the Epson Stylus CX8400 Series LCD display screen, press Setup, select Maintenance, and press OK. Then select Change Ink Cartridge and press OK. 2. Open the scanner. 3. Open the cartridge cover. 4. Squeeze the tab on the cartridge and lift the cartridge straight up to remove it. Dispose of it carefully. Do not take the used cartridge apart or try to refill it. Warning:
If ink gets on your hands, wash them thoroughly with soap and water. If ink gets into your eyes, flush them immediately with water. Keep ink cartridges out of the reach of children. 5. Before opening the new cartridge package, shake it four or five times. (Do not shake a cartridge after opening the package; ink may leak.) 6. Remove the cartridge from the package, but be careful not to touch the green chip on the cartridge. 7. Remove the yellow tape from the bottom of the cartridge. Caution:
Do not remove any other labels or seals, or ink will leak. 8. Insert the new cartridge into the holder and push it down until it clicks into place. 9. Once you replace all the necessary cartridges, close the cartridge cover and push it down until it clicks into place. 10. Close the scanner. 11. Press OK to begin charging the ink. This takes about 2 minutes. When you see a completion message on the LCD display screen, ink charging is finished. Caution:
Never turn off the Epson Stylus CX8400 Series while ink is charging or you’ll waste ink.
If you see an ink replacement message on the LCD display screen, press OK and press down all the cartridges securely.
If you remove an ink cartridge for later use, protect the ink supply area from dirt and dust and store it in the same environment as the Epson Stylus CX8400 Series with the label facing upward. Note that there is a valve in the ink supply port, making covers or plugs unnecessary, but care is needed to prevent the ink from staining items that the cartridge touches. Do not touch the ink cartridge ink supply port or surrounding area, and do not store the cartridge upside down.
If you remove a low or expended ink cartridge, you cannot reinstall and use the cartridge.
Nov 10, 2008 | Epson CX8400 All-In-One InkJet Printer
I cant print
I DON'T KNOW WHAT YOU ARE SAYING ABOUT " ADDING UP INK ON ITS CARTRIDGES WITH COMPATIBLE ONE". IF YOU USED THE DISCOUNT REFURB, INK CARTRIDGES, A LOT OF TIMES THESE WON'T WORK RIGHT. I WOULD CHANGE TO THE CORRECT CARTRIDGES FROM HP AND TRY TO PRINT AGAIN. IT IS NOT A GOOD IDEA TO LEAVE OLD CARTRIDGES IN A PRINTER FOR A LONG TIME IF EMPTY, REMOVE THEM. IF THE PRINTER IS NOT GOING TO BE USED FOR SOMETIME, REMOVE THE INK CARTRIDGES. AS FOR THE CORD, MOST PRINTERS USE A COMMON CORD FOUND AT MOST DISCOUNT STORES LIKE WAL-MART,K-MART ETC. YOU SHOULD FIND ONE THERE.
ARCLIGHT1217
Aug 24, 2008 | HP PSC 1110 All-In-One Thermal Printer
Lexmark X4270 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
