Question about Hotpoint Refrigerators
The freezer compart defrosts completely. I took all the food out and then it started to freeze again after we moved the temp setting up and down
  • 532 Answers
In a cold location the freezer may begin to defrost or even completely defrost. Most fridge freezers will only operate satisfactorily in an ambient temperature down to plus 10 degrees C although some need a minimum of plus 18 degrees C. This may seem strange but the fridge thermostat governs the operation of the freezer and if the ambient temperature drops to either of the figures above the fridge will switch off.
That will not be a problem for the fridge which should be cool enough to keep its contents safe but it will mean that the freezer will cease to work and that will create a problem. Take note of the Climate Class of the appliance which will tell you the temperature range that the appliance is suitable for use in. The classes are as follows:
N ? ambient temperatures between +16 to +32 degrees C
SN - ambient temperatures between +10 to +32 degrees C
ST - ambient temperatures between +18 to +38 degrees C
Also note the higher temperatures which should be taken into account if the appliance is somewhere that is likely to get hot in the summer.
Thanks.
Posted on Jul 15, 2010
I cannot understand the dual thermostat manual (" rolling " knob type) controls . They are printed in Japanese . There are 2 temp. control knobs side by side located inside the ref. compartment / lowe
Don't think it's the temp control problem, I suspect one on the defrost elements at the top is faulty, if food starting to defrost in the cycle indicates the lower element is working overtime.
Nov 22, 2014 | Refrigerators
Ge dss25ksress
Scenario:
When the defrost timer on your self defrosting unit closes, it shuts down the operation of the compressor and the evaporator fan in freezer compartment while the defrost heating element under the evaporator gets turned on to defrost the ice buildup in freezer. A defrost thermostat attached to the evaporator coil will turn off the defrost heating element if it gets too warm. Then when the defrost timer opens, the compressor and evaporator fan get turned back on for normal cooling cycles via the thermostat.. The defrost cycle lasts about a half an hour and repeats itself every 8 to 10 hours.
By the very nature of its operation you can see that in a self defrosting refrigerator, freezer temps are subject to a rather large fluctuation every time the self defroster goes on. Ergo, frozen food in such a unit will not keep for as long as in a commercial refrigerator or chest type freezer where such a circuit does not exist, temps are constantly low, and food lasts longer. And of couse, when the freezer temps go up as a result of the heater operation it follows that refrigerator temps will also go up since cold freezer air is no longer being funnel to fridge compartment. But since the refrig temps were never as low as those of the freezer, the temp variation during the defrost cycle will be considerably smaller.
If the self defrost mechanism is not working in accordance with the description above then maybe something is wrong with the control board if you have one on your unit.
Nov 28, 2013 | GE Refrigerators
Can I remove the freezer compartment from my Haier HSE12WNAWW?
not possible to remove the freezer
the most likely [problem is that the seals around the freezer door are not sealing properly
that allows the atmosphere into the freezer and the humidity then freezes and turns to ice , causing the problem
adjust the door and change that door seal
when defrosting the freezer, remove all the frozen food, and place a fan at the open door
atmospheric temp air will defrost a badly iced freezer in around 1 hour with the use of the fan on high speed
Apr 05, 2017 | Haier Refrigerators
Food in refrigerator is freezing
check the damper door between the freezer and refrigerator compartments,it most likely has frozen in the fully open position allowing cold air into refrige compartment all the time,you will see ice build up around the damper door unit,remove the door unit defrost,replace and then see if it moves when you change the refrige cold control
Jan 12, 2010 | GE Refrigerators
My daughter's mini fridge has a freezer compartment. Her issue is, if she turns it up high enough so the freezer freezes, the fridge compartment also freezes everything; if she turns it down so that the...
This is a drawback of most mini-fridges. Start by defrosting everything. Then fill ice cube trays with water and keep lowering the setting until the water freezes. Just go a little lower, no more. Fridge should not freeze food. If the fridge stays closed all the time food will freeze. Also if the freezer element gets ice buildup it must be defrosted. Not automatic like home fridge. Most kids today weren't born when the last fridges that had to be defrosted were in service.
Sep 01, 2009 | Refrigerators
Coils keep freezing up its 4 years old
Iced-over evaporator coils, accompanied by a non-chilled fresh food compartment, happened in my GE side-by-side (model GSS20IEMDWW). For me, the problem was caused by a faulty temp sensor in the fresh food side. That sensor never signalled the computer that the temp in the fresh food side was cool enough, so the compressor ran constantly.
Since the compressor was running constantly, the evaporator coils (back wall of the freezer compartment) eventually iced over (took about a week). Since the fan that draws air over the evaporator coils could no longer move any air (due to the icing), the temperature in the fresh food side got warmer as well.
The fresh food side is chilled through a hole with a motorized door at the top of the dividing wall between compartments which opens when the fresh food side needs cooling. If no air is moving in the freezer compartment, temps in the fresh food compartment climb.
I replaced the temp sensor in the fresh food side and solved the problem for a while.
I bough a pair of thermometers at a kitchen store and put one in the freezer compartment and one in the fresh food compartment so that I could occasionally check to see if it made sense for the compressor to be running (ie, was it really necessary to be trying to cool either compartment, or were they already cold enough).
About six months later I had the coil icing problem again. This time the fresh food side seemed cool enough (according to the thermometer as well as the fact that the flapper door would close, indicating that the computer knew to not try to additionally cool the fresh food side).
The thermometer indicated that the temp in the freezer compartment was cold enough, but the system computer continued to run the compressor. So I replaced both temp sensors in the freezer compartment - which solved the problem again. (My fridge is about seven years old.)
If you are going to replace any of the temp sensors, replace them all under the principle of "if one failed, the rest will soon fail too".
Use a website like www.partselect.com to look up a parts diagram for your fridge and see if you can order just the temp sensors. Other websites (www.repairclinic.com and www.appliancepartsworldwide.com) may also be helpful. I have no affiliation with any of the sites I just mentioned - I'm just posting them as resources.
Jul 30, 2009 | GE GSS20IEP Side by Side Refrigerator
I just has the motherboard replace last week and now the Refrigerator side stop working and I have Ice on the back wall of the frezzer . Frezzer is still working well. gss22wgmd
You don't say why the mother board was replaced. Make sure the board was the correct one, part number WR55X10656 for your GSS22WGMD and that all plugs are firmly and correctly attached to it. If yes, then check the defrost heater (located behind the back wall inside the freezer, near the bottom) to see if it is burnt out. (If you disconnect the wires from each end of it and test, finding no continuity, it is bad) It is a part number WR51X10101 for your model, and is a fairly common failure point. While you have that apart, manually defrost the coils with a hair dryer. (the manual defrosting alone will get your refrig working for at least a week, allowing you time to get any needed parts.) If left alone without defrosting, your freezer section will not be working well soon either.
Jul 29, 2009 | Refrigerators
The coils on my ge gss22wgpd bb side by side keep freezing up . IU can defrost them manually and the freezer and fridge work fine again.
This has happened in my GE side-by-side (model GSS20IEMDWW). For me, the problem was caused by a faulty temp sensor in the fresh food side. That sensor never signalled the computer that the temp in the fresh food side was cool enough, so the compressor ran constantly.
Since the compressor was running constantly, the evaporator coils (back wall of the freezer compartment) eventually iced over (took about a week). Since the fan that draws air over the evaporator coils could no longer move any air (due to the icing), the temperature in the fresh food side continued to climb. (The fresh food side is chilled through a hole with a motorized door at the top of the dividing wall, so if no air is moving in the freezer compartment, temps in the fresh food compartment climb.)
I replaced the temp sensor in the fresh food side and solved the problem for a while. About six months later I had the same problem again, so I replaced both temp sensors in the freezer compartment - which solved the problem again. (My fridge is about seven years old.)
This site has schematics of various appliances, including the model number you provided...
http://www.partselect.com/AdvancedModelSearch.aspx?ModelNum=GSS22WGPDBB&mfgModelNum=&fkMfgID=2
Your model appears very similar to mine - in the "Fresh Food Shelves" section of the above site, the sensor is diagram number 242. In the "Freezer Section", the sensors are diagram number 241 and 243.
Jul 28, 2009 | GE Refrigerators
I have a roper model RT14ZKXDWOO and the freezer is working fine but the refrig is warm. I took the panel off the back of the freezer and it is full of ice. What should i do next? and is there a diagram...
Hi,maybe I can shed a little light.I don`t know where the defrost timer is,but I would melt the ice with a hair dryer and real warm water(it will make a mess so be ready).There will be a drain inside of the freezer compartment,on the inside.Some how the rear panel inside the freezer compartment comes out.You may have to take apart the whole inside of the freezer compartment just to remove this rear panel.But when you do look for ice build up on bottom of freezing unit,and the rearof the freezer compartment.Melt this ice the same way earlier described.You will find a drain that starts inside the bottom-rear of the freezer compartment.This drain goes all the way down to the bottom of the fridge.You will find a very shallow drip pan under the fridge.This pan will most of the time only receive a little amount of water at a time and evaporates quickly.Now while you thaw this drain,water will start draining threw the drain,if it is not stoped up with food particles and such.This would be a good tome to blow threw this ine from the bottom where it drains into the pan underneth the fridge.Then blow threw it at the top in the freezer compartment.You can use a air tank with a blow gun.Be sure to pour water threw and down this drain to wash out all particles left behind.Clean the freezer compartment out good(the particles of food and such) and reassemble the freezing unit.plug fridge back up and set the freezer control to a respectfull setting(not the coldest and not real cold)and set the frideration to a decent setting for food preservation. Let the fridge and freezer run 12 to 24 hours to see if your problem comes back,and then time will tell if your defrost timer is bad,or is working like it should.When the drain clogs,it starts freezing away from the defrost elements and continues freezing the blocked water untill it overtakes the coils .The defrost and the timer don`t stay on long enough,or hot enough to overcome the ice.This is the reason you should try this solution first.If I can help you anymore,let me know roniecon@gmail.com /let me know how it turns out
Jul 12, 2009 | Refrigerators
Fridge keeps on freezing everything inside of it
This refrigerator only has one thermostat located in the fresh food compartment it is designed to activate the sealed system (cooling) until it reaches approximately 37 deg f in the fresh food compartment. The damper controls how fast the cold air can move from the freezer compartment to the fresh food compartment. Allowing you to control the temp in the freezer by controlling the flow of cold air to the thermostat.
You have one of two problems.
#1 your thermostat is no longer opening when it achieves set temp. fix = replace thermostat pn 61005798 $35
#2 your damper arm or assemblie has broken. Fix = Replace damper or broken arm and actuator.
damper assembly pn12001377 $44
damper actuator pn 61002000 $2
damper arm pn 61001999 $2
thermostat actuator arm damper arm
damper assembly both pics
Apr 06, 2009 | Refrigerators
Refrigerators Logo
74 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal DeAngelo
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
