Question about Toshiba 36A40 36" TV
Picture compressed into upper half of screen
The picture is compressed into the upper half of the screen when the set is first turned on. After a minute or so, it expands to fill the screen. I cannot find any horizontal/vertical adjustment.
  • lpress Apr 22, 2008
    > This is not an adjustment.
    Don't most sets have adjustments to compensate for such changes with age?
    > Very often it can be a number of electrolytic
    capacitors.
    Is there any way to narrow it down?
    > An experienced TV tech can service this for you.
    Do you know of any Web sites that help folks find recommended repair people?
    > After the fix, the TV should work as normal.
    Do you it is worth fixing or would you expect this to be the tip of the iceberg? I like the set, but if other parts will be failing, it might be time to replace it.
    Thanks for your help!
    Larry
    Genius:
  • Toshiba Master
  • 1,689 Answers
This is not an adjustment. There are some components that have become thermo sensitive with age and use. The fault is in the vertical deflection circuit area. Very often it can be a number of electrolytic capacitors.
An experienced TV tech can service this for you. After the fix, the TV should work as normal.
Jerry G.
Posted on Apr 22, 2008
I have a 37" JVC LCD TV Model # T370HW02 and the left half of the picture if filled with vertical colored lines for approximately 30 minutes after the set is turned on then the picture clears up and s
The problem with your TV is the screen tabs this is where the electronics bond to the screen a technician may be able to fix it with compression pads otherwise it a new screen
Apr 11, 2017 | JVC Jlc37bc3000 37 Lcd Tv 1080p
Panasonic plasma TH-42pz700 has left hand side of screen distorted
The set uses two boards to drive the screen --one for each half or side.
Different names are used like sustain or in LCD sets inverter.
Apr 02, 2012 | Panasonic Viera TH-42PX80U Plasma TV
Black box in upper left of screen
Thats the PIP (picture in picture), which lets you watch two pictures at once.  Push the PIP remote or go into the settings to turn the box off.
Nov 16, 2009 | LG 42LC2D 42 in. LCD HDTV
No picture in upper half of screen, normal at bottom
Could be something as simple as a bad contact on one of the deflection yokes or other coils on the cathode ray tube - check the contacts on the circuit board where these coils are connected, resolder the pins or wires if the contact is bad, also check connector pins for any dirt or oxydation and clean if necessary.
Read more about this kind of problem at:
http://www.repairfaq.org/sam/tvfaq.htm#tvpopco
Hope this helps somewhat.
regards
3rq8 (Triarcuate)
Sep 04, 2009 | RCA 20F512T 20" TV
Will it be less expensive to have repaired or buy new HDTV?
The vertical deflection amplifier has failed. They should be able to find the bad part easily. Get a quote before they begin and decide the economics of it. The actaul bad part is probably less than $10 cost.
Aug 25, 2009 | Gateway CX200S Tablet PC
My older Toshiba TV is showing horizonal lines on upper screen.
maybe dust in the back of set try giving it a hoover out but unplug first
Mar 19, 2009 | Toshiba Televison & Video
Model 42mf231d/17 42" plasma
If the loss of picture is either on top half or bottom half of screen. there are y buffer boards that go from top to bottom on left side of screen when looking at back that control those sections. when there is loss of half of picture then buffer associated with that area would be at fault and would need to be replaced. when i see a degrading symptom such as loss of picture on top half or bottom half leading to no picture issue normally you would check heat syncs on y sustain board and if not heating up after a few minutes of being turned on would recommend replacing y main and both y upper and lower y buffer boards as they complete a circuit
Jun 04, 2008 | Philips Magnavox 27MS343S 27" TV
Half screen activated only
When only a half screen is produced, it is usually a upper or lower buffer board, if the top half is blank then it is the upper buffer, and of course if it's the bottom half then it's the bottom buffer board
Sep 15, 2006 | Panasonic TH-42XVS30U 42 in. Plasma HDTV
Screen split with black bar through center, top of picture shows in bottom
It sounds as you desribe, the vertical output IC and or the b+ feed capacitor off the Hi voltage transformer feeding the vert. IC its required voltage. Not a really hard job to replace, but not for a handi person to do. This should be left to the professional, as there are no user serviceable parts inside this set and with the HI voltage and the safety issues its best to call somesone to assist you with this repair. Good Luck
Jun 14, 2006 | Sanyo DS31520 31" TV
Toshiba 36A40 36" TV Logo
118 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
