Question about Ovens
My wendys Garland Range/oven will not heat up ?? the top range is heating up ok but the oven dose not !!
bigg t
  • 640 Answers
SOURCE: Garland gas range
look at the bottom panel below the doors.on the left and right side youll see screws--remove them.open the doors and you should see 2 more screws.pull the panel out towards you.youll see the serial/model number on it or the frame of the oven.if the glow coil is red try to manually light the burner witha paper towel.if the burner lights, the burner may be obstructed --if not the gas valve may not be opening.you will need a voltage meter to test the coil on the gas valve.if you get the correct voltage on the valve coil which is 24 volts ac and no gas the valve is bad.if you dont have 24 volts the ignition board is bad.let me know.
Posted on Jan 21, 2008
aborcass
  • 2651 Answers
SOURCE: heating element in GE Range Oven
get the model number and order the exact repacement bake element
Posted on Mar 10, 2008
  • 41 Answers
SOURCE: my garland air deck will not heat up
I own a large repair company we charge these fees for our tech. ability I often give you people free advise but when you insult our techs try to figure it out yourself then you will know why we chargey the way I would not give you free advise you would not say thank you
Posted on Jan 01, 2009
  • 17 Answers
SOURCE: Frigidaire Gallery ES340 electric range, burners will not turn on
Okay,
1, check your power, locate your breaker for the range. turn the breaker off and turn it back on.
Your Range it is electronic control on the Oven but not the Stove Top heating elements.
After you reset the breaker and it still not work.
Please let me know more about the unit.
When you purchase.
How/when it happen.
What is the indicator showing.
nguyen@ite.net
Posted on Jun 09, 2009
  • 127 Answers
SOURCE: kenmore electric range - oven temp low and takes forever to heat
if lower element tests open with continuity meter then it for sure is bad. i would also check the wire ends that connect to the element and/or the control board, they could have loosened allowing a bad connection and low voltage to elementor burnt off.. most ovens do not use the broil element at all during the bake cycle, only during the broil cycle.. some however do utilize the broil element during baking, but at a lower wattage or something..
best of luck,
ttfn
Posted on Oct 25, 2009
Oven dose not warm but the top range works
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Feb 20, 2011 | Maytag Ovens
Stove top want heat up
the bulb i am sure is ok . but you have had a power failure to the burner . it could be the burner itself . if all the burners do not work the power to the range may be the problem .. ck the main fuse and make sure the 220 power is ok mm
Jul 12, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Our Oven is not heating up at all. The top range works but oven is broke
Is the timer clock flashing,it may just need resetting.
Hope this helped.
May 17, 2010 | Ovens
The oven will not light on my Whirlpool gas oven Mod SF368LEPQ 2. The stove top burners still light.
Sounds like you need an bake element ignitor if the bake doesn't work but if the broil also doesn't work, it could be the electronic clock/timer control. the part number for the bake ignitor is 8054129 .Best off to call a reliable service company such as Sears.
Jan 31, 2010 | Whirlpool Ovens
Model TE2B garland does the fan run to move
The fan runs to circulate the heat inside the oven for more even and faster cooking...That is how a convection oven works :)
Jan 14, 2010 | Garland Convection Oven - MCO-NAT Gas
Oven not coming on/heating up although top plates are working
If the burners are heating up but seem to take along time to get up to heat and your oven doesn't seem to be working you may have only 115 volts of power going to the range rather than the full 240 volts that are needed to power up the bake/broil oven elements.Check circuit breaker(s),check range receptacle behind the range for 240 volts,check for full power at the terminal block on the back of the range where the cord connects to the range.Good luck!
Nov 22, 2009 | Smeg Ovens
Can a microwave listed as a countertop be installed over an oven or should an over the range type be installed?
over the range should be installed
they are desined to take the heat being over the stove will generate
as well as become your vent for the stove top
Oct 09, 2009 | Ovens
GE glass top and oven are not heating?
I have an electric oven that is turning on but not heating up. The oven, broiler, & stove top are not heating up. Any easy solutions to this?
Jul 18, 2009 | GE Profile JKP18 Electric Single Oven
Okay,
When you purchase.
How/when it happen.
nguyen@ite.net
Jun 09, 2009 | Frigidaire 30 in. Electric Gallery Series...
Heating element in GE Range Oven
Mar 10, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
22 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
