Question about Garden
My Honda XR2750 pressure washer doesn't seem to be spraying a full capacity. Is there a blockage and /or filter I can clean?
  • 5,603 Answers
Usual cause is the water admitance valve that regulates the pressure by admitting more or less water.
Remove the valve parts and clean the bore with crocus cloth on a dowel rod. Replace the O rings and lube with plumber's grease.
Re-assemble.
Posted on Jul 15, 2010
Honda 8hp motor only starts with quick-start fluid
if you have gas to carb rebuild carb or relace
Jul 07, 2012 | Honda 8 HP Engine
Gcv160
High likelyhood of your intake screen/filter being stopped up with debris that was in the water hose.
Other than that, more information would be needed. Like, does no pressure mean it doesn't seem to spray at all (or nothing more than the water hose is pushing water through the system with the engine off)? Or does the pressure come up a little and there is a pulse you can feel in the hose/trigger gun? Any other little details you notice can provide clues as to the root of the problem.
If it was just a stopped up intake, and this fixes your problem -- please take a sec to rate me. Thanks!
Don
Mar 24, 2012 | Honda Black Max 2600 PSI Pressure Washer
Tipe of oil and quantity for 6.0hp 2750 psi (xr2750)
any sae10w-30 will do, 5.3litre of if you prefer 5.6us quarts.
manual is available on this site:
http://www.cpocampbellhausfeld.com/maxus_tools/pressure_washers/mx5223_spec.html
if you find my advice helpful, please do not hesitate to comment and vote4 for me, thanx!
Jul 31, 2010 | Honda Maxus Prosumer MX5223 Pressure...
F5 flashing and machine wont empty help
F05 means pressure switch jammed on full.
Do the following.
Remove lower rear panel of washer.
Locate and remove the large black hose fastened to bottom of drum.
Remove and clean filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.Reassemble, and test.
Please rate my solution.
Thankyou.
Dec 29, 2009 | Hotpoint Aquarius WD640 Front Load...
Lost pressure
try this
dissconect hose and lance , and check for water flow through the machine , if theres none or just a trickle then you may have gunk in your inlet filter ( usually a small plastic gauze insert just where the water feed hose connects )
then start machine , check for high pressure flow ( you will see the difference )
its quite common for the nozzle on the lance to become blocked
if all this seems fine but the lance is vibrating then you have a blockage in one or more of your pump valves .
Nov 11, 2009 | Honda Pressure Washer PSI 3000
Honda Pressure Washer HP 5 not starting
You can try spraying some carburetor cleaner into the carb. If it starts for a minute, your carburetor need cleaning. When you added new gas did you remove the old gas first? Is the air filter clean?
Jul 18, 2009 | Honda 8 HP Engine
Honda p/washer won't **** up cleaning chemicals cleaned filter,still no go.
In general, pressure washers will draw detergent from the reservoir only when the spray nozzle is set to low pressure. At high pressure a non-return valve closes to prevent water flowing back in to the reservoir. If you've got the spray nozzle set to low pressure and still have the problem, it may be that the spray nozzle is partially blocked - you can try clearing it with a length of wire.  Failing that, the non-return valve is probably stuck (and that may need professional attention).
Apr 17, 2009 | Honda Garden
I'm trying to find out how much oil should be in the water pump of a honda pressure washer model xr2750-1
it's an ex-cell pressure washer with a honda motor.
engine oil capicity: 0.61 qts(.58L)
view owner manual here:
http://www.excellpressurewasher.com/documents/pdf/a12338-e.pdf
Mar 10, 2009 | Honda Garden
Pressure washer stalls
Pressure washers work under very dirty conditions, no wonder they encounter engine problems. Here are a few pointers from a former pressure pump tech. The unloader is a source of engine overloading however this can easily be checked with a pressure guage attached to the gun with a tee fitting having the guage and the normal tip used for the unit. The pressure should never rise over rated pressure. The pressure should drop considrably when trigger is released. The life of the pump and engine can be increased by setting max pressure to 75% of rating. Most engine problems are from following conditions:
Leaking or misadjusted valves; clogged muffer /spark arrester; weak spark coil that is about to fail completely; kill switch/oil sensor wiring and or sensor mal function; gas cap not venting properly causing vacuum in tank and wet or dirty air filter.
All these problems easy to check, fastest repair is to disconnect oil sensor wire to check oil safety system. Then temp replace coil with known good coil. Loosen muffer bolts to check for clogged muffler. Temp run engine without gas cap to check for vacuum. Finally if everything fails, run the engine with carb cleaner spraying directly into the intake. If the engine continues to run with carb cleaner then the problem is fuel delivey and faulty carb. enjoy
Nov 15, 2008 | Honda Pressure Washer PSI 3000
Garden Logo
722 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
