Question about Frigidaire FRS26H5AS Side by Side Refrigerator
Frigidaire refrigerator temperature keeps changing. Refrigerator
Section only, not freezer.
Rotu
  • 175 Answers
SOURCE: Refrigerator not cooling properly
You may have a low freon condition in the fridge section. Look to see if you have an ice block building up on the rear wall towards the lower left side. If so, you are low on freon and the ost likely culprit is a leaking evaporater. The best way to tell if you are low on freon for sure is to take out all the shelves, remove the light cover, then the 2 screws holding the fan cover, and then remove the back wall. You wont be able to pull it all the way out cause the cold control is attached to it for the freezer and fridge so be careful. Turn the fridge control all the way up to 10 and wait till the compressor is running. you can tell if the compressor is running by pushing in the little switch on the top of the door frame and seeing if the fan runs(one switch is for lights, the other for fan) if it runs the compressor is on. anyway watch the coils and see if they develop frost all the way from top to bottom. If they dont you are low on freon and are ooking at about a $600 repair. if it does frost all the way you may have a bad cold control or a stalling fan motor up by the condensor on top. The best way to tell this is the next time the fridge feels warm, sheck the frame around the door seal and see if it is hot to the touch. If it is you almost surley have a bad condensor fan motor. Hope you can wade through all tis to find the answers. Good Luck!
Posted on Feb 24, 2007
the dr
  • 447 Answers
SOURCE: Refrigerator Freezing
Your refrig has a mechanical damper (the a b or c knob) it may be broken (uncommon ) \ is the freezer fan running even if the cold control is cycled?? Other than that it must be a faulty cold control These are very reliable refrigs and your problem is interesting. Please rate my solution
Posted on Oct 03, 2007
SOURCE: Kenmore refrigerator model 253 not getting cold
i have the same problem: botttom of refrigerator does not cool.
freezer working ok.
Posted on Mar 18, 2009
SOURCE: Top Freezer section working Bottom Refrigerator not getting cold
I have a side by side jenn-air refrigerator, the freezer compartment working fine and making ice like it should, however the refrigerator compartmant is not cooling, no cold air is felt, I need advise.
Posted on Mar 23, 2009
SOURCE: Refrigerator section warm. Freezer section OK.
Most likely it's a defrost system problem. One of the heaters could be bad and that will cause the coils to freeze up reducing the amount of cold air the fan can push into the fridge. Sounds wierd but, trust me, that could be your problem. Mine did that two years ago.
Posted on Apr 14, 2009
Frigidaire r134a the freezer is not cooling but the fridge is working
Bobby, I'm not sure what refrigerator you have but are you sure your refrigerator part is working? Did you actually measure the temperature in it? It should be around 40 deg F. The reason I ask this is because in most cases, the refrigerator portion of the unit receives its cold air from the freezer. This suggests that you can't have a problem in the freezer section without a problem in the refrigerator section. You may want to clarify this point before you move on with the diagnosis.
Dec 07, 2016 | Frigidaire Refrigerators
Why dose it keep beeping ?
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator
Cause of Beeping Noise in Frigidaire Refrigerator eHow
Jun 20, 2015 | Refrigerators
Why is my Fridgidare side-by-side freezer working but my refrigerator side not cooling?
Hi Friend, this is Z. Thank you for your question!
If the temperature in the freezer compartment of your Frigidaire refrigerator is cooling but the refrigerator side is not, it may possibly be because the temperature control is set too cold/high in the freezer section or the damper door is not closing. Turn the control to a warmer setting and allow several hours for the temperature to stabilize. If the temperature does not stabilize within 24 hours, then more than likely the control is not telling the damper when to close and/or your refrigerator might possibly have a faulty thermistor or temperature control. I would personally contact a professional to accurately diagnose your refrigerator to determine the root cause to reduce the risk of unnecessary parts.
May 21, 2014 | Frigidaire Refrigerators
Fridgidaire refrigerator flashing error code 4
From what I remember a flashing 4 means "damper error". Send your model number found inside or on the outside of the fresh food section, The air damper is found between the freezer and fresh food section and regulates temperature in the fresh food section by opening wide for things that warm up your fresh food section example would be opening the door and letting warm air inside . The damper then closes to keep the right temperature. If you have questions please ask, Thanks Sea Breeze
Sep 07, 2012 | Frigidaire Refrigerators
Frigidaire refrigerator/freezer side by side--compressor keeps running
Most problems with side by sides frosting up is due to failure of the defrost heater in the bottom of the freezer section behind the panel inside.
Jun 16, 2012 | Refrigerators
I have a Frigidaire refrigerato with top freezer that I keep on the back porch. The freezer has quit working completely. The temperature has been below freezing lately and I was wondering in this has...
Good day,
Yes, Frigidaire specifically states any temperature below 55 degrees will unbalance the machine causing the freezer to warm.
This is due to the fact that the thermostat that runs the entire machine is located in the fresh food section. When it reaches it's normal temperature it shuts the entire machine down.
In cold weather it could stay off for the best part of the dy, if not the entire day.
As well. on some model Frigidaire's, they makes a winterizing kit.
It is wired to the thermostat in a manner that heats the thermostat artificially in cold weather to cause it to cycle more.
Contact your local appliance parts house to see if they carry the kit for your machine.
Feb 17, 2010 | Frigidaire FRT21H8 Top Freezer...
Freezer temperature won't get cold enough.
This might sound stupid, but I had a similar problem. A few years ago when I was renting I noticed that suddenly my freezer stopped working well. I eventually had to call my landlord to check it out. It turned out that there was a knob to adjust the freezer temp and I had turned it to the warmest setting somehow. If it isn't that, I would return the freezer.
Hope that works for you
Jan 18, 2009 | Frigidaire FRT18G6J Top Freezer Side by...
freezer working ok.
Sep 30, 2008 | Frigidaire FRT17G4B Top Freezer...
Food stays frozen regardless of temperature setting
It is possible it has a bad thermostat but most likely cause would be a bad damper motor.  It is the vent inside the fridge that opens and closes, based on temp. setting, to allow cold air from the freezer into the fridge section.
Oct 14, 2007 | Frigidaire FRS26H5AS Side by Side...
Frigidaire FRS26H5AS Side by Side Refrigerator Logo
153 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
