Question about Vivitar ViviCam 5386 Digital Camera
MEMORY CARD I FORMATED THEN PRESSED OK, THEN THE CAMERA READS -ONE MOMENT- THEN AFTER A FEW SECONDS THE SCREEN TURNS BLACK
  • 13,433 Answers
Can you proceed to take pictures?
Posted on Apr 20, 2008
  • Ekse Apr 20, 2008
    in some cameras the lcd turns off after the camera is ready to take pictures, its a setting in the camera, can you still use the camera after the screen turns black?
  • Ekse Apr 20, 2008
    If camera doesnt work after the screen turns off, then the camera is haveing a hard time formating the card, I would recommend formating it in a pc. or takeing the camera to be checked for faults
    free repair estimate
    http://www.advancecamera.com/repair/
Format memory images
Paul,
You are using misleading words. You can format a memory card. And images can have a certain format, So I wonder what you mean.
Your camera can use the following format to save images:
5M (2592x1944pixels 4:3), 3M (2048x1536pixels 4:3),
2M (1920x1080pixels 16:9 )
VGA (640x480pixels 4:3)
To switch to another image format, press the Menu / OK button
Press the up down button till you see resolution then again press Menu / OK
with the up / down goto the format you want and press OK to confirm the selection.
The manual does not say anything about formatting the memory card. If you want to format a new memory card, put it in an external memory card reader and conner it to the computer. Format with FAT32. But my guess is, when you insert a memory card in the camera, it will show CD card inserted. that is the moment the camera will format the camera.
Success
Jan 26, 2014 | Vivitar ViviCam 5024 Digital Camera
When i turn on my s5700 there is a message (images recorded to internal memory) then on the screen is a white box with black letters (in) i have done what the manual said and formated but it has not made...
Okay "normally" when the memory card is installed the camera reverts back to the memory card from the internal memory. Two things might be happening here one the internal memory needs to be downloaded to the memory card then saved to the computer and the internal memory card formatted. then the memory card formatted to clear those pictures. And or there is a setting switch in menu or set up that you need to manually switch from internal memory to memory card.
I know when I read this over it made scents so you might need to read it a few times to get the idea of what I'm telling you needs to be done
Apr 19, 2011 | Fuji FinePix S5700 Digital Camera
I have a brand new PENTAX E70L camera, with SD memory card. i took a few photos on it and then turned it off. Now when i turn the camera on it reads -card requires formatting.I press continue , to format...
Make sure you don't have any pics on the internal memory. To be sure, with no card in the camera, go into the menu and find "format" and follow the on-screen instructions. Then, insert the card and go into the menu and do the format thing again to erase the card and optimize it. Use the menu and not the format option the camera has been giving you.
Sep 28, 2010 | Pentax Cameras
Memory card needs formatted is displayed on the screen. Deleted the pictures and it still comes up. Tried to take more pictures and the memory card would not hold. Is there something wrong with the camera...
I assume you have an SD card. If it's bigger than 2GB then it's actually an SDHC card and will not work in the ZD710.
No, there doesn't seem to be anything wrong. The card just needs to be formatted. In any mode press the Menu button. Press right-arrow to select the Setup tab (camera and wrench) then press OK. Press up/down-arrow to select "Format" then press OK.
Make sure you format the memory card. It's okay to format the internal memory, of course, but your current problem appears to be that the card needs to be formatted.
May 28, 2010 | Kodak ZD710 Digital Camera
Why My kodak dc280 can not read the memory card?
Try formatting your camera memory card If you own camera memory cards that have been used in other digital cameras, the card may not be properly formatted for use in your camera, or that data on the card may become corrupted. When these issues arise, your camera indicates that the camera memory card needs to be formatted.
When you format a camera memory card, all of the information on the card is erased. This includes any borders supplied on the card.
  1. Set the Mode dial to Camera Setup.
  2. Slide the POWER switch to the right to turn on the camera. The main Camera Setup screen appears.
  3. Press a updown_icon.gif button until the format_icon.gif icon is highlighted. format.gif
  4. Press the DO-IT button. The Format Memory Card screen appears.
  5. Press a updown_icon.gif button until CONTINUE FORMAT is highlighted.
  6. Press the DO-IT button to format the camera memory card and return to the main Camera Setup screen.
Dec 10, 2009 | Kodak DC280 Zoom Digital Camera
Screen black in all lighting. Icons and menu show and can view photos already on card, but screen black in all modes. Can take picture, but it is also black. Lens cover is open. Nikon Coolpix 4600. Thanks...
Hello, I went and researched a few points in the manual and hope this helps to some extent. If this doesn't help, try resetting your camera by removing the batteries for 30 seconds, then reinstalling them and turning on the camera again.
Monitor is blank:
• Camera is off.
• Batteries are not correctly inserted or battery-chamber
cover is not properly latched.
• Batteries are exhausted.
• EH-62B AC adapter (available separately) is not properly
connected.
• Camera is in sleep mode. Press shutter-release button
halfway.
• Monitor is off.
• USB cable is connected.
• AV/Video cable is connected
No picture is taken when shutter release button is pressed:
• Camera is in playback mode.
• Red (!) lamp flickers: flash is charging.
• Green (AF) lamp flickers: camera unable to focus.
• Message "CARD IS NOT FORMATTED" appears in
monitor: memory card is not formatted for use in your
camera.
• Message "OUT OF MEMORY" appears in monitor:
insufficient memory to record picture at current Image
mode setting.
Dec 02, 2008 | Nikon Coolpix 4600 Digital Camera
Screen black in all lighting. Icons and Menu show but screen otherwise black in all modes. Can view photos on card. Can take a picture, but it is also black. Lens cover is open. Nikon Coolpix 4600. Thanks...
Monitor is blank:
• Camera is off.
connected.
halfway.
• Monitor is off.
camera.
insufficient memory to record picture at current Image Mode selection.
Hi, I have a Canon Power Shot S2 IS 5.0 megapixels that was working fine until one day I changed the memory card from 512MB to a 1GB. Now every time I turn the camera on and try to take a picture, a...
Its possible that there may be an error on the camera try to reset the camera by
1. Turn the mode lever to the camera or play button
2. Press and hold the MENU button for more than 5 seconds.
3, The message "reset settings to default?" appears
4. Use teh arrow buttons to selelct ok. then press the SET button.
5. It should then reset the camera.
AFter doing that and the problem is still there. Format the memory card using the camera.
I hope this has answered your question sufficiently. If you have more questions please post a reply and i would be happy to assist. Thanks.
Oct 06, 2008 | Canon Cameras
Format Error in Sony Cybershot
i think this problem arises when you fail to regularly format the card ie. take lots of pictures and delete some and repeat the process over and over instead of downloading every session and formatting the card causing coruption. Also if you've bought pro duo memory stick off ebay poss. its a very good forgery (again i've been caught out by this).
Nov 05, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Memory Card
Format the card in the Camera- read your manual
Jul 31, 2007 | Fuji FinePix A500 Digital Camera
Vivitar ViviCam 5386 Digital Camera Logo
27 people viewed this question
Top Vivitar Cameras Experts
Tony
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
