Question about IBM ThinkPad R31 2656 Notebook
Recovery Partition Hi recently i had booting problems when dual-booting vista with linux but you guys helped me out with that. Thanks. Now i want to recover vista back to default. The problem is when trying to load recovery console at start, the F8 button doesn't work. The recovery partion is still there and healthy. There is no option to mark the recovery Partion as active. Is there a software that can do it?
    Genius:
  • 2,028 Answers
You will get a better response if you pay for the expertise we have to offer!
Posted on Jun 24, 2008
Had dual boot with linux, lose my XP. I have the 5 cd recovery disk, but I can not install my XP back.
  • Hello charlieri_1, this happens often when installing 'new' OS, especially when creating a "Dual Boot." What you will have to do is a "Clean Install" starting from scratch; unfortunately! You will have to use the "Recovery Disk" to install Windows XP, first! Next, after you have restore the XP [OS]; then you will install the more "Updated" OS, [Linux] "This is just the Operating System way of order; oldest first, latest last, to properly install the OS. Hope this helps you, thanks paul7of9."
Dec 17, 2010 | Acer Aspire T135 PC Desktop
Windows doesn't recognize recovery partition after os reinstall
The issue you are having involves using multiple systems,...If your emachine came with vistan and you installed xp, you voided your warranty status...However remove your dual boot and stick to vista if you wanna keep your restore partition working properly.....On a side note theres usually conflict with running OEM OS's on dual boot...typically it doesnt work and if it does it doesnt work like you want it to! so here is what you can do..Call Emachine up and fib to them a bit (just alittle) tell them that you cought a nasty bug and it messed with your restore partition and now you cant restore your pc....request the factory programing discs (if you ask nicely they'll hook you up 99.99% of the time) you get the discs so you can reprogram the pc to factory spec if you ever wanted to. Now use a retail version of vista and a retail version of xp. and create your dual boot, feel free to remove your restore partition if you want (cause you have the factory programing discs if you wanna go back to stock stuff YAY) I hope this helps!
Sep 26, 2009 | E-Machines eMachines Desktop PC
Installing Ubuntu after vista install gives "out of range"
http://www.tech-tips-now.com/2008/11/12/how-to-dual-boot-vista-and-ubuntu-810-part-7/
this is great guide to set up a dual boot option on your on pc
Mar 16, 2009 | ViewSonic VA2226w 22" Widescreen LCD...
Dual Boot problem in Windows XP & VISTA
Don't try to edit the xp boot.ini or the vista bootloader. It only leads to other problems and headaches.
Try this first: Take note as to which drive has vista on it, put your vista installation cd in the drive and let it boot to the "installation window", then choose "repair", then "startup repair." Make sure you choose the drive that already has vista on it. Let that run and when it re-boots you should then be given a choice to boot to vista or "other windows".
There is also a (free) program called EasyBCD. Download that, read the directions and have at it.
If none of that works, you'll have to do a clean install. Install XP on one drive first, then Vista on the second drive in that order. The Vista bootloader will pick up the XP. However, XP is NOT forward compatible and will not recognize the Vista bootloader. Make sure that you don't have any flashdrives or media cards plugged in before doing the install.
Another approach would be to shrink the Vista volume, creat a new partition, then install Linux Ubuntu that partition. Linux will detect all of the OS's and create a boot menu. Unfortunately, you'll lose about 5 gigs to the Linux OS and it's swap partition, but then, you get to goof around with Linux :-)
Feb 25, 2009 | Microsoft Windows Vista Home Premium with...
Dual Boot Ubuntu
1st, install windows or if you have already its good .
Then, download Linux distribution that suits You better
Download It and burn into a CD or DVD with ISO file you can use Magic ISO or other manufacturer
then Go to BIOS setup and set 1st priority is the CD or DVD drive and save and exit
and install follow the instruction of linux.
also if you chose capacity of windows or linux is to little dont worry you can make install a partition magic and resize what you like....
PS:
pls rate me if my solution solve the issue and you need more further information. but if is invaluable solution rate me fixya.
Sep 07, 2008 | Canonical Ltd. Ubuntu
Windows XP
It should have come with the 32. For dual boot on this machine, go in and set up XP on the same partition as Vista. When the machine starts up it will go to a screen that allows you to choose which op system you want. You shouldn't, but if you run into conflicts you will need to create a separate partition for the two op systems.
Jun 18, 2008 | HP Computers & Internet
Reinstalling Problem
Once you disrupt the partition table by introducing a new linux partition the recovery program is unable to identify the recovery partition. The only success I have had is to boot from a program called partition table doctor and using it to rebuild the master boot record and partition table structure, you can download it here: partition table doctor
of course there is no guarantee it will cure your problem but it is a very powerful tool I have used with some success. Please rate my assistance as we depend on your rating to carry on giving FREE advice.
Mar 29, 2008 | Compaq Presario Notebook
Acer Aspire 4720 RHEL4 Installation
again install linux in between the installation there will be option select linux boot loader , and one more think linux partition space should more then windows partition
Mar 26, 2008 | Acer Aspire 5100 Notebook
Dual Booting
possibly by first creating a new partition large enough for Linux OS, but does not solve your problem...try getting a VISTA startup disc from another pc (floppies if you have the drive) and startup from these.
Sep 09, 2007 | Microsoft Windows XP Home Edition
IBM ThinkPad R31 2656 Notebook Logo
57 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
