Question about Asrock P4I45GV R5 Motherboard
How can i enable the onboard graphics card so i can play CO2 well
  • 305 Answers
Press del key or f1 key or f2 key at the system power on ...you wil enter the bios setup u can find the option to change to onboard graphics there
Posted on Jul 15, 2010
Dualgraphics
Hello here is the homepage:
http://www.asus.com/Motherboards/AMD_Socket_FM1/F1A75M_LE/#specifications
To enable crossfire, you must have 2 identical graphic cards.
The onboard graphic can`t be used with the hd6670.
This means that you must buy another hd6670 to add on the mainboard.
The graphic cards homepage:
http://www.asus.com/Graphics_Cards/AMD_Series/EAH6670DI1GD3/
AMD CrossFire technology is the ultimate multi-GPU performance gaming platform. Unlocking game-dominating power, AMD CrossFire harnesses the power of two or more discrete graphics cards working in parallel to dramatically improve gaming performance.
You also need a large power supply min. 500 watt to have enough power.
Please disable the onboard graphic in the device manager.
Good luck
Jan 06, 2013 | Computers & Internet
Graphics card didnt work so bought a new 1 and that doesnt work either,but the onboard 1 works, please help
Reboot the computer and enter the BIOS.
Somewhere in the several pages of BIOS pages there is a place to turn off the onboard graphics.
This should enable the PCI graphics card.
Jun 20, 2011 | Computers & Internet
Ive installed the ati his radeon ice q graphics card and my computer will not boot,Why?
hook monitor cable back to your onboard video port then 1st make sure you have already downloaded the driver for your new graphics card. then at start up go into system setup and go to your display and make sure that you have your new graphics card enabled as your primary graphics instead of onboard video. it will say something like 1.Onboard 2. AGP/OR PCI MAKE SURE YOU DONT HAVE YOUR ONBOARD ENABLED AS YOUR PRIMARY VIDEO. AFTER THAT JUST SAVE AND EXIT THE JUST HOLD POWER BUTTON DOWN TILL PC SHUTS DOWN THEN SWITCH YOUR CABLE MONITOR CABLE FROM THE ONBOARD TO THE AGP/PCI CARD THEN RESTART YOUR PC. THEN YOUR PC WILL SAY FOUND NEW DATA AND WILL INSTALL THE DRIVER YOU HAVE DOWNLOADED FOR IT THEN YOU SHOULD BE OK IF THE CARD IS COMPATIBLE WITH THE MOTHERBOARD
Jun 07, 2011 | MSI KT4V (MS-6712) Motherboard
When i install my video card the screen is blank
Use onboard graphics and enter the BIOS/CMOS by pressing the delete key during boot.
Go through the options, some-where there, there should be an option to enable PCI-Express slot, PEG when one is inserted. This need to be set.
So onboard VGA is disabled unless PCI-E Graphics card/PEG is inserted.
damnor01
Jan 25, 2011 | PNY GeForce 6200, AGP Video Card
PCI-E card does not work, onboard video works fine, this is the second card.
The Abit IP-95 manual doesn't show you how to adjust your bios settings when adding a PCI-E x16 graphics card. When adding a PCI-E card you'll need to adjust a few settings within, Advanced Setup.
Press the delete key on your keyboard every two seconds to load your bios menu. Within Advanced Setup look for, Onboard Device Configuration and open it. Find, Primary Graphics Adapter.
Set this to read as [PCI-E, VGA] save your changes and exit.
Currently your onboard graphics is enabled. You'll need to change this setting to PCI-E first. When you use the onboard UniChrome Pro 2D/ 3D Graphics & Video Controller you are also using some of your system memory to run the UniChrome graphics. Once you enable the bios to boot to the PCI-E card you can also stop using your system memory assigned to the UniChrome card. Link to Abit is provided below, click on it to open;
http://www.abit.com.tw/page/en/motherboard/motherboard_detail.php?pMODEL_NAME=IP-95&fMTYPE=LGA775
Cheers!
Mike
Nov 12, 2009 | Abit IP-95 Motherboard
About the size of onboard graphic
ASUS P5KPL-AM SE
Onboard-Video: Intel GMA 3100 Graphics Controller, w/ 256MB Shared Memory
Video Slots: 1x PCI-Express x16 Slot
source: http://www.smksuperstore.com/product/P5KPLAM_SE-52785.aspx Note: I quickly checked Asus's website and the manual (
http://www.asus.com/Product.aspx?P_ID=xs6iinKxu0y5agcg
) but it didn't appear to give a direct answer.
Also note that even if the motherboard supports both onboard+PCI-E, G31(GMA3100) graphics wouldn't help much at all, trust me. You'll want to buy a new PCI-E card if you plan on doing any gaming. Not knowing what game(s) you plan to play, your budget, and what processor you have makes it tough to suggest an exact video card. So, check out this site to select the best card for your budget and game play:
Best Graphics Cards For The Money
http://www.tomshardware.com/reviews/best-graphics-card,2362.html
You can definitely get a real good card for under $100. Perhaps a Radeon HD 4850. Lastly, I highly recommend you buy from NewEgg.com.
Aug 10, 2009 | ASUS P5KPL-AM SE Motherboard
My computer won't detect ATI RADEON SAPPHIRE X1550 256MB
go to bios and enable it to detect graphics cards most bios have an option for onboard only or onboard and external graphics adapters
May 04, 2009 | Sapphire ATI RADEON X1600Pro 512MB...
HOW TO DISABLE MY ONBOARD GRAPHIC CARD??
For user BIOS21 & julio1963,
How to enable you're (Add-in AGP video card) & disable the onboard, integrated S3 graphics UniChrome 2D/3D PCI graphics card.
Enter you're bios. Open you're user manual to page 3-13. Integrated Peripherals. Go to, Init display first. Set to AGP.
(Not to PCI). That is all you need to change. The MSI bios will than see you're add in AGP card & automatically disable the PCI S3 graphics, (Onboard) card.
Enjoy!
If I can help you further, feel free to post here.
Please, each user's vote this issue as a fix, if this helped you to get you're bios to see you're new AGP graphics cards.
Mike
May 31, 2008 | MSI KM4M-L Motherboard
Error code 43
What you have to do, with your monitor still plugged into the onboard, is disable the onboard controller then restart.
Your screen will go to 640x480 during this process, but no worries.
Once you've logged back in to vista, open up your device manager again to make sure that your card is now enabled. If not, enable it. Also make sure that your cards' driver sortware is updated.
Switch your monitor over to the card now. No need to power down.
Open display properties, set your dual monitor setup to default on the single monitor that you do have plugged in and reset your screen resolution... and maybe even upgrade your monitor driver from generic to specific if you want.
The issue with nvidia cards isn't with vista or nvidia at all. It's a simple matter of driver conflict between the card and the onboard chip. You just have to tell vista that you'd like to make the card the priority adapter by disabling the onboard.
However, disabling the onboard DOES NOT make it unavalable to you. You can still utilize it in a dual monitor setup as a generic adapter without conflict.
Dec 26, 2007 | Computers & Internet
PCI-express won't come up.
BIOS Setup Utility; go to Advance Chipset Features
PEG Port is your PCI-EXPRESS…Enable/Disable
Nov 10, 2007 | EliteGroup 915G-M Motherboard
Asrock P4I45GV R5 Motherboard Logo
69 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Computer Links
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
