Question about Kenmore 57029 Side by Side Refrigerator
Ice maker stopped making ice - Kenmore 57029 Side by Side Refrigerator
    President:
  • 1,218 Answers
Good day,
Lots of reasons an ice maker will quit. First, if you have a filter system, you could try installing a new filter. If no luck then follow these steps. it should resolve the problem. Be aware the freezer must be at normal temperature to function. If the freezer reaches 14 degrees or warmer, the ice maker, by design, will lock out.
First step is to take a small paper cup of water and fill the cavity until it is near full. With the ice maker turned on, close freezer door and wait 3 hours to see if it harvests. If not, the ice maker is bad, and must be replaced. If the cubes harvest then.......
Three possibilities.
1. The water supply from the house is not delivering water to the water valve. Shut off the house at the meter, disconnect the line going to the water valve, and with the line pointed into a bucket, have someone turn the valve back on for a 15 second count. The water should come out smartly. If not, the line and it's fittings will have to be replaced.
2. The fill tube from the back of the machine that feeds water into the back of the ice maker is frozen up. You will have to remove the ice maker to visually inspect that tube. If blocked, it needs to be defrosted, but use caution. Too much heat too fast will start to melt plastic and vinyl parts you don't want melted.
If this is the case, then once cleaned out, you will have to change the water valve located in the back bottom rear of the machine because it is leaking during the off cycle.
3. If everything checks O.K. up to this point, you will have to purchase and install a new water valve, and install it.
P.S. Under very rare occasions the electric circuity in the ice maker will fail to send a signal to the water valve. Although rare, it can happen, in which case the best option is to replace the ice maker and water valve.
Posted on Jul 15, 2010
Joe_Rex
  • 114 Answers
SOURCE: Ice Maker Won't Stop Making Ice
There is an adjustment for the "harvest" bar (The bar you lifted up). That bar you are lifting up tells the ice-maker that the cubes have fallen into the ice storage and starts the ice-making cycle over. It is also the Limit switch for the ice level in the storage container ... if it stays up for preset time determined by the manufacturer it stops making ice... most all ice-machines use the same devices. they vary little in design. Sometimes you can just gently bend the bar down to the point where it turns-off the machine at the level you want ... unless you can get to the adjustment hinge you can adust it there. For the fact it goes off when you lift it all the way up tells me the harvest switch is turning the ice-maker off.
Posted on Apr 29, 2007
  • 12 Answers
SOURCE: Ice Maker leaking water in freezer and won't stop making ice
The filter should be before the fridge and should not affect it it sounds like the water valve from the fridge is defective .Other possibility is the icemaker head is defective and needs changing.
Posted on Mar 10, 2008
  • 172 Answers
SOURCE: Kenmore Coldspot w/Ice Maker Not Making Ice
hi LOP7,
In most cases you can easily solve this problem.
step one would be to make sure your freezer is getting cold enough. If you have icecream in your freezer is it frozen solid or is it soft. Most icemakers cycle around 0 degrees and if your freezer is not getting to 0 then it will not cycle and it will not make ice.
Step two would be to make sure you icemake is cycling. To do this simply lift the little shut off arm on your icemaker and wait about an hour then go back to the icemaker and drop the arm down. The icemaker should start going through a cycle. You should notice the arm slowly begin to raise and the ice dispencer fingers will begin to turn. Then you will hear it call for water. You may hear a humm.
If the freezer is cold enough and the icemaker is cycling that only leaves the inlet valve. replace the valve and enjoy the ice.
If the freezer is cold enought and the icemaker does not cycle, then you have a bad icemaker. Simply replace the icemaker and viola.
Third if the freezer is not cold enought 0 defrees. Then you may have a defrost problem. In this case post more info and I will be happy to help. Good luck mca0824@aol.com
Posted on Apr 30, 2008
  • 31 Answers
SOURCE: maytag ice2o won't make ice
theharrisont,  You state that...." ice maker stopped working after it flooded our kitchen floor."  The water works because the water fountain dispenser uses a separate part of the Water Valve. The ice maker portion of the water valve is defected and the entire Water Valve Assembly will have to be replaced.  Your problem is the dual Water Valve Assembly which is located on the rear bottom area of the refrigerator (follow the water inlet line from the wall to the refrigerator...the water inlet line connects to the Water Valve Assembly).  The significant info which you provided was that the ice maker flooded the kitchen which indicates the Water Valve Assembly is defected. Failure to replace the Water Valve Assembly will result in the same problem of flooding at some later date.  Replacing the dual Water Valve Assembly is just one step of several steps necessary to correct the problem.  You will also have to temporarily remove the ice maker from the freezer (usually a couple of screws hold it to the wall and a quick disconnect electrical plug) and put it in the sink and run warm water over to remove any ice.  Before you reinstall the ice maker you must check the Water Fill Tube that dumps the water into the ice maker.  Because you said that the ice maker flooded the kitchen, then the Water Fill Tube is probably filled solid with ice which must be removed.  A hair dryer is a quick way to achieve this.  Blow hot air directly into the end of the Water Fill Tube which dumps the water into the ice maker.  Note:  Use a long screw driver to insert into the Water Fill Tube to break loose any ice and continue to use the hair dryer to help to remove any ice. This should correct your problem
If you need further help, I’m available over the phone at https://www.6ya.com/expert/henry_239f63a136de60f0
Posted on Feb 07, 2009
SOURCE: GE refrigerator ice maker model can9 stopped
The schematic to my CAN9 is cast into the front cover.
Posted on Apr 04, 2010
Why does my new ice maker only make a few cubes?
I don't think your ice maker was the issue sounds like it's not cold enough to make ice in your freezer get a thermostat and see if you are maintaining temps between 0-10F if not you are slowly losing freon somewhere
May 09, 2014 | Refrigerators
Ice maker kitchenaid super ba is not working . Chilled water dispenses but no water seems to enter ice maker.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 22, 2012 | KitchenAid Superba KSRG25FK Side by Side...
Ice maker
other ice maker related issues and solutions:---
Ice maker dispensing ice with black or white plastic pieces in ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-dispensing-ice-with-black-or.html
After replacing ice maker assembly, ice is not getting made?
http://alltypesofpartsreplacing.blogspot.com/2011/10/after-replacing-ice-maker-assembly-ice.html
Ice maker is leaking water and causing the ice to freeze?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-leaking-water-and-causing.html
Ice maker is noisy and not making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-noisy-and-not-making-ice.html
Refrigerator ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/refrigerator-ice-maker-stopped-making.html
Ice maker leaks water into ice bin causing a glob of ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaks-water-into-ice-bin.html
Amana Refrigerator leaking water from ice maker?
http://alltypesofpartsreplacing.blogspot.com/2011/10/amana-refrigerator-leaking-water-from.html
Ice maker leaking?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaking.html
Ice maker is dumping the ice cubes out before frozen solid.
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-dumping-ice-cubes-out.html
Water overflowing ice maker?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflowing-ice-maker.html
Ice cube is getting stuck up hard in ice maker
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-cube-is-getting-stuck-up-hard-in.html
Icemaker quit working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/icemaker-quit-working.html
Quit making ice
http://alltypesofpartsreplacing.blogspot.com/2011/10/quit-making-ice.html
Water leaking into ice tray, frozen glob of ice
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-leaking-into-ice-tray-frozen-glob.html
Not making ice, and water leaking in freezer?
http://alltypesofpartsreplacing.blogspot.com/2011/10/not-making-ice-and-water-leaking-in.html
The ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice_20.html
Ice maker not making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-not-making-ice.html
Ice maker quit working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-quit-working.html
Ice maker dispensing black pieces of plastic in the ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-dispensing-black-pieces-of.html
Replaced Ice maker but its still not making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/replaced-ice-maker-but-its-still-not.html
Ice maker leaked creating an ice block?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaked-creating-ice-block.html
Ice tray leaked?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-tray-leaked.html
Ice maker stopped functioning?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-functioning.html
Ice maker stop working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stop-working.html
Ice maker failed
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-failed.html
Old ice maker stopped working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/old-ice-maker-stopped-working.html
Old ice maker started leaking?
http://alltypesofpartsreplacing.blogspot.com/2011/10/old-ice-maker-started-leaking.html
Ice maker not working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-not-working.html
Ice maker overfills and cause water to flow into ice dispenser and freezes?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-overfills-and-cause-water-to.html
Ice maker didn't make ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-didnt-make-ice.html
Ice maker was leaking?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-was-leaking.html
Ice maker was leaking after it filled up with water?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-was-leaking-after-it-filled.html
These will help.
Thanks,.
Dec 21, 2012 | LG LFX25976ST - 3-Door French Door...
Ice maker will not stop sending ice out of door
If your refrigerator has a wire bar that raises and lowers as ice cubes are ejected. Make sure the bar is not trapped or frozen in the down position. This will cause the ice maker to continuously make ice.
Usually pulling the wire bar all the way up the ice maker will stop.
If not, you may have a bad switch and will need this replaced.
Oct 18, 2009 | KitchenAid Refrigerators
My refrigertor has stop making ice.
just check if the lever in the ice maker is turned to on or off,because that causes the ice maker to stop making ice
Aug 15, 2009 | Refrigerators
Amana Side-by-Side Fridge Model SBD21VPSE Problem started when water stopped flowing from in-door dispenser and ice maker stopped making ice. I emptied fridge and freezer, left unit off for several...
If there is a reset button on your ice maker try pushing it. Many ice makers have two holes for reset. A general rule of thumb is if the ice maker fingers are stopped in a slightly vertical position then your ice maker unit is working. If the fingers are stopped anywhere else then it needs some sort of attention or replaced. Make sure there is water, or ice in the ice maker tray, if not then the problem is with water supply.
Nov 29, 2008 | Refrigerators
Ice Maker Problem
my ice maker stopped making ice. Green light is on. Drinking water is ok
Feb 17, 2008 | GE GSS20IEP Side by Side Refrigerator
Kenmore 57029 Side by Side Refrigerator Logo
383 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Bailey's...
Bailey's...
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
