Question about Amana AGR4400A Gas Kitchen Range
Oven want stay on
When oven is turn on it will get hot and turn off.
  • 677 Answers
Hi, you can use this links as a guide (home.howstuffworks.com/how-to-repair-an-oven6.htm). and (appliancerepair.lifetips.com/cat/63865/range-oven-parts/index.html). Hope it helps.
Posted on Jul 15, 2010
Neff electric oven stays hot after turning off
This is normal...there is a cooling fan built in to your oven designed to cool the facial controls when hot and can take some time to cool to an acceptable temper?ture that's why you can feel the air blowing,, usually above the oven door...if you switch off at the mains you are risking the plastic components on the facial melting. Just leave it to Run it is a very low wattage motor and costs very little to run
Oct 10, 2017 | Ovens
The burners light indicator stays on even when the burners are turned off
Here is a tip that I wrote about the problem of the cooktop light staying on.
Oven Hot Surface Indicator Light stays on heatman101
Apr 23, 2011 | Microwave Ovens
The light for the right back burner stays on,even though the burner is turned off and is cool
heatman101
Dec 25, 2010 | Microwave Ovens
Last night, we were using our Frigidaire oven to heat some salmon. My wife openned the oven door and there was a bright flash with sparks and a crackling noise, and a 1/2 inch portion of the element caught...
Kill the power to the stove. L2 is always hot to the element. If it welded itself to the frame whats left of the element stays hot. Easy fix but power needs to be OFF
Apr 17, 2010 | Ovens
OVEN STAYS HOT
This is somethig you should have checked by technician.Till then turn the oven off then pull straight out on the knob removing it. use a plyers to check if it's actually turning off by turning it to the left. If it does turn to the left( off position) you may just need a new knob.
Oct 04, 2009 | Ovens
My oven does not shut off.
Hi there, this is a serious control fault that may be fixed by unplugging this unit for a five minute period. after this hard reset, plug the unit back into the wall outlet and power up. if the unit continues to stay on, you will need to replace the control(electric oven control)board.
May 18, 2009 | GE Kitchen Ranges
Oven won't stay hot
You probably need to replace the baking igniter, (Igniter,bake burner
Part Number: AP4102011 made by MAYTAG
Feb 12, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Neff U1420 oven gets hot then cools.
there are is an ignitor nest to the oven burner. that part gets red hot when you turn the oven on, but when starts to go bad it takes longer and longer time to open the safety valve that supplies gas to the burner. or i can turn on but it will not stay on it go es of again. the ignitor needs to be replace.
Dec 08, 2008 | Maytag MER5775Q Electric Kitchen Range
Oven heating element stays on
If element stays on even with oven turned off you probably have a bad main board. A relay on board is probably stuck on. If it stays on, but at a reduced heat...not getting red hot, it may be from a shorted wire causing 110 volts to get to element.
Nov 02, 2007 | GE Profile JTP18 Electric Single Oven
Amana AGR4400A Gas Kitchen Range Logo
18 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Mike Carew
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
