Question about Savin Office Equipment & Supplies
Toner light and message won't go out
Can not get the ''add toner'' light to go out. Replaced toner bottle two times. Printer will not print with the message and light showing. Tried shutting it down, unplugging it. Nothing seems to work. Savin model number 9922 DP
  • 3 Answers
Try to check the toner bottle holder.there are some patrs inside likethe bottle chuck,seals ,foam
Posted on May 23, 2012
    President:
  • Savin Master
  • 990 Answers
Hello sir; You have to replace toner senser, it located at the bottom of developer unit. have any problem please contact us, good luck!
Posted on Jul 15, 2010
  • nita51 Jul 15, 2010
    Can you tell me where the developer unit is? Is that the PCU?
Message the toner bottle is full please call the server machine printing rico 4500
The bottle full message indicates that the waste toner collection bottle is full. The full bottle needs to be removed and the toner disposed of properly. Then a replacement collection bottle needs to be installed and the waste toner counter reset. This site has the toner bottle: http://www.precisionroller.com/waste-toner-containers-for-ricoh-aficio-mp-c4500/details_47769.html . It is possible to reuse the bottles but most people will spill the toner when they try to empty a collection bottle. You do not want loose toner in your environment.
Turn off the printer (at the power switch) and wait for the lights to stop blinking before attempting the replacement. See page 62 of the network guide for the replacement procedure. See https://www.ricoh-usa.com/downloads/downloads.aspx to search for your printer and get the manuals.
I hope this helps
Jul 06, 2015 | Office Equipment & Supplies
Hi! i am using ricoh afficio MP171 SPF. i replaced the toner but it still showing the message "add toner". what can i do please?
You could check if the contacts on the toner cartridge and in he printer are clean and shiny. Perhaps just a bit of glue or a scrap of plastic is on a contact, making it impossible for the printer to read the status.
Apr 06, 2015 | Ricoh Office Equipment & Supplies
Hello - my Lexmark E120 will print a test page, but won't print anything that I send to it. I just get an error message. There is a green light next to the 'lightbulb' on the printer. The...
The light next to the lightbulb on the printer Toner low/replace PC kit. The printer is ready to receive and process data. In addition, the toner in the toner cartridge is getting low.
Solution:
? Press continue button to clear message and continue processing job.
? Remove the toner cartridge. Gently shake the toner cartridge from side to side and front to back several times to redistribute the toner, and reinsert it. Repeat this procedure multiple times. If the print remains faded, replace the toner cartridge.
For further assistance, please contact Lexmark Technical Support
Sep 12, 2011 | Lexmark E120n Laser Printer
Ricoh CL4000DN. I recharged the magenta toner using the OEM cartridge. I replaced the chip as instructed and all elements snapped together without difficulty. However, now there is a "check toner...
Hi, the chip on those toner bottles stores information about how much toner is left, so once that chip registers an empty toner bottle, it won't work even if you attach it to a new toner bottle. You'll need the chip from a new toner bottle, or one that hasn't registered no toner.
Jan 22, 2011 | Ricoh CL4000DN Laser Printer
Printer wants toner cartridge replaced, though not empty
unfortunately the drum within the cartridge has reached end of life so changing to a new drum cartridge would resolve this issue.
Mar 25, 2010 | Panasonic KX-FLB801 All-In-One Laser...
Replaced Konica 7022 toner and add toner light stays on
Remove the toner bottle carefully, pwr off and unplug the machine , then plug it in and turn it on do not put toner bottle into machine until asked for.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jun 30, 2009 | Konica Minolta Office Equipment & Supplies
Message says to add toner after I replace toner
Plunger from the top of the previous bottle is probably still stuck in the machine. Remove the toner bottle and check/remove .
Jun 29, 2009 | Ricoh Aficio 1013F Copier
Add Toner stuck on & Replace Photo Conductor Unit (PCU)
I suspect that it is the PCU causing the problem, and the message should clear once the PCU is installed and it (automatically) runs it's calibration cycle. Likely the toner auger gear has seized on the PCU, and broken. If the light does not go off after installing the PCU, then you may need a technician, as the toner motor may not be working, or there is a blockage within the toner hopper itself.....but again it is likely the PCU, especially if the toner bottle was empty when it needed replacement. Was it empty?? Did the machine work for a few days, or at least for a while? If so, it seems like too much of a coincidence that this problem would come up at this time.
Good Luck :)
Mar 18, 2009 | Office Equipment & Supplies
Replace/int tank toner error message
If the toner bottle has been cleaned, it might still be dirty on the top. If the bottle is new, the you need to clean up the light sensors that pass through the toner bottle.
Be blessed.
Sep 24, 2008 | Samsung CLX 3160fn All-In-One Printer
Add Toner
pull out hopper and remove bung of old tube from inside!.
Feb 08, 2008 | Ricoh Aficio 2022 All-In-One Laser Printer
303 people viewed this question
Top Savin Office Equipment & Supplies Experts
quennie732
Adorjani Laszlo
Don  Farrell
Don Farrell
Are you a Savin Office Equipment and Supply Expert? Answer questions, earn points and help others
