It use to be a 300bg hard drive when i brought it but every time i format it stays with the last size it use d
  • 52 Answers
Try deleting the partion then formating it.
Posted on Apr 20, 2008
Hi there i have a hitachi hard drive model HTS541680J9SA00 and have brought an external case for it but its does not fit. Do i need a specific external case at all?
I had that problem if the hard drive is full size (same size as a pc hard drive) you will need a 5.25 external case.
Nov 29, 2011 | Computers & Internet
I brought a 250gb hdd for the xbox 360. The xbox 360 says that it is a unformatted storage device, the only thing i can do is formatted the hdd. but nothing happend I have formatted the thing 5 times....
Trying to format a large external USB or Firewire hard drive to the FAT32 file system? Can't do it? Only see an option for formatting the drive using the NTFS file format? Well if you answered yes any of those questions, then you're at the right place.
I was recently trying to format my 1 TB MyBook external hard drive in Windows XP to FAT32 instead of the overly forced-upon NTFS format. Why? Well because I needed to connect it to a NAS device and the NTFS permissions were causing the NAS not to be able to access the drive. Simple solution is to use FAT32, no security, no problems. Though it's sometimes useful to format a USB drive in NTFS format.
Also, formatting a drive in FAT or FAT32 will allow it to be read by other operating systems, such as Mac, Linux, and older versions of Windows such as Windows 98.
Unfortunately, Windows XP and Windows Server 2003 will only format a removable drive in FAT32 if it's less than 32GB! Hmmm...that pretty much cuts out ALL modern external hard drives!
However, Windows can format a drive that is larger than 32GB in FAT32, but you have to use the DOS command prompt. However, if you have a drive that is 1TB or larger, you may still get an error saying "The volume is too big for FAT32".
In that case, you can use a free program called SwissKnife that will allow you to format an external hard drive that is up to 2TB in size. Let's go through both methods. In case you are having problems getting your external hard drive to show up in Windows, read my article on how to change the drive letter for an external drive in Windows.
Format external drive in FAT32 using DOSOpen a command window by going to Start, then Run and typing in CMD.
Now type in the following command at the prompt:
format /FS:FAT32 X:
Replace the letter X with the letter of your external hard drive in Windows. Windows will go ahead and begin formatting the drive in FAT32!
Format external hard drive in FAT32 using SwissKnifeSwissKnife is a nifty little program that is completely free and that you can use to format many types of external drives such as USB, Firewire, PCMIA, SATA and SCSI. You can also use it to create partitions on an external hard drive and it formats faster than Windows.
So next time you want to format a hard drive in FAT32 and Windows only gives you an option for NTFS, make sure to follow one of the two method mentioned above. Enjoy!
Mar 02, 2011 | Microsoft 20GB Hard Drive for Xbox 360
I can't format and i can't make partition and i can't excange ant thing on hard disk I make partition and format and use program PartitionMagic 8.0 and fdisk and outher programs after uses all this...
Are you sure you committed to change. Most programs don't make change till last step.
How is it formatted now? NTFS, FAT32? You cannot use old programs to change newer formats.
In windows, right click on drive letter, choose format.
Nov 13, 2010 | Seagate U5 (ST330621A) 30 GB Hard Drive
My terabytes have gone i just brought it
The reason it "lost" size is due to the limitations of the FAT32 file structure. This system cannot address the entire drive because that is larger than it knows how to organize.
You can either format additional partitions(using a PC) into similar sized FAT32 drives and make the space usable by creating 4-5 drive letter or you can format all of the remaining space as NTFS using windows if you don't need the space for the PS3.
Unfortunately FAT32 simply won't support a single drive letter that large.
Hope this helps FixYa,
Crankstart
Mar 19, 2010 | Iomega 1TB Desktop USB 2.0 Hard Drive
-Was using the laptop toshiba A40 for several hours -The computer shut off on it?s own -Upon restart the computer goes to a prompt screen asking you to choose to boot from one of the following: Safe Mode,...
it is a bad hard drive, 12 hours is too long its a slow drive therfore you just need a new hard drive (new not used from ebay) and format xp and bob is your uncle. dont think that i will try other stuff to still not spend to get a new hard drvie but it is time you cof'up lol good luck
trust me i know
Jul 30, 2009 | Toshiba Satellite L305-S5907 Laptop
I have a emachines and i want to install a new hard
windows 98 uses the FAT 32 file system and will only read up to 127GB. You could format the drive and divide it into smaller sections and windows should be able to read it fine. Either 2 sections of 80GB each, or multiple smaller sections.
-Download and use the updated FDISK.EXE utility program from Microsoft.
-Keep your partiton size for the Primary partiton that is to be used for drive C: to 127GB or less.
-Use the Windows 98 FORMAT.COM utility program. Note that while the prgram is running it will display an incorrect size for your partition. After it has finished, the summary screen will show the correct size that was formatted.
Formatting large hard drives is extremely slow. If you have a disk setup utility that came with your new hard drive, use it instead of FORMAT.COM. This can save you HOURS of waiting.
Dec 31, 2008 | Western Digital WD1600AB 160 GB EIDE Hard...
Pen drive memory insufficient
cheeck virus with an updated virus cleaner.
Nov 12, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
HardDisk
Just continue in formatting the hard drive because this can be cause by some malware that's why your hard drive is just showing that size and after you format it everything will be clean, the other reason why the hard drive is just shwoing that small size even though its a big size there's a possibility of bad sector on the hard drive so don't use the quick format when you reformat the drive so the bad sector will be fix also...
Oct 14, 2008 | Western Digital Caviar SE WD1600AAJS 160...
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
