Computers & Internet Logo
Posted on Jul 15, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Video files clogging hard drive
I have a lot of video files taking up space on my hard drive, what's the best solution for saving space/compressing them, most are FLV and MPEG-4
Lee Hodgson
Level 3:
  • Master 4,810 Answers
  • Posted on Jul 15, 2010
Lee Hodgson
Master
Level 3:
Answers
4810
Questions
Helped
1781661
Points
15941
Your best bet is to back them up to an external drive or a DVD really. You could compress them but the quality of them are reduced so you'd end up un-compressing them again to get a decent watch.
With an external its plug and play. With a DVD you would need to file them in some kind of order and they take up space.
Regards.
Anonymous
Level 2:
New Friend:
  • Expert 60 Answers
Anonymous
Expert
Level 2:
New Friend:
Answers
60
Questions
0
Helped
8578
Points
166
If they are video files, movies and the like, the best way is to burn them to a disk and then simply delete them from the drive.
4answers
IPhone 6 out of space for pictures
Down load to a laptop or PC then you can save them on a disc, sd card or thumb drive. After that is done you can delete all pics from iphone
Oct 13, 2015 • Cell Phones
How do you retrieve raw files from external hard drive? What format are they in? Will they be the same quality?
Files are Files are Files. The .raw file type is just a specific method of saving data with a lot of information. The .jpg's are a much more compressed version that really save a lot of space, whether it be on a hard drive or memory card.
You should be able to use your external drives much like a memory card or internal hard drive. You should be able to move files from one drive to another, deleting or copying files wherever you feel necessary. There will be no loss of quality if you move a file from point A to point B.
How can I save on multiple profiles
My best guess, (I have not encountered it in the PC version) is that it is relatable with your hard drive, space, and file size. It could be your hard drive out of memory or running low?
A key question is it available on the first but not the second?
If it is then it definitely has to do with the accounts and for some reason the second one is being denied access along the line (Im guessing you installed via the first account).
Sometimes save game files take up a large amount of space and if you have played a lot already then it may be affecting your game in some manner and restricting you someway.
See if you can delete older save files if you are willing to part with them as well as changing permissions between accounts or reinstalling the game as a last resort.
2answers
Disk full error on file save...
It seems that you Hard Drive is full. You may either choose to upgrade the Hard Drive, or you can compress or even delete some of your data. There are also programs that will search for duplicate files on your system. This website is one example of that. http://www.easyduplicatefinder.com/
I hope I answered your question. Have a great day.
2answers
My d drive says it is 99% free space but it has 4.53 gb how do i get more gb
Your D drive is usually for system restore. Insteed of system restore disk the manufacturer will partition a drive and place the installation data in the D drive. You should have a C drive and this is where you want to focus on. Delete unwanted pictures , music, and other unwanted files. Movies will really use a lot of drive space.
2answers
Does storing a lot of pictures on my PC cause it to run slower?
It could, depending on how large your hard drive is. Side note, if these are important, back them up so you won't lose them.
One way to save space is to put your hard drive in a compress mode.
Go to start, computer, select the hard drive, right click then under properties click the box that says "compress to save space". It will save space and also help it run faster.
2answers
I am losing hard disk space What can I do Thanks
1- Do hard disk cleanup - This will help you remove hidden files and folders
2- Move or delete old videos and pictures
3- Compress some old files
Not enough sdram, everything very slow loading what to do to add more ddr sdram?
1. This may not be extra ram being needed
this may be a virus or you have loaded your hard drive and will need to clear some files and programs may be needing a lot of space.
2. You may have to many Mp3 file stored or videos. Videos and music Mp3 files take up a lot of space on the hard drive and can potentially lock the hard drive.
3.You the utility in Windows to clear some hard drive space. Found in the "accessories" then System Tools >.then "disk cleanup" This is for Windows XP.
Windows 7 is totally different but basically the same principal.
I hope this helps. Have a great day
1helpful
3answers
My lab top hard memory is parted in c and d and I am running out of space in c drive. How to put them together
1. Go to the Start menu and open Control Panel
2. Select the System and Maintenance option if you are using the Control Panel Home View and Administrative Tools if you are using the Classic View
3. In the Administrative Tools section, select Create and format disk partitions.
4. For Classic View users, select the Computer Management option and select Storage. When done, click Disk Management
5. When the list of your drive is displayed, choose the one with which you want to merge your partitioned drive with (e.g. disk D:) and select Delete Volume.
6. Hence, select your drive C: and the option Extend Volume. You computer will automatically select empty available spaces on your hard disk, and you can alter them if you wish to do so.
Regards.
Filesize query
It's probably not out of line. A one hour minDV holds about 13.5 gigs. AVI files need a LOT of space. Yes, it will be compressed before it goes to DVD, but compression (also called rendering) usually isn't done during the capture process. How much hard drive space do you have? You probably need more.
Grand Canyon Tech
Grand Canyon Tech
