Question about Kenmore 95023 Stainless Steel Electric Kitchen Range
Kenmore E1 F2 Stove Fault
My stove is showing fault E1 F2 on the digital read out. Turned power off for 30 Min, and the rror returned in about a day. What dose it want from me?
    Scholar:
  • 61 Answers
You probably don't need to replace any parts to solve this problem. E1 -F2- = the keytail (connector ribbon) that plugs into the control board is not making good contact. first unplug your range and then remove the two screws on the underside of the back-splash controls panel to access the back of the control board. now simply cut a slip of heavy paper such as a business card to the width of the ribbon and slide it into the slot along with the ribbon connector. that will help press the contacts on the other side together snuggly. screw the back-splash back in place, plug in your range, and the problem might vanish. if the error code returns, try pulling out the connector, cleaning the contacts with a pencil eraser, reinserting it into the slot and repeat above with the paper.
the paper trick worked for me for about two weeks, then the problem happened again. the next fix I tried was to unplug the keytail (the ribbon connector) from the slot on the control panel. there is a clip in each side of the black plastic receptacle (the place where the keytail plugs in on the electronics control board). pres them inward to separate the top portion of the receptacle, which I think helps to clamp the keytail into the bottom portion. the top and bottom fit tightly together, so you might need to use a small screwdriver at the joint to pry them apart, however, I did not find it necessary to remove that clamp in order to remove or replace the keytail on mine.
smoke and other sticky cooking fumes cling to the contact wires on the keytail and the pins in the receptacle (as well as other surfaces) and that buildup interferes with the electrical connection they need to make. once the keytail is free, clean it well with a mild cleanser (I used a slightly soapy, damp dish sponge) and dry it with a clean paper towel. FYI, one side of the keytail has the exposed wires which make contact with pins in the receptacle on the control board. the exposed side is on the inside surface of the curled keytail ribbon, the outside surface is translucent plastic insulation (you can feel that the outside is smoother than the inside because the inside has the contact wires exposed). the inside is the side you want to make sure is clean because those are the wires that need to make electrical contact with the pins in the receptacle.
next, use sharp scissors to carefully trim a small uniform strip (roughly 1/16 of an inch or less) off the end of the keytail. then plug it in again (remembering to use the top portion of the receptacle to secure it in if you had removed it). doing this provides a fresh spot on the exposed wires to make contact with the pins in the receptacle. my theory is that over time the wires wear out at the points where they make contact with the pins. trimming the edge allows you to insert the keytail deeper into the receptacle and therefore, the pins will contact the wires in the keytail at a new, unworn spot. it's been over a week now and so far, it seems to have fixed the problem on my stove. if I get the error message again in the future, my next step will be to try paper trick again (at least as a temporary solution), but I doubt it will be necessary any time soon.
be sure to try all other solutions first before ordering any parts. I first changed the control board for $125 and there was no change. then I ordered the touchpad, but ended up fixing the problem before it arrived. I sent the touchpad part back to Sears Parts Direct after I figured out I didn't need it and they eventually refunded $15 less than I'd paid. of that difference, $13 and change was for shipping, so the other dollar plus must have been a miscalculation or a restocking charge or something, but I didn't bother following up to find out. I also had to pay about $3 to ship it back to them via USPS because I didn't hear the UPS guy when he dropped it off on the doorstep, so I wasn't able to simply refuse the delivery.
good luck with your repair.
Posted on Nov 18, 2010
  • 15,935 Answers
F2-E1 - Touch Pad (Keypad) Cable Unplugged -
Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
Select the 'cancel' function and wait 60 seconds.
If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
It appears your timer/clock has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&&&&
Posted on Oct 01, 2010
Tip
Whirlpool oven, stove and range fault codes (ERC and EOC display errors).
Here a list of Whirpool oven fault codes. The codes had been collected from different service manuals. This was a memo that I wrote for my own use. I think this can be useful to owners and technicians.
WHIRLPOOL - most models
Range/Stove and Oven Fault Codes, Common error codes.
F1 - Analog control board Failure
Disconnect for one minute - if error comes back, replace control board
F1 - Shorted control keypad
Replace keypad
F3 - Oven temperature sensor open
Replace oven temperature probe
F2 - Oven temperature sensor shorted
F3 - Oven too hot
F3 - Clean temperature too hot
Replace oven probe
F5 - Door latch switch fault
Test and replace the door switch.
Whirlpool with 4 Digit Failure Code:
F1 - E1 - Electronic control (flip flop)
Replace control board
F2 - E0 - Shorted control keypad
Replace keypad
F3 - E0 - Oven temperature probe open
Replace temperature probe
F3 - E1 - Oven temperature probe shorted
F3 - E2 - Oven temp too high
F3 - E3 - Clean temp too hot
Replace temp. probe
F5 - E0 - Check door latch
F5 - E1 - Check door latch
Replace switch if defective
WHIRLPOOL Polara models 5 digit codes:
F1 F0 - EEPROM communication error
Replace ERC
F1 E1 - EEPROM checksum error
Replace ERC
F1 E2:7 - UL A/D errors
Replace ERC
F1 E4:2 - Model ID error
Reinsert keytail.
F1 E6:0 - Latch signal mismatch error
Replace ERC
F2 E0:4 - Shorted key error
Replace keypad assembly
F2 E1:3 Keytail unplugged
reinsert the keytail
F3 E0:5 Top oven sensor open
Test and replace top probe.
F3 E1:6 Top oven shorted
Test and replace temp probe
F3 E2:9 Bake range over temperature
F3 E3:8 Clean range over temperature
Test and replace temp probe.
F3 E4:10 Bottom oven sensor open
F3 E:15 Bottom oven sensor shorted
F5 E0:14 Door switch errot
Test and eventually replace door lock switch
F5 E1:16 Door latch not operating
Test and eventually replace door latch
F8 E0:17 Refrigeration error
Test the cooling module.
PF Power failure - Does not indicate a fault.
PF occurs when power is disconnected.
WHIRLPOOL
Models SF3, 30'' and 24"
F2 - Oven temperature above specifications
Check 8-pin connector from temp. probe to Electronic Oven Control
F3 - Open oven temperature probe failure
Check wiring, replace oven probe if necessary
F4 - Shorted oven temperature sensor failure
Check wiring harness, replace oven temperature probe if necessary
F5 - Push button stuck or faulty
Check for binding of pushbuttons and control panel glass. If OK, replace touch panel
F6 - Electronic control logic error (timing)
Replace Electronic Range Control (ERC)
F7 - Electronic control logic error (lock motor)
Replace ERC.
F8 - Electronic control logic error
Replace ERC.
on Jan 31, 2010 | Whirlpool RBS305PDS Electric Single Oven
Kenmore electric stove model 95012102 displays EO-F2 the cooktop works.
that code is a bad touchpad.
F2 - E0 Shorted keypad (also called touch pad) 1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Read more: http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#Sears / Kenmore Fault Codes#ixzz1cHA0Nn50
Oct 30, 2011 | Kitchen Ranges
Where my clock was on my stove a E1 F-5 came up and my oven won't work now. The top burners are working but the oven won't. We don't have a manual for troubleshooting. Can you help me?...
F5 - E1 Self clean latch will not lock
2. If door not latched:
  1. Disconnect power from unit.
  2. Check wires and connectors from control to latch switch, then from latch switch to control. If no damage to wires and all connectors okay, proceed to step C.
  3. Repeat steps A and B for door switch
Read more: http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#GE Range / Stove / Oven Fault Codes#ixzz1cwlkkZwU
Read more: http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#GE Range / Stove / Oven Fault Codes#ixzz1cwlaiwL3
Sep 04, 2011 | Kitchen Ranges
My oven when turned on goes to F1 and the heat is like broil...only the top burner comes on????
Hello,Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
May 28, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Whirlpool Accubake F2EO
F2E0 is shorted key pad. You will need to replace keypad if the power shut down and reset does not work.
Mar 09, 2010 | Kenmore 95002 / 95004 Electric Kitchen...
66993 pizza oven microwave oven combo pizza oven not heating error code f1 microwave part works
Hello, please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
Thanks
Jul 20, 2009 | Kenmore 63662 / 63664 / 63669 Microwave...
E1 and F5 are on digital read out instead of 500degrees and cleaning
The E1 and F5 is a code that the door latching system is creating a fault. YOu might be able to take apart the door latch mechanism, and recondition it.
Apr 26, 2009 | Kitchen Ranges
My kenmore oven is beeping and will not stop. the display shows F-1.
Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error.
Dec 16, 2008 | Ovens
My kenmore electronic stove is having a beep with code F1 on the
Dec 15, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore 95023 Stainless Steel Electric Kitchen Range Logo
436 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
