Question about John Deere 3010,3020 Tractor Basic Carburetor Repair
I am looking for a diagram of la 140 carburetor. my mower will only run if gas is poured into carburetor.
    President:
  • 1,627 Answers
Sounds like you may need to remove the fuel line from the carb that comes from the tank and see if you have fuel coming out of it.If you don't,try blowing back through it to see if you have a blockage[remove the gas cap first].If you can't blow back through it then you either need a filter,a fuel line or the tank is plugged.If you did get gas to the carb the you need to take the fuel bowl off the carb ,pull the needle pin out and then clean the needle and seat.If none of the above works then soak the carb in carb cleaner for several hours and then clean the carb with brake clean and you should be good to go.If nothing works try a new carb.
Posted on Jul 15, 2010
Como encender mi cortadora de cesped
1. Make sure it has gas
2. Move the carburetor lever to the "choke" position
3. Switch the ON/OFF switch to ON
4. Pull the pull-string fully out, very quickly
5. If it starts, then quickly move the carburetor lever back to the "run" position, so that you won't flood the engine
6. If it tries to start, then it stops while the carburetor lever is still in "choke" mode, then the engine may be flooded. To remedy this, move the carburetor lever back to the "run" position and pull the pull-string again and again until the excess gas burns up, and the lawn mower starts and keeps running
1. Aseg?rate de que tenga gas
2. Mueva la palanca del carburador a la posici?n "estrangulador"
3. Encienda el interruptor de ENCENDIDO / APAGADO
4. Tire de la cuerda de tiro completamente, muy r?pido
5. Si se inicia, mueva r?pidamente la palanca del carburador a la posici?n de "marcha" para que no inunde el motor
6. Si intenta comenzar, se detiene mientras la palanca del carburador a?n est? en modo "estrangulador", entonces el motor puede estar inundado. Para remediar esto, mueva la palanca del carburador a la posici?n de "marcha" y tire de la cuerda de tiro una y otra vez hasta que el exceso de gas se queme y la cortadora de c?sped comience y siga funcionando
Apr 13, 2018 | Computers & Internet
Briggs and stratton 650 series mower starts but cuts off Replace spark plug and put oil in It is a self propelled mower
be sure the oil level is not over the full mark. the plug is good? try to pour some gas in the carburetor, if it starts and runs a few seconds i would say the carburetor if plugged and needs taken apart and cleaned real good
Aug 13, 2016 | Garden
Troy-bilt mower will not start. If I put gas directly in carburetor it will start but appears to not be getting fuel.
Darlene, if it will start with gas poured in the carburetor. it is fuel relater. take the carburetor off clean it real good and it should run as good as new.
Jun 03, 2016 | Garden
John deere lawn tractor rx 95
carburetor needs cleaning. sounds like the Needle valve is not doing its job
Apr 22, 2014 | Garden
Lawnmower carburetor problem.
Remove carb float bowl. Check float operation. Float down gas flow, float up no gas flow. Clean float bowl. Observe bowl screw, see if there is a hole or holes thru the screw. Clean out with thin wire, bread wrapper works peeled back about an inch. Use wire to clean out center port of carb. Remove mounting pin of float, remove float and meter needle, clean out port up thru carb with wire. Reassemble try to start. Prime at least 3 times, ensure primer bulb is not cracked, replace if cracked. Replace air filter if dirty. Replace spark plug once a year. Fill oil. 30w. Mowers now have a low oil cutoff.
Jun 14, 2013 | Garden
Power washer wont run
What make and model?
Jun 08, 2013 | Garden
Murray riding mower will not start. Bought and installed new Champion spark plug, bought and installed new battery. Had fuse checked and it is fine. The mower sounds like it wants to start but will not...
This could be several issues. The most common is gum from the gas building up in the carburetor. To eliminate this as a problem pour a small amount of gas directly in the Carburetor. To access this you will need to remove the air filter. while cranking the mower after doing this "feather" the choke a little. These carburetors get gummed up very easily if left sitting for any period. it could be a matter of bad gas in the tank or possibly water moisture from condensation causing the issue as that will settle to the bottom of the tank and stop the mower from starting. Look in the tank and see if you have what appear to be dark colored blobs in the bottom of the tank, if you do that is going to be part of the issue. If the motor starts when you pour gas in directly in the carburetor the problem is most likely a need to rebuild the carburetor or with the fuel.
Jul 23, 2011 | Garden
Try to start mower and turns over but wont start unless you pour gas in carb then it will start and run fine. 1648s scotts mower with a kohler motor.
Does it continue to run after you start it by pouring gas into the carburetor or does it die again?
If it continues to run, it sounds like your choke is not working. Probably disconnected -- check linkage.
May 05, 2009 | Garden
How do you get to the carburetor in a Yard Man
Take off the air cleaner an pour in a tablespoon of gas, if it runs for a couple seconds, then you have a carburetor problem. If not, maybe spark plug problem.
Apr 05, 2009 | Garden
Not getting gas to combustion chamber, leaking gas from exhaust
Definitely the carburetor. Take it off and look for something clogged. Look carefully at the gaskets. Look for water and dirt in the float bowl.
Nov 23, 2008 | Craftsman 20 Hp 42" Deck Lawn Tractor
John Deere 3010,3020 Tractor Basic Carburetor Repair Logo
591 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
