Question about E-Flite Blade mCX RTF EFLH2200
Blade mcx lvc activates at random intervals sometimes in less than 30 seconds with charged battery. replaced both motors. same symptom with multiple batteries.
Pro has a full charge. Why won't it stay on?
This is most likely caused by your laptops' power management settings. Those specific settings may currently be set to conserve "maximum power and battery life" and thus turns off the display (biggest consumer of power) at specified intervals of non-activity detection. Example: it may be set to turn off the display every 30-45 seconds if there is no detected user actions.
Check your settings! Adjust and override to your liking. Just remember, the longer the display stays on (or active - full color and brightness, etc.) the faster the internal power source (the battery) will be depleted.
Sep 05, 2015 | Computers & Internet
Nikon f3hp shutter is getting stuck for random intervals of time
Water damage to the shutter speed dial, or poor contact in its flex connector, can cause this.
Nov 11, 2014 | Nikon F3HP 35mm SLR Camera
Electric current shock
If you have just purchased this laptop then return it to the shop and ask for a warranty replacement. Do not try to repair it yourself as you may void your warranty.
Apr 28, 2013 | ASUS Computers & Internet
Mini 1012. new battery. charger led working, battery wont charge. when plugged in charger works for about 30 seconds
Seems like you may have purchased the incorrect battery or they shipped you one that is NOT for your unit, if you purchased an "aftermarket" battery this could be the issue. Not saying aftermarket parts are bad, they are just massed produced and sometimes you get a bad one. Return it for refund or replacement. Try E-Bay for a reseller for this product, much less cost.
Jan 28, 2013 | Dell Inspiron Mini 1012 Netbook...
How do you reset remote for w75 wireless trolling motor
Its very easy:
Reprogramming the Wireless Foot Pedal or RemoteNOTE: This activation procedure applies to the foot pedal and remote.
IMPORTANT: To activate multiple foot pedals or remotes, the motor must be unplugged from the power source and then plugged
back into the power source between activating each control device.
1. Unplug the battery cables from the power source. Wait 30 seconds and then plug the motor into the power source.
2. In less than ten seconds, press and hold the "+" and "-" buttons on either the handheld remote or the foot pedal controller
simultaneously.
May 07, 2011 | MotorGuide STANDARD MOTOR REPLACEMENT...
When you turn the laptop on it turns off with 30 - 60 secs.
You may have a DC connector problem:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
Feb 06, 2011 | Acer Aspire 5735 Notebook
Unit will not power on// has a solid amber light// turns green for about 3 seconds then back to amber
You may have a bad DC connector:
If your laptop is out of warranty, then you can fix the problem by resoldering DC-IN jack on the system board. If it
Dec 17, 2010 | IBM ThinkPad T20 2647 Notebook
On start up the lap top starts to come on and within 6 seconds it switches off and not even the screen comes on?
Do you have it plugged in? Also, do you know if the battery is charging? You may have a bad DC connection.
Problem symptoms:
  1. Laptop randomly shuts down without any warning.
  2. Power LED and battery charge LED start flickering when you wiggle the power cord or the AC adapter tip on the back or your laptop.
  3. The battery will not get charged.
  4. When you plug AC adapter, the laptop appears to be dead and there is no LED activity at all (DC-IN jack on the system board is broken).
The DC connector needs to be resoldered on the system board.
Dec 08, 2010 | HP Compaq nc6000 Notebook
TV turns off at random intervals.
99.9 % this problem comes when x'tal malfunctions just heat the x'tal of CPU and see if it works replace the x;tal.
Aug 07, 2009 | Sony KDF-E55A20 55 in. LCD Television
E-Flite Blade mCX RTF EFLH2200 Logo
52 people viewed this question
Top E-Flite Toys Experts
ray gallant
Are you an E-Flite Toy Expert? Answer questions, earn points and help others
