Question about Samsung HCM5525W 55" Rear Projection Television
Can u send me a (full size) picture of a hcm5525w
I need a picture
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 242 Answers
Check google
Posted on Jul 15, 2010
When i save the picture that received from mms, i was not full to the screen... what should i do? in the setting i already set it on 1600 x 1200... but the picture i received still small....
you might have to enlarge it before you send it at the right size if you are unable to enlarge it once it has been received on your phone
though some mms message can only be sent at a certain size
hope this helps
Nov 12, 2011 | Nokia 5130 Cellular Phone
Samsung HCM5525W - Picture pulses slightly
It sounds like a filter cap is out or a resistor has gone o/c. check the circuit around the sub deflect board and anything that feeds it sometimes when convergence boards go they also take out a smaller component that is linked with the deflection. In this case the capacitors need to be tested or looked at for any signs of venting.
Jan 06, 2010 | Samsung HCM5525W 55" Rear Projection...
I have a Samsung HCM5525W that distorts horizontally across the top and bottom after it has been on about 15min. Center of picture is fine.
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
Dec 25, 2009 | Samsung HCM5525W 55" Rear Projection...
Blue gun out of focus
There is a manual focus adjustment above and between the red and green gun, located in the front of the TV behind the panel; It is a small black box about 3X3" . This has all three adjustments .
Apr 21, 2009 | Samsung HCM5525W 55" Rear Projection...
Motorola z3 , cant recieve picture messages
any photo you take with your phone can be sent, the 1600x1200 pixel photos are the largest this phone will take which is a 2.0 megapixel photo, when you send these, your internet provider will require them to be a certain size, for instance tmobile will require that the photos are 640x480, so your phone will resize them, before they are sent via mms. If you send them by bluetooth directly to someone in range they will be the full 1600x1200 pixel size or what ever size you take. Recieved photos must be this size or less and JPG format for them to be viewable on your phone... if they are larger they will not be recieved , this is normal. due to size constraints.. let me know if you need any further help... :-)
Dec 09, 2008 | Motorola Mobility MOTORIZR Z3 Cellular...
GETTING NO RED IN PICTURE
This is very common. The cable from the cable comp. are not good. Replace the cable with one from the store that you can go buy.
Nov 11, 2008 | Samsung HCM5525W 55" Rear Projection...
Samsung hcm5525w rear projection tv
Extensive analysis revealed this unit to be for 120V 60Hz regions. If you use it in a region where the mains supply is 220/240V 50Hz then it won't work. In addition, the PSU will overheat, with possible damage to other modules.
One possible solution is a 120V 60Hz inverter, else Samsung may be able to provide the correct PSU for 220/240V.
Jul 14, 2008 | Samsung HCM5525W 55" Rear Projection...
Picture not perfectly clear
your convergance ampliers have gone bad and need to be replaced along with some resistors and/or pico fuses. the repair my cost you about $350.00. this is the most common failure in rear projection tvs
Feb 20, 2008 | Samsung HCM5525W 55" Rear Projection...
42 inch olevia
If you're sending an HD signal to the tv use either 1:1 or Aspect viewing modes.
If you're sending an SD signal you'll not be able to get a full screen view unless you use zooming.
Dec 04, 2007 | Olevia LT42HVi 42 in. LCD Television
Help with my mms
sir i don't think if i can help but all i know is that when sending mms, a file you send must be aproximately 100kb. or if not try to master reset the phone, not master clear it will erase all the data, to set default the settings. last reactivate your mms settings maybe its not configured properly.
Nov 21, 2007 | Samsung SGH-D600 Cellular Phone
Samsung HCM5525W 55" Rear Projection Television Logo
54 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
