Question about HP Officejet Pro L7580 All-In-One InkJet Printer
I am trying to scan from a HP Officejet Pro L7580. I am a bit of a technophobe and the printer is telling me No Scan Options Refer to device documentation which I havn't got. PLEASE advise me on how to overcome this. Many Thanks. johnson.n3@sky.com
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 123 Answers
Hello Mr.Johnson !
You can start a scan from a computer or from the control panel.
To use the scan features, your device and computer must be connected and turned
on. The printer software must also be installed and running on your computer prior to
scanning. To verify that the printer software is running on a computer running
Windows, look for the device icon in the system tray at the lower-right side of the
screen, near the clock. To verify this on a computer using the Mac OS, open the HP
Device Manager, and click Scan Picture. If a scanner is available, it will launch the HP
ScanPro application. If it is not available, a message appears to let you know that a
scanner was not found
Here you will find a link that will take you to this printers service manual (device documentation) :
http://h10032.www1.hp.com/ctg/Manual/c00863866.pdf
Hope this can help you
You can contact me directly on:
eliteprintersolutions@gmail.com
Good Luck
Posted on Jul 15, 2010
Scanner function will not work.error message--"no scan options". have reinstalled software plus downloaded software from hp website.
Cobbled together a MS scan option that works with the L7580. Not very seamless but I'm scanning, viewing, saving and emailing OK.
Still wish I could get the darn L7580 to work via the "scan" button!
John Boggess
Jan 05, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
No scan options prints and copy's ok runing vista
on hp solution center , we need to do some settings..
open hp solution center..> click on settings >
go to scan button settings.. >
add all the options to the right side. > press ok..
try to scan ..
Nov 06, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
When I try to scan, it reads "No Scan Options".
Try scanning from the solution center. If successful, check the scan button settings if you can see applications available on the 'Destination List'. Add all the application to the right side. Close the solution center and try to scan.
Mar 23, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Scanner Issue
First you have to do a Level 3 un-install. Do this by inserting the original disk that came with the printer.
go to "start" then "run" then type
e:\Util\CCC\Uninstall_L3.bat (or whatever drive you put the disk in)
This will uninstall the program completely from your computer.
Go to hp's website and download the hp basic feature package for IT professionals. Open the readme file and follow the instructions to install the program from the command line. Make sure your anti-virus software is turned off!
I just did this yesterday. It doesn't install a huge program on the computer that really slows it down. Plus it doesn't install all of the useless **** like customer participation program and **** like that.
You will be able to scan directly from Microsoft Word or any other program that has a scan feature. To scan from word (2003) go to "insert" then "picture" then "from scanner or camera" and follow the prompts. It works perfectly for me now. This was after many, many months of having the same problem you are having.
Aug 04, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
I have an HP Officejet pro L7580. I called tech support a couple of months ago and they had me reset the printer. I'm have similar problems and need to reset it again and can't remember how. It had...
My officejet L7580 is brand new but when i want to scan anything it tells me there are No scan options.  Refer to device document what does this mean
Jun 30, 2008 | Office Equipment & Supplies
scotti444 ,
hi! try this solution for your problem.tnx
Follow these steps to correct the problem:
  1. Open the HP Director/Solution Center software.
  2. Click Settings , click Scan Settings and Preferences , and then click Scan To....Setup . The Button Settings window will appear.
  3. The Destination List tab should be visible. The software will scan the computer and determine what scan capable programs are installed on the computer. These will be listed on the left side.
  4. Select a program you wish to scan to and then click Add to move it to the right side. Programs listed on the right will be available as scanning destinations when pressing the Scan button.
    Figure 1: Destination tab of the Button Settings
5. On the Scan To Button tab, you may also specify what type of scan you wish to launch from the front panel and establish a default scan resolution and color depth setting.
6. Click OK to save the changes and exit the setting.
Causes:
>This error message occurs if the Scan To settings have never been set.
hope this can help you resolved your problem
regards,
coffeebeans
Mar 15, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
Getting error when trying to fax or scan
The L7580 is not meant to be set up as a scanning device on a network. This unit can only function properly as a USB connected device to have all the features work. Also, for the software to install with out problems, all other All in One software fro previous HP printers need to be removed. Once we did that and did clean install using USB only then did it work.
Mar 03, 2008 | HP OfficeJet Pro L7580 Color All-in-One...
HP Officejet Pro L7580 All-In-One InkJet Printer Logo
245 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
