Question about Ulead Videostudio 8 for PC
No sound and green and purple blurred picture
I cannot get this easycap thing to work. i try to capture video, but the picture is purple and green and so blurry that you can't tell what you're looking at. the audio doesn't work either. I've uninstalled it and reinstalled and nothing has changed. please help, i only have a couple days to get this thing working.
  • SamSJ Jan 25, 2009
    I have the same problem too...... its green purple, and no sound
  • Anonymous Feb 04, 2009
    i have the same problem ... =(
I think the problem may be that you are using USB1.1 this device needs USB2.0 port
Posted on May 14, 2008
How To Install EasyCap On Windows 7
easycap was not meant to used on windows 7 (i think). but i have uploaded all my easycap drivers for you,.... as always right click exe's and in compatibility mode for windows xp service pack 2. if it still not working after driver install go device manager try update drivers from there.
easycap reccomend - ulead video studio for video editing.
the rar file has no passwords. easycap driver and stuff
Apr 22, 2016 | DekCell EasyCap USB 20 Video Capture...
Driver for easycap video capture device
hi,the easycap is a plug and play device ( it dose not need drivers ) but there are many copy's of this device out there ( very cheap ) and they are very difficult to get the sound working ( is this your problem ? ) there are many video capture software out there and most video players will capture your video. depending on what software you get will depend on how difficult it will be to capture sound. so to sum up all you need is a video capture video player ? ( windows media player/webcam max/VLC player etc )
Apr 24, 2015 | DekCell EasyCap USB 20 Video Capture...
Windows7 64bit & EasyCap directions
In my experience with the Easycap software the quality of sound & vision is very poor. My recommendation is as follows:
1) Use windows movie maker instead to capture video.Use the 2M byte/sec capture rate. Make sure the box for "make video clips" is NOT selected - you probably don't want your vid chopped into little bits.
2) In my experience USB audio is rubbish on these devices, so instead connect your PC or laptop audio LINE IN to your sound source. Don't forget to set sound source in RECORDING section of Control Panel Sound devices to Line In instead of your Easycap (which the Easycap drivers would have preset it to by default).
Good Luck.
May 17, 2014 | DekCell EasyCap USB 20 Video Capture...
Where I can download the driver for and easycap video adapter that I bought but the CD came corrupted
Hi,all you need is in this link.This works for xp,vista and windows 7 32 bit and 64 bit.
One thing unplug the easycap 2.0 before tring to install and a reboot will be required,all software is located at the bottom of the page (web link "firebird")Hope I've helped and please don't forget to rate
http://www.fixya.com/support/r4954235-windows7_64bit_easycap_directions
Nov 10, 2010 | DekCell EasyCap USB 20 Video Capture...
Hi, when trying to capture video with easycap two things happen. Either a message comes up that driver is not installed or device is not connected or secondly that Ulead has developed a problem and has to...
The following link gives you a collection of drivers for the EasyCap USB 2.0 adapter. Just choose the one for your operating system. The STK1500, which is actually the STK1600, works fine with Windows 7 32 bit.
http://escalalibre.com/descargas/AllEasyCAPDriversIFound.rarI
Jul 22, 2010 | DekCell EasyCap USB 20 Video Capture...
Easycap
I had the same problem and found that if I went into the options and chnged the format from NTSC to PAL and then back to NTSC it would bring in my camera. Thanks to snrobby for the hint on the options idea.
Sep 04, 2008 | Ulead Videostudio 8 for PC
Cannot get sound or colour to work
Sound:
I had exactly the same problem and solved it by updating the drivers for the USB sound/audio device.
My XP version is in Swedish so I´m not sure what it says in English, but it should say something like the following.
Go to the "Device manager" by right clicking on "This computer" and choosing "Properties", locate the "USB sound/audio device" under the "Sound, Video and Game"-category and right click and chose "Update drivers". Then chose "Search for drivers on the internet" and chose "Recommended installation".
My new drivers are called "USB EMP Audio Device". They work perfectly. Of course you have to chose these drivers under "Options/Input source".
I wasn´t able to update the actual EasyCap video adapter, but it doesn´t seem to matter if you´re having problems with the sound.
Video:
Click on "File", then "Preferences" then "Capture" flap, check the "Allow access to capture device´s settings" box, click "OK". Go the the "Capture" flap in the main window and chose "Capture video". Now you should see "Options", click and chose "Capture properties", then "Video capture filter", click "Properties" in the same window and the chose the correct "Videostandard", for example "NTSC" for USA and "PAL" for Europe. Try all of the alternatives until you get a picture.
Make sure you have chosen the right input source under "Options (see above/Input source". Chose Composite or S-video (you´re likely using composite). I can´t use an S-videocable, only a videocable, otherwise the picture turns black and white.
Now you should see something, if not, maybe something went wrong when you installed the drivers/software.
Hope this helps!
May 15, 2008 | Ulead Videostudio 8 for PC
Ulead Videostudio 8 for PC Logo
374 people viewed this question
Top Ulead Computers & Internet Experts
d3yavu3
Alun Cox
Karan Sethi
Are you an Ulead Computer and Internet Expert? Answer questions, earn points and help others
