This is a very common complaint and usually not a cheap fix.
The problem is the analog water level switch is clogged or failing. You will need to remove the top cover. The switch is a small rectangular box with a group of wires going to it and also a hose. First check that the hose is clear and free of obstructions do this by blowing thru it. If all is clear and f35 or suds pops back up you will need to replace the switch. Here is a link if you need diagrams or illustrations www.appliancehelponline.com
Thank you for your post, friend!
I located that on Electrolux Cooktop error codes "35" and "75" stand for input voltage too low. It could be an issue with your filter board or an issue within the voltages. I would recommend having a professional come out to your cooktop to properly diagnose to avoid any unnecessary part purchases. -Matt
