Question about Kenmore 63942 Dryer
Hi,my problem with the dryer is that it not heating any more and i can't get the timer on
  • Kenmore Master
  • 2,536 Answers
Send the model number,open the door,look around the opening of the dryer not on the door and i can look up your dryer,i don't understand what you're saying about the timer?if the timer isn't moving on auto or more or less setting it wont move if there's no heat,also i either need the model number or is it gas or electric
Posted on Jul 22, 2010
Dryer works but timer doesn't move. I just replaced it and still having the same problem.
Kenmore 400 6942 Dryer Heat timer - Questions - Fixya
www.fixya.com > Forum > Dryers > Kenmore > Kenmore 400 6942 Dryer
Kenmore 400 6942 Dryer, heat timer related issues. ... The timer doesn't work. ... the heat turns back on the timer stops,heat shuts off the timer will move again,if the ... not heating/timer knob not turning . the dryer works but is not heating and i ...
kenmore 400 doesn't heat, and timer doesn't move, but dryer ...
www.shopyourway.com > Manage My Life > Questions
I understand your Kenmore 400 Dryer doesn't heat up or the timer doesn't move, butit tumbles sometimes. I found the manual for your Kenmore Dryer in ...
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ....and now the dryer won't heat and the timer doesn't advance, butthe motor still runs? .... Diagose a Whirlpool or Kenmore Dryerthat Keeps Running, Wont Shut ...
Dec 21, 2015 | Kenmore 400 6942 Dryer
Hi, i have an amana dryer that the timer and the heating element quit at the same time.could the heating problem be coming from the bad timer?
Hi and welcome to FixYa, I am Kelly
I think you have a failed cycle thermostat. The cycle thermostat provides power to the timer to advance the clock and the heating element. If the thermostat has failed it will not heat or advance the timer. Usually when just one side of the thermostat fails the timer will advance but the dryer will run and not shut off. There may a wiring problem on the C terminal of the cycle thermostat. (Burned / got hot / wire itself failed from heat )
If you can provide a model number I can probably locate he replacement parts information for you and possibly a wiring diagram.
Thanks for choosing FixYa,
Kelly
Jan 30, 2011 | Amana Dryers
Dryer Tunrs on and runs with no heat and timer never moves
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 02, 2010 | Maytag Centennial 7.0 Cu. Ft. Super...
63942 Dryer: runs air no heat , timer does not move...
heatman101
May 18, 2010 | Kenmore 63942 Dryer
Dryer will not heat, plus timer will not move
heatman101
Apr 09, 2010 | Whirlpool LGV4634JQ Gas Dryer
Dono heat and timer dont turn
HI. Due to the fact that the timer is not advancing, this will lead me to believe that the timer is the culprit here. The timer is equipped with a motor. this motor, when energized, will advance the timer dial, thus, activating the unit, and progressing the cycle. If the motor is damaged, as in your case, the unit will not heat, or run correctly. Simply replacing the timer control module will correct this problem.
Replace this damaged timer mechanism asap.
Dec 04, 2009 | Estate TEDX640JQ Electric Dryer
TEDX640PQ1 dryer, timer no longer times and heat does not come on. dryer will spin and blow cool air forever
HI. The timer is the principal initiator off all functions. If the timer module dose not time, or rotate properly, this will signal that the timer mechanism has failed. The timer will need to be replaced in this case. The motor is damaged.
Once the timer is replaced, the heat will return as well.
Oct 23, 2009 | Dryers
Amana gas dryer ALG331RAW timer does not work and no heat
HI, the timer is defective. the heating process can be affected if the timer isn't functioning correctly. replace this failed timer asap. this will fix the issue.
Jun 19, 2009 | Amana ALG331RAW Gas Dryer
Timer not shutting and and not heating
Hi, Is this a gas or electric dryer? The heating problem is causing the timer not to advance. Let me know which type dryer and I can get you through this.
Vic
May 10, 2009 | Dryers
It runs but timer wont advance dryer wont heat.
did you change out the limit switches? they control the heat to the element... and it sounds like you need a new timer
Jan 22, 2009 | Whirlpool GGQ8831L Gas Dryer
Kenmore 63942 Dryer Logo
80 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De GO PATS
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
