Question about Frigidaire FDB989GF Dishwasher
My Frigidaire FDB989GF runs for a short while then shows PF
The machine starts running and then after a brief 3 - 5 mins(?) shows "Power Failure" and shuts down... yet all monitor lights, etc are illuminated.
Timer?
Help!
Thanks!
5 Suggested Answers
SOURCE: Error Message 'Er' on frigidaire dishwasher
I had the same problem. I pressed the "Start Cancel" button, kept it down, then pressed "Rinse Only" button. The display then went clear. I pressed "Start Cancel" again, then "83" showed up on the display. I let it run its cycle, then it corrected itself. A little scary, but it worked. This answer board is great!
Posted on Feb 22, 2009
SOURCE: Flashing Power Failure Light on Frigidaire Diswasher Model # FD989GFC2
I have a Frigidaire that does the same thing. I was able to push the start cancel button then select a cycle and press the start button, shut the door and presto it worked.
Posted on Mar 16, 2009
SOURCE: Frigidaire Ultraquiet III
I had the same problem with mine. I turned the heated dry off and it works fine.
Posted on Jun 09, 2009
shastalaker7
  • 1515 Answers
SOURCE: just installed the dishwasher and
Hi, I am doing some Research at this moment. Will get back to you,
Shastalaker7
Posted on Nov 06, 2009
Start for just 1/3 second then stop with error PF ?
Hey Andy, thank you for your post!
From what you have described your Frigidaire dryer, GLEQ2152ES, is running for a few seconds and then displaying an error code of "PF". The error code of "PF" means there is a power failure and this could be an issue within your control panel or power source. I would suggest performing a reset, this could help clear our any miscommunications within the panel, and you can do this by disconnecting the power cord for at least ten minutes. I hope that this information is helpful towards your repair. -Matt
Feb 17, 2016 | Frigidaire GLEQ2152ES Electric Dryer
Why would machine throw a PF error code in spin cycle?
The PF error code indicates "power failure" condition. The fact that it was indicating on the display while fully loaded tells me that you have a bad electrical connection somewhere on the machines PC boards or supply.
The spin cycle is also triggering this condition when the vibration on the machine shakes the "bad" connection and causes a brief loss of power to the machine.
Sep 19, 2015 | LG SteamWasher Series WM2650HWA
I have a PLD4375RFC DISHWASHER WILL NOT RUN P F FLASHES AFTER ABOUT 2-3 MIN. it will start and run for 2-3 min.before the power failure unit less then one year old
Sounds like a faulty console panel. They had a problem with moisture getting into it, and causing it to get a PF (power failure) code. If it's under 1yr old, it should still be covered by manufacturers warranty. Part number for console with touchpads is 154639207, failing that, i'd say you have a bad control board, but console much more likely.
Mar 31, 2010 | Frigidaire PLD4375RFC Dishwasher
Getting code PF, resetting breaker did not fix the problem. Dryer model Aeq6000es2.
PF Power failure "PF" flashes to indicate that a power failure occurred while the dryer was running. Press HOLD TO START to continue the cycle, or press OFF/Pause to clear the display.
Feb 22, 2010 | Frigidaire AEQ6000ES Electric Dryer
The dryer runs for a couple seconds and then give a PF code which I think means power Failure. brand Frigidaire
that is a power failure code. check the main cisuit breaker and the cord to the dryer and make sure the connections are tight.unplug the unit for a few minutes and plug it back in this should clear the pf code out.
Error code pf
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 01, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
My dishwasher starts and runs for 3 minutes then shuts off and flashes PF?
PF IS POWER FAILURE / LOOK AT CONNECTION IN HOOK UP BOX . SOUNDS LIKE THERE GETTING AN CAUSING AN OPEN . WHEN COOL THEY WORK ..MM MAY BE THE CONTROL BUT I DON'T THINK SO ..
Dec 06, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Code
The PF stand for Power Failure. When you unplugged it, it truely did have a power failure..
Nov 02, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire FDB989GF Dishwasher Logo
135 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
