Question about LG Televison & Video
Thomson LCD-TV 32LB125B5 switches on by itselve
My Thomson LCD-TV 32LB125B5 is connected to a Humax HD-Recorder iHD-PVR C via a HDMI cable.
For some reason the TV switches on by itselve during the night even if no recordings are programmed. How to avoid this?
mistersony
  • 320 Answers
SOURCE: Periodic tv screen blackouts
The problem is your cable box. I know you said you replaced it, but I work on TV's everyday and, sorry to say this but cable box HDMI outputs have serious issues, like no or intermittent sound and video. I have seen customers exchange their cable boxes 5 and 6 times and still have the problem. Your best bet is to use the component outputs of your cable box, visually you will not see a picture difference between component and HDMI when using a cable box. Your other solution is to get satellite; I have NEVER seen an HDMI issue with a satellite box
Posted on Nov 26, 2008
  • 57 Answers
SOURCE: Insignia TV no audio on non HD channels via HDMI cable.
have you tried to change the audio settings to HDMI on tv? when u have HDMI hookd up u have to change the audio to HDMI also
Posted on May 31, 2009
  • 325 Answers
SOURCE: PLaystation 3 won't link up via HDMI cable
You might want to try a factory reset on your PS3 = turn it off then hold down the power button for 5 seconds it should then Beep.
there is a small memory in the PS3 that stores info about the tv that is was Initially setup on. IF you do this reset this should allow you to connect it to your Acoustic Solutions tv via the hdmi cable.
Another Tip i would do is connect it all up with it turned off then power up your appliances once its all connected.
Hope this sorts it out for you
Little Dish Fitter
Posted on Sep 18, 2009
BElectric
  • 1140 Answers
SOURCE: I have a Panasonic Tx
You didn't fully expain how each device is connected to the others. I don't think you have this set up correctly. Your DVD cannot record in HD so there is no point sending an HD signal to it - it can't process it. This is how I would set it up:
1. Install a 2-way splitter on the input cable
2. Connect output 1 from the splitter to the Humax receiver
3. Connect the Humax receiver to the TV with an HDMI cable
4. Connect output 2 from the splitter to the DVD
5. Connect the DVD to the TV with SCART cable.
This will enable you to watch HDTV via the digital receiver and also provide an input from source (dish/cable) to your DVD player so that you can record.
If you've already set it up this way then it should work. I suspect you've connected the Humax to the DVD and TV and also the DVD to the TV.
Please try this setup and post back if you need further assistance.
Posted on Nov 04, 2010
SOURCE: hi,i have a humax hdr freesat box connected to
have you used a satellite finder for maximum signal and searched the internet for the angle at which you need to align your satellite dish?
Posted on Jan 05, 2011
DVD output to TV not displayed
So you have HDMI off of the PVR into the TV and AV off of the DVD Player into the PVR at the moment? Just for info what connectors do you have at the back of the tv, dvd and pvr? In's and out's...
Feb 28, 2014 | Televison & Video
Connect hdmi
they are not HD ready so dont have the HDMI plug fitted. 3way models are fitted with HDMI
Jan 30, 2014 | Humax T800 TiVo 80-Hours Video Recorder
Humax cable and Channel connections
see the connections:God bless you
Jul 16, 2012 | Humax Televison & Video
Hi, I have a 32LG3000 HD tv with software version 3.47.1. I just bought a Humax FoxT2 HD free view box but when connected via hdmi to the LG tv a message briefly comes up on the tv saying invalid format...
I , would try using another ( alternative connection) from your humax , say the scart cable just to see if it , the humax is ok. then if tv has more than 1 hdmi skt try it too, if still not working retry upgrade firmware route
pete
Nov 11, 2010 | LG 32LC7D Television
I have a Panasonic Tx l37S10B tv set, & a PanasonicDVD recorder,DMR-EX768EB. To ensure I receive true HD i have bought a Humax Fox T2 hd Digital receiver. I use these items to receive & record HD...
Nov 04, 2010 | Panasonic Televison & Video
Connection to Bose V30 System
check hdmi setting from ur tv and ur dvd connection
Nov 08, 2009 | Bose Lifestyle V30 Home Theater System -...
I'm simply looking for the most efficient way to hook up my HD-TV with HDMI inputs to both my cable box (with HDMI inputs) and my DVD player/recorder so that I can record from the TV I watch.  ...
The way you have it hooked up right now will not work unless you have a coaxial out on your cable box going to the dvd recorder. Even then, picture quality will be severely degraded. The best way to do it is to leave your cable box hooked up to your TV via HDMI and connect your dvd recorder to your cable box via component video if your dvd recorder has a component video input. If it doesn't, then just use the composite video input. That way your picture quality will be better and you will still be able to record with the TV off.
Jan 02, 2009 | Insignia 37" LCD Flat-Panel HDTV
How to connect a humax foxsat-hd to a panasonic dmr 75eb recorder,to a panasonic th42px60b plasma tv,also will i get better result using component cable instead of scart lead. please can you...
You plug the humax into the panasonic dvd recorder and then from the outputs of the dvd recorder plug it into the panasonic plasma inputs
Is component video better than RGB? Well, yes and no, RGB provides the widest bandwidth and is the best choice for connecting audio visual devices like a Freeview box, digibox or Sky+ box to your TV, home cinema or home theatre system. DVD is however different, to reduce the amount of storage required DVDs are recorded using component video, it is therefore better to connect a DVD player via a component video cable to your TV, plasma or LCD TV etc.
Thanks if you have any questions please do not hesitate to ask
Dec 02, 2008 | Televison & Video
Question regarding audio connections Akai 30" LCD TV
a switch box is needed the s video shares the red/white audio with the yellow rca that is being used already
May 07, 2008 | Televison & Video
Televison & Video Logo
Computer Repairing
Computer Repairing
