Question about LG WM2688H Front Load Washer
My LG is leaking around the seal at the glass. How can I lubricate this to keep it from leaking? Or is there a better solution?
  • kelley12185 Jul 15, 2010
    Is there a more permanent fix than shimming the door?
  • LG Master
  • 8,220 Answers
The manufacturer recommends shimming the door latch to make it close tighter.
Posted on Jul 15, 2010
  • Dan Webster
    Dan Webster Jul 15, 2010
    It is recommended by LG that the latch gets shims between it and the door frame. This will make the door close tighter. I did NOT make that up. You may also have a leak because of misusing the correct amount of detergent. Here are ALL my LG washer and dryer notes:
    You MUST use "HE" (High Efficiency-Low Suds) type detergent--but to use the correct amount.
    Nearly all brands of "HE" detergent have incorrect instructions.
    The correct amount is as follows:
    HE: (2) Tablespoons Per Washload
    HE 2X (double concentrated) : (1) Tablespoon
    HE 3X (triple concentrated): (1) Teaspoon
    This reduces/prevents:
    1) Musty Odor
    2) "LE" Error/Interrupted Cycle
    3) L-O-N-G Cycle Times (longer than time displayed)
    4) Insufficient Cleaning Results
    5) Small Water Leaks from the air vent behind the washer or at the
    front door gasket
    6) Damaged Hall Effect Sensor (on 2007 or older LG washers)
    7) Reduced Spin Speeds (laundry not spin-dried effectively)
    Most consumers were doing what is *normally* the right thing to do, which is to follow directions on the detergent label. In this rare case--those directions should be entirely disregarded.
    Additionally--in many LG washers--the liquid dispenser cup (blue cup) has a "MAX" line on the white siphon cap.
    This was a very big *faux pas* on LGs part--this "MAX" line has NOTHING to do with measuring detergent and should never be used as a guide for determining correct detergent amount.
    The "MAX" line indicates how much liquid must be in the blue dispenser cup before it DISPENSES from the bottom of the cup.
    This is a very,very frustrating mistake that gives owners much grief.
    After three months of incorrect type of detergent or incorrect amount of the correct detergent used--musty odor begins to occur.
    After more than two years--a significant amount of soap scum/curd has accumulated in the washer. Odor-causing bacteria flourishes on this build-up.
    It is imperative to remove this slimy residue. Tide sells a product called "TIDE WASHING MACHINE CLEANER" which is very effective.
    Once a tub has become heavily contaminated--normal methods of performing a TUB CLEAN cycle won't "cut it".
    Add the entire packet of "TIDE WASHING MACHINE CLEANER" directly into the tub (no laundry) and close the door.
    Press and hold: SPIN SPEED & SOIL LEVEL buttons--then press POWER button.
    Wait for door to lock.
    Press the START button (6) times--this will fill the tub with hot water to the maximum setting when it stops filling.
    Press the START button two more times--this will enable the tub to tumble.
    After 3 hours--turn "off" the washer.
    Turn the washer back "on".
    Select the shortest wash cycle (usually "quick wash") and press "START". This will rinse out the tub.
    This method of "TUB CLEAN" is *not* from a service manual but has been the best method for cleaning out LG washers more than a year into incorrect detergent useage.
    After this--use the correct amount of "HE" detergent & perform a "TUB CLEAN" cycle every (4) months using the *tub clean* option on the control panel.
    Most digital-controlled front load washers have a software feature that consumers are unaware of.
    If excess suds is detected by the MAIN BOARD (which monitors motor electrical load during rinse & final spin) the "suds kill mode" will be enabled.
    This causes the washer DISPLAY CLOCK to stall.
    The washer makes an attempt to reduce/remove suds--usually a futile attempt--and ends the cycle much longer than was originally shown on the DISPLAY.
    Problem:
    An occasional LE error but always a slow or no spin: Solution:
    The Red wire going to the Hall sensor was intermittent. You can test this from the main board connector down to the connector on the hall sensor by checking continuity. There is an intermediate connector down by the motor/hall sensor so you can isolate the problem even more. My problem was in the short wire harness that connects directly to the motor and hall sensor. I could not find the open point of the wire so I added a new red wire and integrated it into the harness. All is Good!!!
    Problem:
    The seal design on the washer traps water causing mildew to grow.
    Solution:
    If the door gasket has a small hole at the six o'clock position--it is clogged with soap scum. Use compressed air to blow this hole clear.
    This allows water to drain back into the tub
    If there's no hole--this is an older model LG which did not have this upgrade
    Wiping the door gasket with a rag after the LAST cycle of the day helps prevent debris from accumulating. Some consumers add (1) teaspoon of bleach to a spray bottle with water--and spray the older type gaskets after the final laundry load finished--to keep the gasket clean.
    Problem:
    The detergent and softner dispenser is gravity feed and builds up with "gunk". It has to be cleaned regularly and while the tray is removable, the inlets are not; so you have to fish out the sludge with a paper towel.
    Solution:
    This common on almost all front load washers.
    Remove the dispenser tray. Remove the blue liquid detergent cup. Add all to the top rack of the dishwasher---run a cycle. This makes much less a chore of cleaning the dispenser tray assy.
    Problem:
    The washer broke down about 6 months ago (roughly 2-2-1/2 years old). The waste pump went bad. No service reps in the area and the place that sold them to us quit selling LG after numerous complaints. I went to a local appliance parts wharehouse that sells just about every part known to the appliance world and when I mentioned LG, the guy at the counter smiled and shook his head. "You have to order it online.
    Solution:
    You are correct---parts & service is still lacking in some areas, regrettably.
    Problem:
    The dryer has an auto dry feature which never fully dries the clothes so we wind up manually setting the dry time to an hour
    Solution:
    LG gas dryers are VERY temperamental in long vent set-ups. If fabric softener sheets are used in the dryer--clean the two stainless steel strips of metal on the lint filter housing with a SCOTCHBRITE PAD--scrub back & forth several times to remove the waxy residue from the fabric softener sheets. Most,if not all manufacturers do *not* recommend using sheets in dryers that have a moisture sensor (electrodes).
    However--using a SCOTCHBRITE pad keeps the wax off those sensors which can be seen if looking *into* the dryer drum and at the lint filter housing.
    If only *liquid* fabric softener is used in the washer--clean the dryer sensors once a month. Liquid softener also contains wax which can slowly accumulate on the dryer sensors from the laundry washed in the washer.
    Problem:
    With no error code showing up and the glitchy flickering of the display, I'm eyeballing the main board.
    Solution:
    Unfortunately--that appears to be the fault (main board) if the lights for the cycles that circle the control panel knob flicker or do not fully "light up".
    Main Board Part # 6871EC1121D
    Problem:
    Getting a CE error code
    Solution:
    This is a *rare* error.
    It's highly unlikely the motor is at fault.
    Detergent overuse triggers an "LE" error rather than "CE".
    UNPLUG THE WASHER...
    First--inspect all wiring connections at the MAIN BOARD (see below instructions). If good...
    Inspect the wiring at the motor--remove the rear service access panel.
    Remove the 17mm bolt at the center of the rotor--this can be tight as threadlocker is used (I use an 18 volt Dewalt Impact drill).
    Pull off the round shaped rotor. Use some care--this rotor has magnets lining the inside of it--it's not super fragile but can crack if hit sharply.
    Inspect the two plug connections to the motor for loose or frayed wiring. Also inspect the wiring which runs from the base (bottom) of the washer-to-the-motor. Once or twice--I have found wiring frayed from the gyrating tub assembly (repair as needed).
    If no obstruction such as a nail or similar object can be seen in the drum (small holes in tub)...if the drum turns freely by hand--the most likely fault will be the MAIN BOARD has failed.
    This job is very simple:
    Remove (3) screws at the top of the control panel.
    Pull the control panel towards you & upward.
    Remove the screws that attach the MAIN BOARD to the Display Board. Install new MAIN BOARD.
    LG WASHER SERVICE MANUAL LG DRYER SERVICE MANUAL
  • Dan Webster
    Thanks for the kind rating LOL
  • 185 Answers
Carefully door gasket for cuts or stretching/waves where it meets the door glass. if ok, clean inner door glass where it meets the gasket and, install washer inside under each door switch mounting screw to bring switch "in" slightly. door gasket outer metal spring will need to be removed to do this.
Posted on Aug 24, 2010
LG WM2250CW has a drip underneath, front and center. Used, but new to us. Help!
Before doing anything else, check and see how dirty the glass window is along the inner edge where it contacts the gray seal. You will find that the very bottom of the glass is all gunked up with detergent , hair, lint, etc. Clean all around it using a scotcbite pad and water. These seals will leak if the glass is dirty.
Jun 02, 2015 | LG Washing Machines
Lg tromm washer leaking from front door
We have the same problem with our LG washer. Don't think the door can be adjusted but I'm not for sure. I think the gasket is wore out but haven't checked on fixing the problem yet because it barely leaks.
Sep 29, 2012 | LG WM-2277HW Front Load Washer
Transmission fluid seeping out of braided clutch cable at it' lowest point.
If you have transmission lubricant leaking from the cable, you need to replace the cable. The "braided" cable is probably an aftermarket product. I've never known H-D to offer a braided cable. There is a small seal in the end of the cable to keep the lubricant from running into the cable. There is also an o-ring around the threaded end on the cable to keep the lubricant from seeping out past the threads.
Good Luck
Steve
Sep 03, 2011 | Harley Davidson FLHRCI Road King Classic...
Model wm0642hw front load. it leaks by door frame.rubber seal with clamp.only 2 years old. do i need to change the door frame outer part a151? thanks for your response in advance
Hi, If the door isnt loose or broken? Its more likely to be the rubber door seal if its leaking between the seal and the door glass. Check the edge of the seal where it touches against the glass for damage or ware if its ok clean any soap residue or bits from the glass.If it still leaks change the door seal.
Regards Elect App
Jul 13, 2011 | LG WM-2277HW Front Load Washer
I have a 2003 park ave turbo im wondering what type fluid or ? goes into the turbo i can see grease /oil leakage? around the exterior part
Hi the turbo is lubricated by the same oil which lubricates the rest of the engine. This oil ( under pressure ) lubricates the sealed bearing which the turbo spins on.
If you have oil around the hoses etc then there is a possibility the turbo bearing seals are leaking
and allowing oil to leak into the intake hose this oil usually softens the hoses and the oil contamination shows around the hose clamps etc.
I hope i have been of help to you with this problem.
john ( South Wales UK )
May 30, 2011 | 2003 Buick Park Avenue
Air leakage coming from moon roof. is there an adjustment for seal around glass, there is no water leaking in just wind whistling continually.
The glass frame is adjustable. Sometimes these types of leaks can be fixed with adjustment and sometimes it requires that the seals be replaced. Take a look at the pictures below. If your sun roof looks like it is pretty well centered when it is closed, then you probably need to replace the seals. If it is off-center, then it can probably be adjusted to fix your leak.
Mar 27, 2011 | 2003 Toyota Camry
I have water leak out of our front loader, it leaks out rite in the middle from the bottom of the door. I am not sure if it is from the small hole in the door or if it because of a bad seal. The rubber...
the wire ring just keeps the seal in place,, make sure the bottom of the door glass is clean,, if so look at the seal and see if it is pushed in alittle around the bottom,,you can take a hair dryer and heat it up while pulling it back out ,, ( just the lip part) if that doesnt work you will need to replace the whole gasket
Jan 24, 2011 | LG WM-2277HW Front Load Washer
Leak rear ruim around tire oily
This is most likely an axle seal leaking.
Nov 25, 2009 | 2005 Mercury Grand Marquis
Rain water leak
The most common source of this kind of leak is the windshield, have a glass shop check the sealing around the glass
Sep 04, 2008 | 1992 Mercury Grand Marquis
LG WM2688H Front Load Washer Logo
485 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
