Question about 3Com NBX 3102 IP Phone
I have a bad phone on an NBX100. How do I swap out the phone with a new one and keep all of my programming for the existing extension
  • 58 Answers
What software version are you running? Specifically 5.0.x and below or 6.0.x and above? Assuming you have plugged in the new phone and have discovered it on the system... If you know how to get to the users tab for either version, then select the users extn (example ext.100) and click modify(5.0) or on the extn number (6.0). Then scroll down in the section on the right where it says telephone list (5.0) or associated telephone (6.0) and select the newly added phone (example ext. 101). Once you select the new extn (101) and click ok or apply, you will have moved their user profile to the new phone. All of their recordings, passwords and voicemails will move with the profile.
Posted on Jul 27, 2010
Change internal directory on optipoint 500
The extension name and extension number are set in the system programming. Use manager 'e' and change them in the station view. If you are swapping people around and want them to keep their extension numbers and names, you should re-patch the cables feeding to the wall sockets rather than change the programming (if you can).
Oct 20, 2014 | Siemens optiPoint 500 Standard Corded...
How can i change the extension numbers and names on kx-t7630
It requires access to system programs 003 and 004. That can be done from the extension authorized for programming, usually extension 101. There is no "swap" command and we usually move the hardware at the frame rather than in software, but you can do it if you find a vacant number. An example would be to swap 102 and 108 you make 102 some other extension, like 402, then make 108 102 and then 402 108. Yeah. Sure.
Anyway, the user's guide (UG) for your specific system (not the phone) has instructions for the System Manager that details how to program Extensions and Names.
Carl
Aug 26, 2010 | Panasonic KX-T7630 Corded Phone
Extension Error when setting up new phone
Look in programming, does that extension exist? If not create it. Or, turn on "auto create extension"
Jul 28, 2010 | Avaya 4610SW IP Phone
How to move my ext# to a new phone location Nortel t7316E
The system has a built-in feature called "Set Relocation", which will allow you to move your phone to another active telephone jack in your office and the extension number, voicemail box, and all features will stay with your phone.
Have your system administrator turn on Set Relocation, or check your Norstar administration manual for programming details. Or, you can call your telecom service company and have them send a technician.
May 14, 2010 | Nortel Norstar 16-Line PBX Speakerphone
I want to block a number on 3com NBX100
are you using a PBX system ? you can block your number the same way you would with other phones. if you have to dial a number before you can get an outside line, the dial the code after,. usually *67
May 03, 2010 | 3Com NBX 3102 IP Phone
How do i add a new phone to an existing system? I have connected the phone & just need to assign an extension number for it so that the other phones can see the system, thank you
If you have installed it on a new extension, it already has a number. By default, on a TA-series system, the jack and extension are the same, so Jack 12 is extension 112. Quickest way is to plug the phone in and dial 0. The main phone rings and the display will give you the extension number.
To program the buttons, press PROGRAM the button and dial 1 plus the extension number. The lines should already be programmed by default, but they are 0 plus 01, 02, 03 etc. Press STORE after each button you program.
If you want to program ringing and line access differently than it already is, you need to look in the Programming Manual for the specific phone system. The Panasonic cabinet is going to be white with a silver tag or a model number stenciled or embossed on the case. Something like TA-824 or TA-624 would probably be your system model.
Carl
Dec 15, 2009 | Panasonic KX-T7730 Corded Phone
Assign a new person to an extension
Changing the programming2.gif on a Partner system is done on either ext 10 or 11. At one of those ext's press the feature key and "00"
next press the left hand intercom twice
the display should say system programming
press the left hand intercom button
the display should say central telephone prog extension:
enter in the extension number of the persons phone you wish to rename
the display should say program extension xx
the display should say the extension number followed by the existing programmed name
enter in name of new person by pressing the number where the letter is then its order on the button so under the 2 button 1 would be A, 2 would be B, and 3 would be C ex. BILL = 22 - 43 - 53 - 53 use the mic/hfai button to erase entry.
either press the right hand intercom to go to the next extension or press feature 00 to exit
Oct 19, 2009 | Avaya Corded Phone avaparp18d
How do i change the phone extention number - Panasonic KX-T7665
It depends on your phone system, the smaller ones, 50, have modular jacks to distribute the extensions and you can simply move the pluged in extension wiring on the control unit, for instance if you are 102 and the other phone is 103, simply swap the plugs on the main control unit. The larger Panasonics have direct wiring so you need a punch tool and some cross wire to move an extension.
Oct 01, 2009 | Panasonic KX-T7633 Corded Phone
Program a new Nortel m7310 phone with an existing extension
If the extension was a swap of the old M7310 with a new(ish) M7310 no additional programming should be necessary. However if the phone was replaced with another type of nortel set(M7208, M7324,T7313 etc.) then the phone will default to its base features. To re-program the feature keys press feature *3, the button you wish to program, and the feature code for that button
Sep 28, 2009 | NorStar M7310 Corded Phone
D1232 extension programming issue
Welcome to Panasonic TD programming....
Even though the hardware doesn't exist, the numbers do. The universe of 101-164 and 201-264 are already taken. Oops, 200 might be available, 100 might be available. 167 and 168 and the 80's might work.
It's a 3 step process. Change 210 to 200 change 225 to 210 and change 200 to 225. There's your "swap".
Now, keep in mind that the XDP port for 110 is 210 and if your voice mail is analog.....Ah, but that's another thread.
Carl
Sep 19, 2008 | Panasonic KX-T7453 Corded Phone
3Com NBX 3102 IP Phone Logo
194 people viewed this question
Top 3Com Computers & Internet Experts
micky dee
didi2005
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
