Question about Samsung LNT4069F TV
I have a Samsung LNT4069F LCD that the picture would go out after 30 minutes (sound is normal). You could turn it off and on and it would come on for 15 minutes. With each on/off cycle the amount of time it stayed on was less. After a month of this, now the picture does not come on at all. There is no backlighting. Can you help?
  • bretbaldwin Jul 21, 2010
    That fixed the problem. Thank you very much!!
  • 10,594 Answers
How old is this TV?
If its 2-3 years old then power supply board got leaky capacitors problem and replacement of these leaky capacitors in output section of power supply board will fix your tv problem.
I'm not sure about your expertise for parts replacement in circuit board that needs soldering work so local tv repair shop would help you for that if you feel uncomfortable replacing leaky capacitors in power supply board.
Let me know if you have additional question.
Thanks.
Posted on Jul 15, 2010
  • 2 more comments
  • bretbaldwin Jul 15, 2010
    I have done some soldering, but is there any information (tutorials) that would walk me through the process of identifying and replacing them?
  • Shahid Electronics
    Shahid Electronics Jul 15, 2010
    OK, below is image of power supply board, capacitors that need to be replaced are marked with yellow circle.
    Make sure to replace all of these capacitors with same value written on each capacitor.
    Shahid Electronics Jul 21, 2010
    Good to know that you fixed your tv problem.
    Thanks.
What do you think is wrong with my television, it has sound but no picture. How can I fix the problem?
Hi there
I would go to menu on the remote , from there to picture go down the list, if you do not find anything there to help you. Go to Support and to the E manual .
26053790-x3zeawgeewbvgdzeyuixqaom-4-0.jpeg Kolbrun
Jan 14, 2016 | Samsung LN52C530 52" LCD TV
Samsung Ln52a650A1fxza lcd has a red tint when I turn it on. This red tint disappears usually disappears after about 10-30 minutes, then the T.V displays a normal picture. There are times when I turn the...
Check the LVDS cable !!! It is the cable that supplies the video signal from the main board to the LCD controller. If wiggling the cable clears up the problem or invokes the problem, you need a new LVDS cable!
Oct 18, 2013 | Samsung LN46A650 46 in. LCD HDTV
Half screen normal , other half blackened for 20-30 minutes, before turns normal. Recently getting longer to get normal screen and left side stays black(about 2" wide)
sounds like a bad smps or bad display. I would try the smps, but if that doesn't do it the display costs as much as the tv most likely.
Sep 07, 2013 | Samsung LN46A530 46 in. LCD HDTV
Vaio LCD problem
Periods.......Nice little items because they denote the End of a sentence.
See how this works?
"I have a vgn cs36gj, I was working with it, suddenly the LCD became pale black, I connected it to external monitor and it has a picture, sometimes after turning on for 30 minutes LCD start working normally, but after turning off and disconnecting power when I turn it on, it only shows a pale black picture, you know it is on but only black!"
Now you try it.........
"I have a vgn cs36gj. I was working with it, suddenly the LCD became pale black.
I connected it to external monitor and it has a picture."
Okay, I got that part.........
"sometimes after turning on for 30 minutes LCD start working normally, but after turning off and disconnecting power when I turn it on, it only shows a pale black picture, you know it is on but only black!"
WHICH LCD?
Laptop LCD?
External monitor LCD?
Man on the moon LCD?
1) If the external monitor LCD goes 'pale black', the problem is the graphics chipset.
This I do not believe
2) If the laptop LCD goes pale black, this I believe.
Post back in a Comment.
Regards,
joecoolvette
Apr 25, 2013 | Computers & Internet
My samsung 52
go direct to samsung and post ur complaint to them, first of all was there a warrenty? and if u do go to samsung there more likely to help u, the others r out for money
Dec 23, 2011 | Samsung LN52A650A LCD TV
LNT4069F trouble turning on
If you want to fix it yourself, I have a tutorial on this repair. See my Tips & Tricks "Kitchen Table, Samsung - Won't turn on,..." I hope this was helpful.
Mar 30, 2010 | Televison & Video
Samsung T.V. goes on for 30 seconds then no picture
If this is a flat panel LCD tv, this is a sure sign that the panel itself is bad. I have seen this before. Tv comes on works fine then within 5 minutes goes blank.
Aug 07, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung ldp 46 " replaced lamp humming sound fans cleaned and working set continues to turn off every 20 min or so
Humming problem with a Samsung DLP HL-P5063W
picture displays good
Humming randomly starts, but once it starts it hums
May 31, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung plasma tv shows no picture after cleaning
u may have a bad y-sub board , it is normal on plasmas
Mar 29, 2009 | Samsung SP-S4243 Television
Open Questions:
What can I buy / replace to fix my tv? I have a 4 year old Samsung LCD (LNT4069FX/XAA.) A few months ago the image started ghosting, or flickering and repeating itself multiple times down the screen, accompanied by a slight discoloration and / or darkening. At first I could "fix" the problem by gently applying pressure around the frame, or by swiveling the TV on it's stand back and forth. Once the problem was "fixed" the picture was perfect, and would remain that way until the TV was turned off, where I would have to start all over again the next time it was turned on (usually at least a few hours if not over night in between.) Eventually the turning / applying pressure did nothing. The TV would however "fix" itself after approximately 10 minutes. Again, resulting in a perfect picture and lasting until the TV was turned off. Over the course of 2 or 3 weeks, it would take more time upon start up for the problem to fix itself, 15 minutes, 20 minutes, until eventually no amount of time would solve the problem. It is worth mentioning that this occurs on any inputs, and even with no inputs - it is definitely the TV, not a cable or a source problem. I happened upon a similar complaint on your site, where the advice given was to replace the LCD converter, which I did, and the problem is still apparent. Do you have any other solutions that I may try? I would much rather fix this TV instead of buying a new one. Thank you for your time! - Jim D (the article I mentioned is here...) http://www.fixya.com/support/t8380218-samsung_hdtv_ln_t5271f_approx_4_yrs
May 06, 2012 | Samsung LNT4069F TV
See all Samsung LNT4069F TV Questions
Samsung LNT4069F TV Logo
146 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
