Question about Roper Dryers
I have a Roper Dryer Model #REX3514PQ0 and it's about 5 or six years old. I was drying my laundry. The first load dryed fine. One the second load I notice that the setting nob up top was not moving and subsequently noticed the dryer was producing no heat. The dryer was running and appeared to producing cold air but no hot air. I tried on different setting and the same thing - no hot air. I checked my circuit breakers and they appear fine. Can you help me please? Any pictures would be appreciated.
  • Roper Master
  • 8,220 Answers
What I would do is pull the dryer out and unplug the power cord. I would remove the rear cover and check the components back there for continuity.I have a Roper Dryer Model #REX3514PQ0 and it's - f08dda1.jpg15ccca9.jpgIf all of that is good then the timer or breaker might be bad. Why? The timer calls for heat through the RH leg. The amp draw from the heating element arcs up the contact point inside the timer. The motor runs on 120 volts the heater runs on 240 volts. So the breaker will take a beating on the heater side of it. The dryer will hower I have a Roper Dryer Model #REX3514PQ0 and it's - 6db32c2.jpgTo recap It could be the heatI have a Roper Dryer Model #REX3514PQ0 and it's - a2de035.jpgts the time or an electrical problem.6db32c2.jpga2de035.jpg
Rate it or Hate it:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jul 15, 2010
  • Dan Webster
    Dan Webster Jul 15, 2010
    Bonus stuff:Get these parts off the machine and wash them out. This oughta be enough to keep ya busy LOL
My bosch Nexxt WTMC 3300 dryer makes a squeaking sound when the load is light -- drying a larger/wetter load less likely to make the noise.
I had a similar problem with a different model Bosch dryer. First I made sure the dryer was unplugged. I found, after taking the front and rear panels off, that one of the front wheels that supports the drum was broken. I replaced the wheel and it works fine with no squeaks.
Jan 01, 2013 | Bosch Nexxt WTMC 3300 Electric Dryer
Hello,I just picked an electric ROPER dryer last night.I assembled it plugged it in and it worked fine.This morning I put a small load of laundry in it and it worked fine.I then put in a second load and...
The most likely part that has gone out is the thermal fuse. What will make that go out so quickly is a blocked vent causing excessive heat build in dryer. Did the dryer that this new one replaced havea similar problem of not starting or perhaps it ran but took forever to dry a load of clothing? if that was the case the venting caused the problem with both old and new dryer
Good luck
I hope this helps,if it does please give me a 4 thumbs up rating
Gene
Jul 30, 2011 | Roper Dryers
Dryer will not shut off in any 'auto' mode. Time display ticks down, then jumps up again and keeps running. Dryer does works properly when 'timed dry' is selected. Checked and cleaned exhaust vent. ...
How long is the vent from the dryer to the outside? Dryer vents that are longer than 8 feet with more than (2) 90 degree turns--can affect drying performance.
Setting the DRY LEVEL selector to *Very Dry* will solve most dry-ability issues. In homes with abnormally long vents--even the longer run time in the *Very Dry* setting is usually not sufficient to dry laundry loads.
Reducing the length of the vent or starting a second cycle becomes necessary to fully dry the clothing.
If a second cycle was started---only the amount of time that is needed to dry laundry will be used before dropping to 6 minutes and then the cycle will end with dry laundry.
Jul 14, 2010 | Samsung DV337 Electric Dryer
I have an lg dryer model DLG5966W and the check filter light is on. It takes two cycles to completly dry my clothes. I cleaned the lint filter and still doesnt dry on one cycle. I then removed the filter...
Check your vent. Inspect the dryer venting from the rear of the dryer to the outside vent hood of the home.
If there's a restriction in the vent--the clothing in the dryer takes longer to dry.
When an LG dryer is functioning normally---the time required to dry laundry is determined by the *Sensor* located on the drum side of the lint filter housing and by the main control board.
When laundry is near dry--any Time Remaining on the control panel that is *not* needed will be eliminated---except for the last 6 minutes.
The final 6 minutes of any LG automatic cycle is for cooling down the laundry before the dryer ends the cycle.
If a dryer *counts down* to the last 6 minutes but the laundry is still not dry--the computer will allow the dryer to run until the laundry has dried or defaults (not drying within the additional time allowed).
Setting the DRY LEVEL selector to *Very Dry* will solve most dryability issues. In homes with abnormally long vents--even the longer run time in the *Very Dry* setting is usually not sufficient to dry laundry loads.
If a second cycle was started---only the amount of time that is needed to dry laundry will be used before dropping to 6 minutes and then the cycle will end with dry laundry. Bonus:
LG DRYER
Problem:
The dryer has an auto dry feature which never fully dries the clothes so we wind up manually setting the dry time to an hour.
Solution:
LG gas dryers are VERY temperamental in long vent set-ups. If fabric softener sheets are used in the dryer--clean the two stainless steel strips of metal on the lint filter housing with a SCOTCHBRITE PAD--scrub back & forth several times to remove the waxy residue from the fabric softener sheets. Most,if not all manufacturers do *not* recommend using sheets in dryers that have a moisture sensor (electrodes).
However--using a SCOTCHBRITE pad keeps the wax off those sensors which can be seen if looking *into* the dryer drum and at the lint filter housing.
If only *liquid* fabric softener is used in the washer--clean the dryer sensors once a month. Liquid softener also contains wax which can slowly accumulate on the dryer sensors from the laundry washed in the washer.
Jun 17, 2010 | LG DLG7188 Gas Dryer
Have a Maytag Dependable Care dryer. Model MDG9606AWW. The glow bar comes on, gas lights and stays on about 30 seconds, go off for about 30-60 sec. then comes back on for about 10-18 seconds. Then goes off...
LG gas dryers are more sensitive to venting length and air flow resistance. The gas burner can cause a rapid increase in temperature compared to an electric burner.
Rapid temperature rise in a gas dryer leads to premature burner shutdown (longer time required to dry laundry).
The gradual temperature increase of an electric element is more "forgiving" in homes where the dryer venting is less than ideal.
Apr 01, 2010 | LG DLG5932W Gas Dryer
Dryer gets hot but wont dry clothes
Do you know if the dryer vent is free of obstructions?Check outside where the dryer vents outside ,and see if the air is weak or flowing freely.If it is not clogged the air should be pretty strong from the vent outside.If it has blockage it will definitly take longer to dry your clothes.
May 17, 2009 | Roper RGX4634KQ Gas Dryer
Dryer isnt drying on frist cycle
This is most likely an element problem. it is best that a tech replace it but if you feel comfortable take it out and to your local repair shop. match it up and reinstall it.
good luck
Jason
Jan 19, 2009 | Roper Dryers
It takes several auto cycles on regular heat to dry a load of laundry when I think it should only take one. What's wrong?
first, check your exhaust, you have to make sure there is no buildup at all inside it. this is the most common problem to cause this. if lint gets backed up, there is a sensor that shuts down the heating element after only a few seconds. hope this helps
Oct 27, 2008 | Maytag PYE2300AY Electric Dryer
Dryers Logo
917 people viewed this question
Top Roper Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Roper Dryer Expert? Answer questions, earn points and help others
