Question about Canon imageRUNNER 2270 Copier
I have this problem on my clients iR3300 copier a few weeks ago and it has been going on for quite some times now one side of A4 page copy developer light
    Sniper:
  • 77 Answers
Check your drum volume and make sure not exceeded lifespan, clean up your scanner unit or replace your developing spacers and bearings,maybe also your developing cylinder.
Posted on Aug 01, 2010
  • Ased Pasha
    Ased Pasha May 16, 2014
    i have replaced drum and cleaned the scanner unit also but the problem is still their
  • Ased Pasha
    i have checked the same developing unit in other machine their it works
Hp CLJ 2600n colors problem
do a permanent storage init reset
Feb 13, 2014 | HP Color LaserJet 2600n Printer
Ir3300 black page coming how to rectified this problem plzz help
True multi-functionality means you get more for your money in less space with the iR3300 black and white office photocopier. Handling the work of many in one compact solution, the iR3300 provides a cost-effective solution to your printing needs.
Features of the iR3300:
  • Provides copying, printing, scanning and faxing all in one unit.
  • Has a print speed of 33 pages per minute .
  • High capacity paper supply
  • Double-sided printing as standard.
  • Compact and reliable design.
  • Productive and space saving finishing options.
Jul 22, 2012 | Canon imageRUNNER 3300 All-In-One Laser...
Hi i have ir3300 and the print is lighter from one side in a4 sheet
First of all You need to clean the laser unit and beneath the copy glass and lenses inside.
Second of all if cleaning doesn't help's try with cleaning the developing roller and replace the drum unit and transfer roller.
Hope that helps
Sep 09, 2011 | Canon imageRUNNER 2200
One side of my copy fades on the A4 sheet, i use IR3300 copier.what is the problem?
take out a internal report on A4 .if it ok then the problem is from optics and u have to clean it .if the report is also faded then the laser unit is dirty so u have to take it out if ur a rep and clean it with simple white cloth for dust on mirrors
Jul 30, 2011 | Canon ImageRunner 3320N Copier
The copier IR3300 print one side faded at the back on the A4 than the other side. on the same A4 sheet, one side is lighter than other. but when the paper is A4R, it okey. what is the problem?
it may be because of dirty laser unit or the iptics.try cleaning the optics and then the fuser.charging can also be a problem .check DP unit for toner layer .
How can i put 4 photos on A4 page-using an epson rx700
Go to your printers and faxes (xp), or Devices and printers (Win7) folder
Right click on the RX700 and choose Printer Preferences
Select A4 as the paper size
Select Page Layout tab and select Multi-Page and select 4 (default is 2)
Select 4 copies
Print away!
Alternatively, if you're using Windows, use the Office Picture manger, Picture and fax viewer of the like, and select the multi pictures setting. If you're printing one photo 4 times, remember to select 4 copies, as you're telling the app to print ONE pic in a 1/4 of the A4 page. You need 4 copies to fill the page with the same photo.
Hope this helps.
Aug 03, 2010 | Epson Stylus Photo RX700 All-In-One InkJet...
I don't know how to copy two pages (size A4) at
open the photo copier put the original copy on top of the screen words facing down then cover the machine then press copy then ok after it will copy, after remove the copy from the photocopier then pull the tray and put that copy on that tray the words copied facing up then put the tray back then open the upper side where you put the original copy then change it to another side, cover the photocopier, press copy then ok it will copy on boss sides.
Jun 10, 2009 | Canon iR 1600 Laser Photo Printer
Legal Sized 2-sided Copies through Automatic Feed
Does the copier print correctly when copying off the glass? I suspect that the document feeder has been set up to feed other paper sizes eg A4, A4R. Because of the conflict between sizes the copier adjust the image.
Oct 05, 2007 | Canon imageRUNNER 5000 Copier
Canon imageRUNNER 2270 Copier Logo
76 people viewed this question
old marine
old marine
