Question about Husqvarna "Chain Saw - 16" Bar, 3 Hp
I have a relatively new 16" Husqvarna chainsaw, and I have the hardest time getting it started....sometimes I can't even get it started. Once I get it going, it usually runs fine, but it is extremely difficult to start....like 20-30 pulls.
  • 3 Answers
I had a similar problem in a 345e caused by ethanol-blend fuel(poison to a lot of 2 stroke and other engines). This is an Australian view - strongly suggest stay away from E10 etc , use premium fuel and quality oil(2 stroke and synthetic).
Posted on Jul 25, 2010
    Brigadier General:
  • 4,088 Answers
We have a Husky 435 (two year warranty) that was new last year. It would start and run fine for several days, then nothing--took to warranty service where they replaced the ignition module the first time. Ran for several more days, then nothing again--this time they replaced the carburetor and it seems to working fine from then on. Suspect that Husqvarna has had problems with our ethanol-blended fuels. If you still have warranty coverage, then take advantage. Hope this helps!
Posted on Jul 16, 2010
Husqvarna model 450 will not start when hot
1 view piston. To do this, remove the muffler. 2 to change seals on crankshaft.
May 31, 2012 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Brand new husqvarna 235 chainsaw will not start
is the kill switch on?check the spark plug it could have had the wire fall off in shipping
May 24, 2012 | Husqvarna Forest & Garden #952802239 235E...
I have a Husqvarna 340? with 16 inch bar. Has sat for a while but now will not start. It pulls fine but doesnt crank. Second, what type oil should i mix with the gas
Any brand of 2-cycle oil for air cooled engines will work. Do not use outboard, snowmobile, etc. Sounds like the gas evaporated and the oil was left in the carb and clogged it up. You can try removing the air filter and spraying some gum cutter, carb cleaner or Sea Foam(my favorite) into the carburator. It will probably need to be diassembled and cleaned. Usually the hardest part of the job is getting the link and hoses unhooked.
Feb 21, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna 14" chainsaw wont start. put new plug
Try a new spark plug.If still does not fire you have a bad ignition coil.
Nov 26, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna Model 136 chainsaw will only run for a short time with choke closed. Engine quits shortly after choke is opened.
Take apart the fueling system and carb. Something is blocking or gummed up. One thing that sometimes works is to remove air filter, rev the unit up, and place hand fully over the intake, and remove before unit stalls. This sometimes will clear the blockage.
Oct 05, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna 235e will not stay running
Take the saw back for warranty service. We have a Husky #435 that had starting problems when new last year--warranty service replaced the ignition module the first trip, then a little later, they replaced the carburetor--it has worked very well since. I suspect that Husqvarna has had problems with our ethanol blended fuels. Hope this helps!
Jul 12, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
16" craftsman chainsaw primer pfoblem
Check the condition of the fuel line and filter in the tank and to the carb and primer.Today gas and time will soften them allowing them to become blocked or leak.Replace if needed.
Oct 24, 2009 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
HUSQVARNA model 435 Difficult starting
the problem is in the ignition coil.it needs to be replaced.it is under warranty.its warranty is life time.call husqvarna and they will either send you a new one or send you to a husqvarna dealer to fix the problem.that is at no cost to you..............let me know if this helped.................
Jun 06, 2009 | Husqvarna Forest & Garden No.967012396 345...
Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
343 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
