Question about Electrolux Vacuums
Power cord won't retract on anaerus 5500 vacuum cleaner
  • Anonymous Apr 23, 2008
    Mine's a Guardian c134B with a cord retraction problem...Only steps Ive taken are gently pulling the cord repeatedly.
    Thanks
  • Anonymous Mar 20, 2014
    cord not retracting
    Problem Solver:
  • 7 Answers
What you can do is take out the six hex screws on the bottom of the machine while on it's back. When all the screws are out, flip the machine back over, making sure you don't lose any of the screws. From there, open the bag cover and leave it open. Remove the cord release button. (The big rectangular button near the rear of the machine. Usually a firm pull up will get that thing out without incident.) Grasp the handle with one hand and hold the machine steady with the other. With a firm pull, pull upwards. This should seperate the chassis from the main cover.
With the machine guts exposed, place the main cover on the side for now. Now, this next part you can do one of two ways. You can either leave the cordwinder wires attached, (there's only 2 connected wires to the cordwinder, the white and black. Black is on the inside prong while the white is on the outside) or you can take the wires off. I find it easier to disconnect the wires.
Now, remove the cordwinder from it's place, making sure you take note of how the cordwinder rests in the groove from the motor. From there you can rewind your cord fully. Once this is complete, continue winding the cord while holding the cord in place. Take note of the spring. Make sure you are winding in the direction that is TIGHTENING the spring. Make sure you don't overtighten as the center plastic piece will surely snap due to the overtension. This may take a few tries, but be patient. Once you have met your estimated tension needed, replace the cordwinder, put the cover back on WITHOUT SCREWING IT BACK IN PLACE and replace the cord rewind button.
Replace the large cord release button and pull your cord out at least halfway. Hit your Cord rewind button. If your cord rewinds fully, congratulations, you got it in one try. Replace the screws and you are finished. If not, re-open the machine and continue rewinding the cord in the direction that TIGHTENS the spring with emphasis on overtightening. Once you break that center plastic prong, you need to buy a new cordwinder, so emphasize patience. If you're getting frustrated, go take a break and come back. Repeat until the cord winds fully, replace all the screws and you are finished.
Posted on Oct 29, 2008
How do I fix the retractable cord on a Dyson DC19 vaccum cleaner
Great Youtube video
https://www.youtube.com/watch?v=4p0N2XwiKaw
Aug 22, 2014 | Dyson Vacuums
Husky power cord reel won't retract
spring in cordreel is sprung. cord is probably on last leg. Go to vac replacement parts online store and order a new one.
Feb 04, 2013 | Vacuums
How do I take about my Dyson DC11 to replace the retractable power cord assembly
While it doesn't require a collection bag, a Dyson-brand vacuum cleaner can still suffer the problems of wear and tear that are prone to any vacuum cleaner--for example, a frayed power cord. If the power cord of your Dyson vacuum cleaner has become frayed, change it immediately to avoid a dangerous electrical mishap. You will need a replacement cord from an electronics service center, along with a few common household tools. You do not need electrical skills to complete the task.
Follow this steps on how to replaced the power cord assembly:
1 Unplug the Dyson vacuum cleaner's power plug from the wall outlet. Press the button on the top front of the plastic collection cover. Lift the cover off the front of the vacuum cleaner and place it aside.
  • 2 Trace the power cord to where it enters the back bottom of the vacuum cleaner. Remove the screws from the panel surrounding the power cord with a Phillips screwdriver. Remove the panel. Aim the beam of a flashlight inside the compartment so that you can see where the wires at the end of the power cord wrap around two screws on the motor assembly. Loosen these screws with a Phillips jeweler's screwdriver.
  • 3 Pull the power cord out of the compartment and dispose of it properly. Strip a 1/2 inch of insulation from the ends of the two wires of the replacement power cord. Run the wires into the compartment along the path of the original power cord--pushing the wires into the grooves inside the compartment.
  • 4 Tie a knot on the cord on the inside of the compartment to prevent the cord from being pulled out.
  • 5 Wrap the exposed end of each wire of the power cord around the loosened screws. Tighten the screws. Replace the panel and reattach the screws. Stand the vacuum cleaner right side up. Place the bottom of the plastic collection cover into the bottom front slot on the vacuum cleaner. Push the cover back on the front of the vacuum cleaner.
  • Jul 13, 2011 | Vacuums
    I have a Kenmore Vacuum cleaner 116.24212. The retractable electric cord won't retract. How can I fix it?
    The retraction mechanizm is likely jammed. Mostly likely the cord has jumped it's groove in the retraction wheel/hub. If you are good with tools there is a 70% chance you can get it to work again with a basic DCR operation. Most mechanical problems can be solved using this simple rule: Dissassemble Clean and Reassemble.
    CAUTION: The retract mech has a powerful spring inside, avoid exposing. Most retract mech units are rivoted closed so consumers won't poke thier eye out.
    CAUTION: UNPLUG THE UNIT
    Open the unit from the bottom and the top lid of the canister should come off.
    The retract mech should be obvious as it is where the cord comes into the unit.
    Look for the cord being bound by iteslf either on top or underneath (lie two cordes in one groove)
    Remove any binding.
    If you see no debris or obsticals for the cord to retract (where it is getting stuck)
    Your spring could have sprung!
    Do you feel and retract at all?
    Can you locate the releae mechagnism?
    Does the Release button seem to function? When Pressed it should take pressure off of the cord hub.
    The retract mech may need replaced. Overall the cost will be about $60 for parts.
    Feb 12, 2011 | Vacuums
    Cord will not retract
    Tilt the front of the vacuum to a 45-90 degree angle. Gently tug and release cord until it retracts.
    If this doesn't work, repair or replacement of the cordwinder is needed. For this the vacuum needs to be taken to an authorized Aerus Electrolux store.
    http://www.aerushome.com/storelocator/
    Jan 31, 2011 | Electrolux Lux 5500 Canister Vacuum
    Need to open the canister to get to the cord assembly of my Electrolux Lux 5000
    Why do you need to get to the cord assembly?
    If the cord will not retract, tilt the vacuum to about a 45 degree angle and gently tug and release cord. It will usually retract.
    Due to problems ensuing from untrained persons attempting to reassemble the vacuum and having to take it to the shop anyway, I recommend not taking it apart.
    If the above isn't the problem, please take it to the nearest Aerus Electrolux store for repair.
    Jan 22, 2011 | Electrolux Lux 5500 Canister Vacuum
    Dear Technician, I have a problem with my cord to retract back in the canister vac. Would you please help with this problem solution. ...
    Try tilting the vacuum so the front is at about a 75-90 degree angle to the back. Gently tug and release cord. This will usually retract the cord.
    Jan 20, 2011 | Electrolux Lux 5500 Canister Vacuum
    Vacuums Logo
    348 people viewed this question
    Top Electrolux Vacuums Experts
    Chris Nomland
    Chris Nomland
    Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
