Question about Kenmore Washing Machines
Washer won't empty and spin - Kenmore Washing Machines
  • Kenmore Master
  • 2,287 Answers
Check the lid switch,open the lid and close it a few times,if it doesn't click or you don't hear a clicking sound the lid switch is broken,next time send the model number.
Posted on Jul 16, 2010
4 Suggested Answers
  • 2501 Answers
SOURCE: washer washes, spins but won;t empty and drain
Could be a blockage in the outlet pipe.
Remove pipe from outlet and inspect.
Have a bucket ready to catch any water that falls out.
Posted on Dec 21, 2009
danoyachtcap
  • 2899 Answers
SOURCE: We put a heavy blanket in the washer and the load
Usually that means the drive belt is loose and slipping. You should be able to tighten or replace the belt.
To test the belt you have to remove the washer back.
Posted on Jul 29, 2011
aquatom
  • 108 Answers
SOURCE: washer won't empty or spin
More than likely its your lid switch or your pump is clogged.
Posted on Sep 25, 2011
Rinse and spin cycle keeps repeating at 11 minute time to 17 minute time and won't stop
Sounds like your washer does not empty enough water for the spinning to stop. Have you check that the filter(s) are not clogged?
Jan 23, 2013 | Samsung WA5451ANW 4.7 cu. ft. Top-Load...
The machine doesn't spin properly and doesn't drain the water
see this causes and fix it. God bless you
Lid Switch Assembly If the washer won't spin the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Motor Coupling If the washer won't spin the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission. Another common problem is the lid switch.
Drive Belt If the washer won't spin, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin properly.
Door Lock Motor and Switch Assembly If the washer spin the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Drive Block If the washer won't spin the drive block might be worn out or may have come loose. Underneath the agitator the drive block connects the inner tub (the one that spins around) to the transmission. If the drive block wears out the transmission shaft will still spin but the tub may not - or it may spin slowly. This also usually causes a lot of noise. The drive block is relatively easy to replace.
Clutch Assembly If the washer won't spin, the clutch assembly might be worn out. The clutch assembly makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may prevent the tub from spinning. The clutch is not repairable, if it is loud or not working properly it will need to be replaced.
Clutch Band kit If the washer won't spin, the clutch band kit might be worn out. The clutch makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may prevent the tub from spinning. If the washer won't spin, this clutch band kit may need to be replaced.
Drive Motor If the washer won't spin the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged It will have to be replaced.
Tub Bearing If the washer won't spin the tub bearing might have seized. This is a common problem and relatively easy to replace.
Tub Seal and Bearing Kit If the washer won't spin the tub seal and bearing might have seized. This is a common problem and relatively easy to replace.
Bearing If the washer won't spin the bearing might have seized. This is not common. The bearing doesn't require any normal maintenance. They generally go bad when the tub seal fails and allows water to leak past into the bearing.
Basket Drive If the washer won't spin the basket drive clutch might be worn out. The basket drive sits on top of the transmission and engages with the inner tub. If the basket drive wears out the tub won't spin.
Basket Drive Hub Kit If the washer won't spin the basket drive hub might be worn out. The hub is a set of plastic gears underneath the agitator. The basket drive hub kit is easy to replace with standard hand tools.
Transmission If the washer won't spin the transmission might be worn out or defective. There are numerous more likely causes when a washer won't spin, which should be checked first.
Sep 28, 2012 | Hotpoint Washing Machines
Washer Control Locked blinking and won't washer won't work
Water still in the bottom of the drum. Empty, clean filter and check pump is turning. Once pressure switch is satisfied no water is left it'll allow the door to open, assuming the door interlock is still ok.
May 19, 2012 | Washing Machines
Washer won't empty or spin
Sep 25, 2011 | Roper RAX7244KQ Top Load Washer
We just moved and the house came with a Maytag Neptune TL which won't spin if there are clothes in the cylinder. It will spin empty. Please help! Thanks.
Washer bangs around in spin cycle and throws a DC or UC unballance code with cloths in the wash basket is that correct?
If so it's a Clutch issue.
If you want read more about what I feel is your issue read this post Maytag Neptune load unbalance
Sep 08, 2011 | Maytag Neptune FAV6800AW Top Load Washer
We put a heavy blanket in the washer and the load stopped suddenly with a washer full of water. It wouldn't spin or empty and made a weak sound but nothing worked. We had to manually empty the water....
Jul 29, 2011 | Kenmore Washing Machines
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Ariston AML125 won´t spin or empty water.
Dislodge the white covering infront (just located at the bottom). Once opened, unscrew the black button at the right hand side. Once open, check for blockages like coins, loose items, even lint. This worked for me and saved me $$$!!!! Now my Ariston is back to its superb performance. Do read the manula once in a while, it does help!
Dec 02, 2008 | Ariston Technologies AW125NA 13 lbs. Load...
Washing Machines Logo
20 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
