Question about Jensen Overhead Mobile Video System (JN102) Car Video Player
Have Jensen JN102 dvd player for car. Unit works fine, just won't eject discs.
  • 6,826 Answers
OK, I went to Jensen.com and researched your problem to the best of my abilities at my site:
http://voxrightnow.custhelp.com/app/answers/detail/a_id/3848/kw/won%26%23039%3Bt%20eject/p/2/page/3/r_id/103795
Apparently, your JN102 dvd player for the car is not listed and there is no data from other users with problems, so they recommend that you create an incident report which can be escalated to their tech support to solve your problem.
In my experience, if the dvd or cd player cannot eject discs, there is an internal circuit problem or mechanical problem with the gears causing this problem.
The unit should be sent to an authorized service center to rectify the problem.
I would not attempt to take the unit apart, if it is within the warranty period, or if you intend to have it serviced by Jensen.com.
If it is, however, out of warranty and you do not want to have it serviced by Jensen, then I would consider taking the unit out and removing the case, and seeing if you can manually rotate the gears in question to remove the disc.
But, it's likely there is something wrong with the dvd player for the car, that prevents it from functioning correctly.
That is all that I have found on the Internet regarding your unit.
Thanks for submitting your question to Fixya.com.
Posted on Jul 15, 2010
I can't get my DVD disc to eject. It will play but won't eject? Any suggestions
You should try unplugging the DVD player from its power source then plugging it back in. Now try to open it and if that doesn't work than you'll probraly have to take it apart to get the disk out but sometimes the DVD players can get worn out or if you have a cheaper DVD player it might just be freezing up on you. I have had these problems before. I just took the DVD player apart to get my disk and then trashed it.
Jan 23, 2012 | GoVideo DV2150 DVD Player/VCR
My head unit has "ate"
Unfortunately, it's common for this type of slot-loading disc player to "eat" disks. You can take a shot at removing it yourself, but most car audio stores should be able to disassemble it and take the disc out.
Mar 03, 2011 | Jensen Vm8113 Car Video Player
Brake override Jensen vm9212
Are they "burned" DVDs? The brake override will only allow video to come through the screen it won't make the unit not read them.
Mar 01, 2010 | Jensen VM9510 Car DVD Player
Jensen VM9312 not loading DVD.
If it reaeds the cleaner... then try another disc. 20-30 seconds is a long time to looad a disc...
If the new disc does not work either , I would suggest resting the deck .
If reseting does not help , it is still under warrantee. so have it serviced.
Dec 11, 2008 | Jensen VM9020TS Car DVD Player
Region free code for power acoustik ptid-5300
Try the following which i managed to get from POWER ACOUSTIK technical support:
Multi-region for PTID4006T, 406T, 4005, 405, 8006T, 8004, 4003, 5000, 5800, 5300, 530.
1. Turn the unit on and insert a DVD disc. The unit will display LOADING.
2. While the DVD player is LOADING press the following keys:
SET-UP, then press 0, 0, 0, 0 key (0 four times), then ARROW DOWN key (to change the zone to region all 0), then BAND/ENTER key and SET-UP
3. To finish the procedure, push the EJECT key. The disc will eject... Wait and the DVD disc will re-load and play.
Jul 13, 2008 | Jensen VM9510 Car DVD Player
Jensen 9410 will not load or eject
i had my jensen three weeks everything was okay until all of sudden the unit wounld not load or eject CD's or DVD's
Mar 20, 2008 | Jensen VM9410 Car DVD Player
Won't read cd/dvd the unit takes the cd tries to read it and then eject's it.
You either have a bad disc or the lens on the reader assembly is dirty. You can goto Wal-Mart and buy a CD lense cleaner
Dec 13, 2007 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Jensen vm9311ts problem
The player thiinks the CD is still in the player. you have a shorted or open sensor. Usually thee players have 3 phto sensors to tell the controller that a Disc is inserted , or ejected or present. Sometimes a wire or piece of lint covers a sensor and makes the controller think the CD is still there. Get you a can of Air from Radio Shack and blow out the DVD drive You might get lucky and this do the job.
Nov 30, 2007 | Jensen VM9510 Car DVD Player
Wont load or eject
I have the same problem! tuner works just fine. I cant access the dvd mode. i can only access tuner, video input, and rear cam. Ive tried different cds and dvds and it did not help. Also it seems like the ejection mechenism is running continuesly.
Jan 30, 2007 | Jensen VM9410 Car DVD Player
Car Audio & Video Logo
110 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
