I have a ricoh aficio 1220 which is displaying a fault code sc542, how can I reset this?
  • alfie2 Apr 21, 2008
    Hi yes it is a fault sc542 on a 1022 copier, sorry!
We have a Lanier SP C210SF, and put in a new fuser, and the machine still says replace fuser. Please help, busy tax office......and we are dying here.
Posted on Mar 20, 2009
  • 13,433 Answers
One moment.
Posted on Apr 20, 2008
  • 3 more comments
  • Ekse Apr 20, 2008
    I'm haveing hard time finding the details of your printer can you post the exaxt model number and the type of the machine this is. (scanner, printer, multifunction and so on)
    waiting for your reply.
  • Ekse Apr 20, 2008
    is this a Aficio 1022? I cant find 1220
  • Ekse Apr 20, 2008
    Here is a 880 Page manual for your product if it is 1022
    http://www.ricoh-usa.com/downloads/manua...
    check the troubleshooting section very good instructions there.
    As the time here is 0:31 middle of the night. I will return in 8 hours.
  • Ekse Apr 21, 2008
    SC542: Fusing temperature warm-up error
    -Definition- [A]
    The fusing temperature does not reach the fusing standby temperature
    within 50 seconds after the main switch is turned on.
    - Possible causes -
    · Fusing thermistor defective or out of position
    · Fusing lamp open
    · Fusing thermofuse open
    · Power supply board defective
    · Poor connection of the fusing unit
  • Ekse Apr 21, 2008
    As the nature of the error is hardware, possible reasons include power supply defective, I would call in a tech to check this.
    A simple reset wouldnt fix the problem, you can try to power the unit off and on, also removeing the unit from the wall socket.
What is error code SC542 for ricoh aficio 9005?
Ricoh Aficio MP2510, 3010 Error code sc542 on Lanier ...
? 6:08
https://www.youtube.com/watch?v=58MQVyjfDyg
Sep 3, 2013 - Uploaded by Used .Copier
Are you getting Error Code sc542 on your Ricoh, Lanier,Savin or Gestetner copiers? ... Ricoh Aficio 1022 ...
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...
? 2:41
https://www.youtube.com/watch?v=3CnGl1Ytp34
Sep 21, 2015 - Uploaded by Copier Liquidation Center
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...Ricoh Aficio copiers : AFICIO 1013 F
Dec 02, 2015 | Ricoh Aficio Office Equipment & Supplies
How do I clear SC542 error?
That is a fuser fault code will need to repair fuser first. If you buy the fuser might come with instructions to reset code.
Oct 22, 2015 | Ricoh Aficio Sp 3510sf All-In-One Laser...
How do I clear error code sc542 on model 3510sf
go to maintenance mode. press clear/stop press 1 0 7 and start key(hold) until maintenance mode is displayed. look for fuser SC reset.
Sep 18, 2014 | Ricoh Aficio SP 3510SF
Error code sc542 on ricoh spc222sf?????????????????
Press the red CLEAR/STOP key till you hear the little beep. Press 1 0 7 Press the green COLOR START key. The display changes into MAINTENANCE MODE Use arrow keys to go to ENGINE MAINTENANCE and hit Ok Use the arrow keys and select FUSER SC RESET and hit Ok Hit OK again at the Execute prompt.
Once it is done executing the reset, power the unit off and on.
If the error comes back again, it is likely a real hardware problem and you may need to replace some components.
Sep 30, 2010 | Ricoh Aficio SP C222SF All-In-One Laser...
Ricoh aficio cl7300 error sc542 what does it and how do ifx it
This error is power related... their are two possibilities either... your fuser is blown or your machine needs a reset... here is a link to try the reset...
http://www.fortc.com/2007/06/17/ricoh-cl4000dn-error-code-sc542/
the reset should be all you need...
reset link
Feb 08, 2010 | Ricoh Aficio CL7300 DT2 Laser Printer
Ricoh aficio 2232c sc542 error
SC542 means that the thermistor hasn't detected right temperature in given time.
Often you only have to reset service code.
Try this reset:
  • Press and hold online + escape, then power on.
  • Use up and down arrow keys to select SP2
  • Press Enter
  • Use up and down arror to locate SP5
  • Press Enter
  • Use up and down arrow keys to select 810
  • Press Enter
  • Confirm the selection
  • Power off and on.
from http://www.fortc.com/2007/06/17/ricoh-cl4000dn-error-code-sc542/ here is another service procedure:
  • Press Mode(The Yellow Button)
  • Enter 107
  • Press STOP Button for 3 second (RED Button)
  • Copy Sp
  • 5810#
  • Execute
  • Power Off
  • Power On
Nov 19, 2009 | Ricoh Aficio 2015 Copier
Ricoh 3245c code is SC542
A SC542 error is a fuser problem. Did you have a power problem? You can try to reset it by turning the copier "ON" and once you have the code displayed on the screen.... Press the Yellow clear botton once - then the #'s 1 - 0 - 7, one at a time then press the Red Stop botton till the display changes..... Once, it changes turn the Main Power Off, not the one on the control pannel. Then turn it back "ON" and that should take care of it for you.... If it did not, you may have some more problems that can not be reset till they are repaired.. Good Luck
Jan 28, 2009 | Ricoh Aficio 450 Copier
Ricoh aficio 2022 error code sc542
1. Mode(Yellow Button)
2. 107
3. Press STOP Button for 3 second (RED Button)
4. Copy Sp
5. 5810#
6. Excute
7. Power Off
8. Power On
Oct 23, 2007 | Ricoh Aficio 2022 All-In-One Laser Printer
164 people viewed this question
jasbo
jasbo
