Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
How to get access to door interlock mechanism?
When I closed the door to my washer it took a few times before the door lock light would come on and the machine would start, then one day the light wouldn't come on at all. I tried to unscrew the door lock mechanism from the outside but the interlock fell inside the machine. I have managed to get the back panel and the top of the machine off but I still can't get top the interlock, can I get the front of the washer off? ps my machine is a hotpoint aquarius 1100 (WD61P)
thanks for your help.
  • tansal Sep 30, 2008
    Same problem - had to keep slamming door to get it the lock light to come on and the programme to start, now won't come on or start at all. What do I need to replace? Or is this a plumber / electrician job? It is a Hotpoint Aquarius 1100 washer dryer, not sure how old (came with our flat when we bought it three years ago).
  • bradgibb Oct 31, 2008
    i have same problem machine has not been turning on first time, and if you keep opening and closing door will come on.then it stopped all together and seems to have no power,so i changed the door interlock switch and checked wiring to switch.and its still the same !!!! any one got any ideas???
  • 57 Answers
WHAT YOU HAVE TODO TO GET THE FRONT OFF IS TAKE OUT THE SOAP DRAWER COMPLETELY THERE IS FOUR PHILLIPS SCEWS TAKE THEM ALL OUT THAN TAKE THE TWO KNOBS OFF THAN LIFT UP THE PANEL SLOWLY WATCH THE WIRES THAN UNSCREW THE THREE SCREWS ACCROSS THE TOP OF THE FRONT PANEL AND THE THREE ALONG THE BOTTOM YOU SHOULD NOT HAVE TO TAKE OFF THE RUBBER TO GAIN TO THE DOOR SWITCH
Posted on Jul 15, 2008
I get err01 which I think is related to the door interlock ,is this a matter of replacing the door interlock or something else
the code is for a door lock issue,it means the door isn't closing properly,most likely it will be the door switch,unplug the washer,remove the spring from around the outside of rubber boot,pull the boot off just on the side of the door switch enough just to change out the switch,put it back together.next time send the model number,i could have given you the part number,good luck
Dec 15, 2014 | Bosch Washing Machines
There is power going to the washing machine but only sometimes the door lock indicater light turns on when the switch is on and the door is closed. The machine will work when the indicater is on and...
hi Sandra.
Yes it could be the interlock.
power is passed through the interlock on to the rest of the machine. The actual latching shut of the door is a simple spring-loaded mechanism where the latch just slips into the door catch and the door stays closed. Locking the door is a separate process.
go to this link and it should help you find out if it is or not.
How washing machine door interlock work How to test
Dec 14, 2017 | Candy CN136 Front Load Washer
Door won't lock
If the interlock isn't working it may not allow the machine to start. If you can open the door when it should be locked it's probably a faulty interlock.......Nomess
Apr 17, 2010 | Maytag Neptune MAH5500B Front Load Washer
Front Load washer won't start , door lock light on, not locked
needs new door interlock,( sits behind where the door catches on to) easy to fit normally, make sure you un unplug the washer before starting.
Sep 29, 2009 | Washing Machines
Hoover washing machine front loader, has power, have reprogrammed, but still won't start. Door lock light won't come on. For the last few washes before it quit altogether, the time lapse between pressing...
Hi brennanjodi
I think your door interlock needs replacing. Turn off the power undo the front of the door gasket and that will get you to the lock mechanism. They're about £20 to replace.
Adrian
May 14, 2009 | Hoover PE235 Front Load Washer
Bosch WFK 2401 Need to slam door several times to lock door
Sounds like you need the electric "door interlock" replaced. It is a simple matter of seperating the front of the machine enough to unplug the interlock mechanism, remove the two screws holding the mechanism in place and remove it from the back, reverse the procedure to install the new "updated" replacement part (- Bosch #170935 btw. about $37.00 from Sears). - time: approx 1/2 hour if you aren't mechanically inclined.
Jan 24, 2009 | Bosch Classixx WFL 2462 Front Load Washer
Hotpoint Aquarius WF440 Washing m/c - Door Lock light
You have probably knocked of the connector or the catch (and on these it is very fragile as I have changed the catch 3 times on mine) is broken
Jan 22, 2009 | Hotpoint Aquarius WD63 Front Load...
IT MIGHT BE EASY FOR YOU TO GET TO THE DOOR LOCK FROM THE TOP OF THE MACHINE.IF YOU HAVE REMOVED THE 2 SCREWS HOLDING THE LOCK IN PLACE YOU SHOULD BE ABLE TO SEE IT HANGGING FROM THE TOP ITS BEST YOU HAVE A NEW LOCK ON HAND TO REPLACE IT.IF ALL FAILS BEST YOU SEEK THE HELP OF A TECHNICIAN.LET ME NO IF YOU NEED EXTRA ASSISTANCE.GOODLUCK.MOHAMED
May 21, 2008 | Hotpoint BWM12 Front Load Washer
Kenmore Elite Smartwash
Switch the machine off at the wall and leave it off for a few minutes. The door interlock should reset. If it doesn't, then you have a faulty door interlock or by the sound of what you have described, you might even have a board problem!!
Oct 19, 2007 | Kenmore Elite 45986 Front Load Washer
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
178 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
