Question about Whirlpool Freezers
Greetings: I have a 4-5 yr old Whirlpool up-right
Greetings: I have a 4-5 yr old Whirlpool up-right Freezer - Model EVL201NXRQ04. If it matters -From time to time the Door has been left open .... But always recuperate
Of late my problem was noticed/discovered when the warm alarm sounded. When I looked, it was warm and things were beginning to thaw - so it had been this way for some time. I then exposed the coils and found them totally in-cased in ice. I then used a Hair drier on low and thawed out the coil(s).
Being that the kids have a habit of leaving the door open I figure it was them again. About 3 weeks later it happened again where it froze up and continuously running and the kids were not around. This time I checked the Defrost-Heater and found it dead... So I replaced it.
Now the Freezer still continues to run and run and run.... Every thing is frozen and cold.... It will turn off if I manually reach in and turn the Thermostat down - then even at the lower temp it will kick on after a while... It also appears like as I set the therm lower and lower theat becomes the new base ling for the refrigaer ature Running and running.
The next thing that appears to be next to replace is the Thermostat at amount of $106.00. Is there any other areas that I am over looking Or should consider ? Being the compressor is working, the only other parts that I can think of is the Thermostat, Defrost Timer , and Bi-metal Defrost thermostat.
Also, while it is running I noticed both Sides - [ on the outside ] of the Freezer very warm.
Any input would be greatly appreciated
  • 3,828 Answers
Lucky to get five years out of any white good
time to do the math
replacement cost of failed components
verses
benefits of a new up-right Freezer
Posted on Feb 28, 2017
3 Suggested Answers
  • 150 Answers
SOURCE: Kenmore Upright Freezer Model 253.9239780 Temp alarm, Temp rising slowly
you have a refrigeration issue partner let her go 16 yrs. is good service you can replace it for 3 to 5 hundred the repair will be that IF you can find someone with the r-12. don't go for a top it off and go deal the food you lose is to expensive for that to be economical.
Posted on Apr 23, 2008
  • 27 Answers
SOURCE: upright frigidaire freezer not running properly
Sounds like your defrost timer has packed it in you need to fit another timer to it and everything will be as good as new.
by turning the timer you have forced it to run nothing to worry about. It has just stopped in the defrost position. What you have done is the first diagnostic test a tech would have performed. I hope this has helped you out.
Posted on Jun 30, 2009
We have a 3 yr old whirlpool upright 20.0cf freezer and about once a week it makes a terrible noise. what could be the problem?
Here is a tip that I wrote about refrigerators and the fan noisethat they develop sometimes...
RefrigeratorFan Noise
heatman101
Apr 16, 2011 | Whirlpool Freezers
Ice builup on back wall of top mount whirlpool freezer
It sounds like it is not defrosting. Could be the heater, terminator, or the defrost timer. There is still ice built up behind the wall and won't take long for it to stop working again.
Jan 31, 2010 | Whirlpool Freezers
Frigidaire upright freezer is making whining, revving noise, like a model airplane. What is this, and is it worth fixing in a 15-18 yr old freezer? Thanks!
If all is working fine otherwise ,check the fan in front of the condenser.It may just be the wear in the fan bearings.A replacement fan would be all thats needed to fix then.
Oct 14, 2009 | Freezers
Freezer Just Stop Working
You should not run your freezer from a strip plug, only from a wall outlet. It is OK for a small spark to occur since the freezer is trying to start the compressor as you plug it in. If there is a big spark that kicks out the circuit breaker if you plug it into a wall socket, then there is a short in the compressor or light circuit in the freezer. A strip plug in probably will not have the capacity to run the freezer. Plug it into the wall socket and try that. If you have a circuit breaker kick out, then it's your appliance. Hope this helps you, Rick
Apr 25, 2009 | Frigidaire 20.6 cu. ft. / 583 liter...
Whirlpool upright freezer turning itself off
hi,my name is sourine,i have a probrem with my freezer not cool at all,it's about20 year old.
BRAND WHIRLPOOL
model EV150N A O
14.6 c.f
Dec 19, 2008 | Whirlpool 11.8 cu. ft. / 334 liter Upright...
Freezer does not work
almost certainly a problem with the defrost timer - just replace complete. doesn't matter what position you set timer to when replaced
Sep 06, 2008 | Frigidaire 12 cu. ft. / 340 liter Upright...
Freezers Logo
192 people viewed this question
Top Whirlpool Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
AJMAL KHAN
Are you a Whirlpool Freezer Expert? Answer questions, earn points and help others
