Question about Hilti Drills
Hilti te2-a both battery's won't charge i haven't used it for a while but it is under 2 years old
    Scholar:
  • Hilti Expert
  • 123 Answers
IF you live in the US you can send it into Hilti tool repair and let them evaluate your batteries. Or you can take it to any Hilti Center to be checked out. You can call1-800-879-8000 to locate the nearest Hilti Center to you or arrange to send into tool repair.
Posted on Sep 08, 2010
What hilti hammer drills use TE-C bits? I want to buy one
TE2, TE4, TE6, TE7, TE30, TE40. The 30 and 40 are only corded, (not cordless).
TE-C bits come TE-C (standard head) and TE-C3X which is a high performance bit. SDS is the industry term for this connection.
Dec 09, 2012 | Hammer Set Of 6 Hilti Te-c3x Drill Bits...
I haven't turned the camera on for a couple of years. I've tried charging the battery, but I can't get it to power up. Do I need to replace battery or is it something else?
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Nov 06, 2012 | Samsung i85 Digital Camera
ASUS K54C won't power from battery
Take it back to shop if it's only 2 weeks old
May 06, 2017 | ASUS Computers & Internet
A part of my te2s side handle broke where can I find a new one
Try any tool retailer, parts for the TE10 haven't been made for a while. You should find that one of the side handles for current machines will fit.
Jun 22, 2012 | Hilti Drills
My zune 4g red will turn on and work when plugged into the charger, but as soon as I unplug it from the charger it goes off and I cannot do anything with it. I haven't tried to restore it, not sure...
Ifthe rechargeable battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jun 29, 2011 | Audio Players & Recorders
The carbon brush gone i need a replacement
Here is a detail part list from Hilti.
Link HERE to open the drawing and part list.
Please bookmark this page for reference.
The item in question is carbon brush.
This is inter-grade inside item 2 (the electric motor).
Hilti has a life time warranty on labor and two year in parts.
This model was introduced around March 2009.
Check the model plate for production date.
Contact you local Hilti rep to send the unit for free repair.
Act now to avoid the labor charge (2 year FREE labor)
In most case you can use the manufacture t oprove the unit is under 2 years old.
A sales order or receipt of this Hilti SFH 18A will help speed up the repair process.
Additional references
Hilti, Inc.
5400 South 122nd East Avenue
Tulsa, OK 74146 Phone: (800) 879-8000 Fax: (800) 879-7000 Espa?ol: (800) 879-5000
Feb 01, 2011 | Hilti SFH 18A CPC Hammer DrillDriver
Need locations in europe and asia for spares outlet and price for armature assy for hilti TE 2s drill - ( due to short in windings and comutator) purchased on 1981 from saudi arabia -
Go to Hilti's website and choose your country. You can find locations and parts. The TE2s was not introduced until the early 2000's. In 1981 a drill that size would have been a TE12s. If that is your model parts are no longer available through Hilti.
Dec 25, 2010 | Hilti 284228 UH 650 Universal 1/2" Hammer...
How to remove sda cuck from hilti te2 110v drill
Manual for Hilti Te2 is here.
Per Page 11, "Pull the chuck release ring towards the front and remove
the chuck completely. When fitting the chuck, pull the
release ring towards the front and hold it in this position.
Push the chuck onto the guide tube as far as it will
go and release the ring. Rotate the chuck until it engages
and the ring snaps back into its original position |3|. The
TE-C interchangeable chuck or quick-release interchangeable
chuck may be tited to the TE 2-M with chuck
interface |2|."
If this helps, please vote. Thanks!
Jun 14, 2010 | Hilti Cordless Hammer Drill Sfh 151 A...
I have a Hilti TE 905 AVR the service light came on and it stopped working. Is there a troubleshooting guide to fix and reset this. Also, schematics can be found at:...
If you have the old type TE905, which is the one with the square type handle at the back, the service light will come on for 2 reasons. Either there is a tight bearing which will increase the amount of current used to work the machine. Or more common the carbon brushes need replacing. To reset the light, simply cure the problem.
If you have the newer type TE905 with the large “D” Type handle at the back. It gets a bit more complicated. The service light will come on for the same reasons as mentioned above, but it will also come on after 200 hours of use. It will continue to work for another 50 hours with the light on, then it will shut down completely. This is to ensure that it gets regular service. Once serviced or repaired, it will require resetting. To do this you with need a Hilti optical interface, a PC, and Hilti ODA Software. This is not available to the general public. If your Hilti is less Than 2 years old, call Hilti. They will pick it up, repair it, and send it back to you in 3 working days FREE OF CHARGE. If it is older than 2 years there will be a charge for the repairs.
I hope this helped you. Please leave feedback
Jul 08, 2009 | Hilti Hammer Drill Bit, Te Yx 5/8 In. X 13...
Reprogramming 905 hilti hammerdrill
See if your brushes need changing. You can buy them online and do it yourself. Let me know if you need guidance. Please rate me
Jun 09, 2009 | Hilti Drills
Drills Logo
404 people viewed this question
Top Hilti Drills Experts
John Trevino
Marvin
Marvin
woodzowl307
Are you a Hilti Drill Expert? Answer questions, earn points and help others
