Question about LG LRBN20510WW Bottom Freezer Refrigerator
The upper area were is not frezzing is not cooling
The upper area were not to be frezzing is not cooling properly, some times the temperature go down close to 33F, but some times go to 50F. even if we increase the number for keep more cool, the area keep warm
The low area were is frezzing is working OK.
ES
  • LG Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
sgasgaiyl
Posted on Sep 29, 2010
Optimizing performance in taskalfa 820
When you see "optimizing performance", the machine is going through a cool down cycle and will return to ready after the machine's internal temperature reaches an acceptable amount (usually appears after a large amount of copying). Sometimes I have seen it take as long as 5-10 minutes for the message to clear but if you turn it off before it finishes it's cool down cycle, most of the time the machine immediately shows the message again on display. As mentioned, make sure your filters are clean. I'd also check to ensure your exhaust fans are operational (especially those near fuser area), fuser thermistors clean and in proper position, and ensure machine has proper clearance around the cabinet so it can breath properly.
check the place of the machine.there is not enough cooling temperature for the machine.provide the recommenced temperature 16 to 20 degree.your problem will be solved.
Apr 24, 2014 | Kyocera Ecosys FS-820 Laser Printer 14,499...
How to tell if water pump is bad 3800 gm
The 3800's also had other problems. And also Issues for those that are unaware.
Be aware that there are bleeder screws to bleed air out of the system when filling the coolant. With out properly bleeding the system the coolant can Vaporlock in the system causing overheating.
Also if it has been over heated you need to check for a blown head gasket. Smell the antifreeze, if it smells burnt you should be concerned. Next with the engine cold and the system properly bled, leave the radiator cap off and start the engine, if it bubbles constantly or bursts out of the open radiator cap, seek diagnosis at your local repair shop as they have the equipment to do so properly.
I also suggest using an Infrared Thermometer to check temperatures with. if the engine is at 230f and the upper hose is at 200f, and the lower hose is still cool you likely have a clogged radiator. If the upper hose is cool as well then you have a bad water pump or t-stat. if the upper hose slowly warms, and you start to get bubbles then it's likely a water pump with the fins eroded off by electrolysis (gotta change that coolant at regular intervals)
Also make sure the radiator fans turn on.
Mar 20, 2014 | 1999 Pontiac Grand Am GT
Maintenance manual
Jun 17, 2013 | Cars & Trucks
Where is the coolant temperature sensor located on 1990 pontiac transport
The Coolant Temperature Sensor is located: Under hood, driver side, upper engine area, front of distributor, mounted in intake manifold
Sep 09, 2012 | Pontiac Trans Sport Cars & Trucks
Freezer is working fine but the upper area refrigerator is not cooling properly. Temperature is barly cool but not cold.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Jan 26, 2011 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Refrig is frezzing
Your model a WR49X10091 Electric Controled Air Damper between the freezer and the fresh food section. Sometimes they get stuck open and sometimes the electric motor malfunctions. Most times a little frost will hang them up. Until we can see that we can get this part opening and closing properly we will need to unplug your refrigerator and examine the inside of the back of the freezer behind the rear panel to see if there happens to be frost stopping the door from regulating temperatures. I will be here waiting for your comments and results. Let me know what you find, Thanks, Sea Breeze
Sep 12, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Power surges in area now it wont frezze and barely cools down on food side
WELL IT SURE WASNT THRU YOU GUYS AND YOU SO CALLED FREE ADVICE SECTION --- ITS ALWAYS ABOUT THE FUCKIN MONEY ----HAVE A GREAT DAY
May 17, 2009 | Frigidaire FRS26R4A Side by Side...
97 Pontiac Sunfire - where is the temperature sensor located?
the coolant temp sensor is located: Under hood, driver side, upper engine area, below valve cover, mounted in cylinder head
May 05, 2009 | 1997 Pontiac Sunfire
LG LRBN20510WW Bottom Freezer Refrigerator Logo
101 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
