Question about Garden
Have a yardman 139 cc ohv ez start 22' cut it will start and run for about 15 sec and quit do know what more to try new plug air filter
    President:
  • 1,545 Answers
Try removing and cleaning the holes is the brass bolt (main jet) that hold the carburetor bowl on.
Posted on Jul 15, 2010
Why does yardworks 173cc bs engine will start, run, for 2-3 seconds then stop
Bad gas. Drain gas and refill with fresh gas with Stabil. Old oil. Drain oil fill with fresh 30w oil, 16-18oz. Clean air filter and spark plug.. Relpace air filter if dirty. Saving $$$ on this simple tune up is not intelligent.
May 11, 2014 | Yard Man YardMan 11A41K3001 21Inch 173cc...
22 hp ohv misses under load comp.ok valve adj.ok spark,fuel,air,ok w.t.h.
really sounds like a carb problem if it only starts acting up under load
Aug 30, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Yardman seris 155 42 inch cut will only run for 30 sec to 1 min then stops why
try and run it with the fuel cap loose the vent in the cap could be plugged
Jun 04, 2012 | Garden
My 22" MTD Yardman push mower runs too slow to cut much grass. How can I adjust it to run faster? It has no speed selection that I know of, only the handle bar that must be held tight to keep it running....
These inexpensive mowers are not made for large scale mowing. They're set to run as fast as they do and have low compression (read that as low power also) to make them easy to start and operate. About the only thing you can do to make it work better is keep the air cleaner clean, use fresh gas and keep the blade sharp so it cuts the grass easier. Mowing more often also means less cuttings under the deck so it works more efficently.
Aug 31, 2010 | Mtd 22" Yard Machine Push Mower
Oil in air cleaner
Run it minus an air filter until all the oil is off your piston head, you can also try keeping the plug out and ejecting the oil via that access by pulling the cord. It seems like you've already solved the problem, now you're just cleaning up.
Apr 21, 2010 | Briggs & Stratton Briggs Stratton Intek V...
B&S Intek OHV 18hp muffler glows red hot
sounds like its running too rich on fuel. try turning the fuel mixture screw in 1/4 turn at a time til it starts to stall then turn out 1/4 turn or 2 and see if that helps.Maybe when you used the air it turned this screw???
Nov 10, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Motor runs erratically
Try cleaning the air filter and the fuel filter. Sawmills are dusty places and timber dust can clog-up air filters. Air filters in chainsaws are cleaned hourly for max efficiency.
Oct 09, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Won;t start
I got a new air filter for mine today, plus cleaned out the metal fuel canister under the carburator and the little brass bolt and my mower started right up. I was having hte same problems getting my mower to run and stay running. Glad I checked this site!
Sep 09, 2009 | Mtd 22" Yard Machine Push Mower
MTD Yardman push mower runs fine for awhile then cuts off.
Try buying a new plug first but if it continues then I would say that there is debris in the carb.
Apr 04, 2009 | Mtd 22" Yard Machine Push Mower
Garden Logo
237 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
