Question about Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1
My Hayward H400IDL heater will not stay lit. When I try to start the heater runs and ignites for a few seconds but when the blower tries to kick in it flames out. The manual says the heater should try 3 times to ignite which it does most times and then throws an if code ( Ignition Failure ). Other times it just continues to cycle without throwing a code but still does not light. I have checked all electricl connections and made sure gas is on. Any suggestions as I know it has to be something simple. Ran great last 2 years although I did have to replace ignitor this year as it was cracked.
  • 61 Answers
SOURCE: Hayward Spa Heater ignites for 2 seconds and shuts off.
Sounds like this is a flame sensor issue. It is not detecting the flame.
Posted on Apr 04, 2009
  • 61 Answers
SOURCE: My Hayward electric spa heater 11KW is coming on
Chances are that your element is drawing too much current. Check the manufacturer's website to make sure that you have the correct size breaker installed. Low water flow could also affect this, so make sure all of your baskets and filters are clean and clear.
Posted on Apr 05, 2009
  • 8 Answers
SOURCE: I just installed a new Hayward H400FDN and it will not stay lit.
I had the same issue...you don't have enough gas pressure.
Posted on May 12, 2009
john224
  • 1378 Answers
SOURCE: hayward h100id1 above ground pool heater has
Contact Hayward for a local warranty repair center since it is still under manufacturers warranty. http://www.haywardnet.com/locator/ Be sure to change the reason for search to repair/service.
Posted on Jun 12, 2009
thepool
  • 78 Answers
SOURCE: Hayward H400 Pool heater will not stay lit
"IF" - Hayward Pool Heater Fails to Ignite: the most common reason for this problem is insufficient gas supply. The Hayward heater LED display will show a diagnostic fault code of "IF" which stands for Ignition Failure. Undetected gas pressure problems if not investigated properly may result in unnecessary replacement and servicing of your Hayward Pool Heater.
Posted on Apr 23, 2010
Boiler ignition is loud, boiler runs for a few seconds then goes out
flame sensor, air flow restriction or blower not producing enough pressure. clean the flame sensor to start. inspect venting, etc
May 13, 2013 | Jandy Lx Pool & Spa Heater - Electronic...
I had code AO displayed on my hayward H250IDE. I
Check your wiring again on all the safety devices - Water pressure switch and both Hi- limits in the header.
Feb 19, 2010 | Hayward H Series Pool & Spa Heater 400k...
Hayward h250ed1 heater wont stay lit
Try cleaning your filter if dirty there will not be enough flow to llet heater fire. If filters clean you can try jumping the pressure switch.
Jun 24, 2009 | Hayward 250kbtu Ng Pool Heater - Inground
Hayward heater not staying lit
possibly poor pilot adjustment or insuficient mv output from thermopile
Jun 19, 2009 | Hayward H Series Millivolt 250,000 Btu...
Jun 06, 2009 | Hayward H-series Electronic Gas Pool...
Hayward Spa Heater H100ID blower will not stay on.
I had a similar problem and it turned out to be the solder connections on the control module. The connector that is soldered to this board (comes from the gas valve) needed to be re-soldered.
May 30, 2009 | Hayward H Series Induced Draft Abg 100,000...
Pool Heater will not light. (Flashes AO)
If you hear the blower come on, then you have an air sensor problem. Hopefully the air hose popped off, or has cracked...If not then you will probably neet to replace the air pressure switch.
Mar 15, 2009 | Hayward 250kbtu Ng Pool Heater - Inground
Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1 Logo
210 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
