Question about ASUS R1E-B1 Tablet PC
I need to put the laptop on a monitor but screen
I need to put the laptop on a monitor to transfer hard drive but screen is broken which buttons to press???
    Champion:
  • 200 Answers
Usually FN and F5..............Try FN with other F? keys if it doesn't work with F5
Posted on Jul 15, 2010
How to get my pictures and videos off my Android phones SD CARD to my nextbook flexx10 by putting the SD card into the laptop
The Flexx10 has a micro SD slot, the SD card is about the size of your finger nail. If your Android phone also has a micro SD card you just remove it from the phone and plug it into the Flexx10. Then just transfer the pictures from the SD card to the tablets internal hard drive. When complete put the SD card back in the phone. If the SD card in your phone is the standard size it obviously won't fit the Flexx10. You then have the choice of either using Bluetooth to transfer the pictures between devices or buying a USB SD Card converter and plugging that in your FLexx10 with the Android SD card mounted in the converter.
Feb 06, 2016 | Nextbook Tablets & eReaders
How to put photos on my sd card
This more than likely means your internal storage is low and not the SD card and may not have anything to do with your pictures but more so with your apps. Go into settings and see if your tablet has the feature to set where your downloads and other media is stored, by default that will be your internal memory. change it to SD card or USB storage. In Settings you can also click on your apps individually and transfer them manually one by one to the SD card or USB storage or download a file manager and do so all at once. Some apps and files may not have the feature to transfer these apps the tablet came with or apps you downloaded that uses the internal memory. By default if a memory card is in you tablet pictures are automatically store there, if this is not the case the easiest way to transfer is connecting the tablet to a computer/laptop and transfer to the card or again use a file manager.
Aug 15, 2014 | Acer Iconia Tablet with 8GB Memory - Steel...
How to fix Nobis 9" tablet, stays on go screen.
After you have tried a reset (hard & soft) you"ll need to take the back off. once you remove the two screws you can pop off the colored backing. Remove the black tape (don't worry if you put the webcam out)Unplug everything, start at the bottom with the hard drive. Just lift the little black tab & it will come right out. Then then unplug the monitor in the upper right side. now press the reset button hold & press the power button hold 20 seconds. now plug everything back in just side the ribbons back in place & close the black tab. Now close the backing & turn the tablet on it will load to the welcome screen.
Jun 01, 2014 | Tablets & eReaders
I have a tx1410 touchscreen hp laptop I have a black screen when i turn on my computer and all the buttons are lighting up. Everything works but the black screen. I put a dvd disk to boot it up and then...
First you need to check if you did not have any flash drive or device attached to your laptop when you turned it off. Because if you do, your system will not booth completely, you will only be having a black screen, and to solve that, you just remove your battery and insert in back then try to turn it on.
Ensure you have the battery fully charged. Then turn it on. If that does not help, then the problem could be a hardware problem, which could be that the module is faulty and the screen is not lighting up or the hard disk is disconnected or the RAM is not connected properly.
The module is like the flex on the laptop that assists the information from the motherboard be read on the screen. So if it is faulty then you will not be able to see anything.
For that, you need to open it up and replace the module. If it is the hard disk, just tighten the connection and the RAM too, then try to couple it back together and turn it on.
Try to hold down control+alt+delete to see if the task manager comes up, if it does, then you know it is not the module, then you select task manager and run an operating system disk, to format your hard drive and run a new operating system.
These are a list of most likely problems that can affect the screen of your laptop.
If you are not familiar with such technical activity (loosening the laptop), i will strongly advice you seek technical assistance from a professional, to avoid shock or further damage in the unit.
Take care and good luck
Oct 18, 2010 | HP Pavilion tx1410us Tablet PC
Levono X41 tablet screen stopped working - OK with ext. monitor
Then the screen has failed, though that would be obvious.
Aug 24, 2017 | Lenovo ThinkPad X41 Tablet PC
Need to replace lcd screen on a Fujitsu lt c500
Below is a link to tech support chat page for Fujitsu products. The Fujitsu site does offer a user manual, however, you need a service manual. Being a customer, you should be able to order a service manual for your notebook thru fujitsu. Here is the link for the chat page:
http://solutions.us.fujitsu.com/www/support.shtml?support/support_chat
Here is the link for the user manual:
http://support.fujitsupc.com/CS/Portal/supportsearch.do
This is a good place to start. I hope that you find this information helpful and will leave feedback to that effect if you do.
Thank You,
Brian
Jan 25, 2010 | Fujitsu Stylistic LT C-500 Tablet PC
My hard drive also failed. i cant install or repair the os on it.
the best way you'll need a USB CD ROM Drive so you can boot from USB with the windows CD in the drive and install from there.
Aug 10, 2009 | Compaq tc4200 Tablet PC
About a month ago my screen on my laptop would
Sounds like one of two things. Either your connection wire from the screen to the hard drive is lose most of the time you can go on the product sites enter the info on the underside of the computer enter that info on the products site and get your info from the help self section or the repair diagram. Number 2 is your screen has a bad wire and it needs to be replace you can find them new on ebay and most of the time it is easy to fix yourself. I hope some of this info helps you.
Jul 14, 2009 | Gateway C-141x Tablet PC
Boot up problem
NOTE: Ususally when computers DO NOT find any startup information on the SELECTED DRIVE (like when you click a key) it goes to the default drive.
WHICH IS YOUR HARD DRIVE.
Meaning it is probably your Harddrive is broken, or your connection from hard drive to motherboard is broken
Burn a Live CD bootdisk of some linux distribution
liek Slax, google it.
Burn it to a bootable CD and put it into your drive, then select to boot from it.
If it boots only using your CD ROM drive, if that works then its probably not your BIOS/rest of computer, which is good.
And while in the live cd, you can see your harddrive and see files, that means its not broken its just your connection to it....either way im guessing youll have to send it in.
Jan 10, 2009 | Toshiba Portege R100 Tablet PC
Display crack
Honestly it may cost less just buying a new laptop. Screens can cost more than a new laptop =[
You can use an external monitor if you do not plan on moving the laptop around too much.
G'luck
Jun 05, 2008 | HP Pavilion TX1320US Tablet PC
ASUS R1E-B1 Tablet PC Logo
125 people viewed this question
Top ASUS Tablets & eReaders Experts
k24674
Are you an ASUS Tablet and eReader Expert? Answer questions, earn points and help others
