Question about Brother EM-530 Typewriter
The carraige return is stuck on the left, makes beeping sound
When I unplugged it from the wall, then plugged it back in, the carraige never returned to the center, makes a high pitched beeping sound,Pitch lights 10 & 12 blinking fast. Tried turning off and on to reset,did not work. When it first turned on, the carraige bounced against left margin several times, scraping noise. Then the beeping and flashing lights. HELP
  • jgrondin123 Jul 15, 2010
    It worked fine until I unplugged it and plugged it in again, can't something else be tried? It's a 1 year old typewriter.
    I will take it to a repair shop
    President:
  • 1,561 Answers
You will need to disassemble the unit to take a look at the printer belt, most likely the printer belt is stuck or worn out, check the printer belt to see if it is worn out, if it is , replace it but if not, try to free the cartridge by gently pushing gradually to free it from where it is stuck, with this, you can carry on.
Take care.
Posted on Jul 15, 2010
  • 532 Answers
There is a problem with the carriage return clutch.
Sometimes it is necessary that this problem should be handled by a Professional because it is not a work a lay man can do even given the instruction he needed to do it.
Thanks for contacting Fixya.
Dpxu5120 stuck in standby mode
Unplug it from the wall, ext. cord or whatever power source, wait for 20 minutes, plug back in and see what happens. Hopefully it will recycle and return to the proper screen. If that doesn't work, check out your remote - make sure batteries are in properly and fresh and that some physical object or electromagnetic field isn't interfering with the remote's ability to change modes, inputs, go into the menu, etc.
Sep 19, 2017 | Televison & Video
IBM Selectric III carraige travels all way to the right. Fix?
most often caused by a week or broken spring on the return operational shaft
Mar 23, 2017 | IBM Office Equipment & Supplies
Beeping noise in 1995 Chrysler LeBaron 3.0 turbo
PUT IN A NEW IGNITION SWITCH. THE KEY BUZZER IS INTERGRAL TO THE IGNITION SWITCH. IT ALARMS WHEN KEY IS LEFT IN THE CAR OR IF IT IS BROKEN IT ALARMS FOR ALL YOUR REASONS.
Oct 11, 2012 | Chrysler LeBaron Cars & Trucks
I have a brand new APC 1000xl I just plugged into the wall and it beeps every second with all the lights changing with each beep.
You can push and hold the on button to start a self test. Or you can turn off the UPS. Unplug it from the wall. disconnect the batteries and push the on button to reset the logic. if that wont work return it.
Oct 18, 2011 | APC Smart-UPS 1000XLI (SUA1000XLI) UPS...
Frigidaire stove(smooth top -electric) all of sudden started to beep' constantly w/F1 flashing.Tried to reset - unsuccessful. Unplugged & waited an hour to plug back in & still beeping...
The F1 error code means a button on the touchpad is stuck,usually pushing clear/off will clear it. Since you have done that and it returns the touchpad needs to be replaced
Gene
Aug 11, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
Whenever i try to print it does 1/2 page then the cartridge keeps getting stalled on one side. Error message on screen says print cartridge stalled, error message on printer says clear carraige jam. Cannot...
If there's a carriage jam. While the printer is turned on, Open the access door of you printer.
If the carriage is stuck at the left side, try moving it manually by hand to the right most part of the window. If it's stuck on the right, try moving it by hand to the left.
If you've already done that. While the printer is turned on, unplug the power cord from the back. Close the access door. And then plug it back in.
Make sure you restart the computer first just to avoid documents getting stuck in the print queue. Try printing again. Usually it does the trick.
Feb 03, 2011 | Office Equipment & Supplies
My Sears electric typewriter "scholar w/
could be the carraige release button on the carraige is stuck down (pull it back up). Otherwise the mach. is stuck in "tab" mode or the escapement (the mechanism that hold the carraige in place and lets it advance 1 space at a time) is FUBAR'ed, in eithor case it would need professional help.
Dec 28, 2010 | Smith Corona Office Equipment & Supplies
My royal typewriter i just purchased on line its from the 50s and is blue has a carraige return problem. the carraige always stays to the left so you can not type you push it back and it just flys right...
The starwheel/escapement is probably gummed up. If you look from the bottom, you should see a "star" shaped part. Carefully spray a light lub around the area and move the carriage back and forth to free it. It may take several attempts.
Dec 20, 2010 | Royal Office Equipment & Supplies
IBM Selectric II. Hit return with cover open, and carraige is stuck at the left end. There is no response from any key.
If you can hear the motor running but nothing at all works the motor belt is probably broken. Not a job for the untrained.
DickyO
Sep 28, 2010 | IBM Office Equipment & Supplies
Maytag gemini f1-9 error
plug it back in and press the cancel button
Mar 31, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Brother EM-530 Typewriter Logo
65 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
