Question about Cameras
Just bought a VistaQuest DV500 camcorder.display is very dark unless used in natural sunlight.normal room lighting is too dark
  • 10,594 Answers
It seems aperture mechanism in lens assembly got stuck and causing darker image in low light, aperture is device that controls light amount in lens mechanism for good picture result, it opens wide in low light and gets close to reduce light amount in high bright/ sunlight.
Lens assembly needs to be take apart to fix aperture problem and it is job of experienced camera technician, so take camera to local camera repair shop for fix.
Hope these info will help you.
Thanks.
Posted on Jul 15, 2010
I usedcolor smart for men medium brown and left it on for 20 minutes itt came out too dark and i want to use the light brown what should i do
You may want to use the lighter shade and re-dye it, or simply show it more sunlight. The light from the sun will naturally brighten your hair.
Apr 16, 2014 | Loreal Color Smart Mens Hair Dye Kit
Put new batteries in. Power light comes on.
Had the same problem. It's ainternal flex wire connecting LCD with camcorder. Got from the repair shop did it by miself and it's like knew. It's very common for LCD.
Good luck
Sep 30, 2009 | VistaQuest DV-7 DV Camcorder
My VistaQuest VQ DV800HD camcorder's close up pictures are blury.
What's your definition of "close up"?
Sorry to say its a very cheap camera. It will not focus on anything under 3 feet. It's called a fixed focal camera. Anything beyond 3 feet should be fine.
Sep 06, 2009 | VistaQuest Video Cameras
Pink and Black in natural light
It sounds like the light sensor on the camera is malfunctioning. Try cleaning the sensor. If the senor doesn't work at all it will not be able to tell when the camera is operationg in bright light. Kind of like having your eyes dialated and walking outside on a sunny day.
Jun 15, 2009 | Sony Cyber-shot DSC-W30 Digital Camera
MITSUBA DV500 SOFTWARE
http://www.mitsubausa.com/products/dv500.htm
Sep 29, 2008 | Mitsuba DV500 Camcorder
Projection TV when turned on picture is dark can view slight images until dinning room light is turned on
Try hooking the TV to a different outlet fed by a different breaker. Does the problem go away? If so, the culprit may be a wiring problem in your house that is causing the TV not to get enough power unless the dining room light is on.If in doubt, consult an electrician to make sure both the dining room light and TV outlet circuits are working properly.
Mar 06, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Cant figure out this camera
The Bottom of the camera, right above MODE, (the joy stick thing that you us to select in Menu) when it is in camera mode and you are ready to take a picture using the flash, move the joystick to the left until you see a lighting bolt in the bottom left on the view screen.
Feb 24, 2008 | Mitsuba DV500 Camcorder
Replacement battery for DV500
I think this is the battery.  I have also been searching for this battery.  If you will let me know what you think.
T.R.
http://www.amazon.com/Aiptek-Lithium-Rechargeable-Recorder-Camcorder/dp/B000ES843I/ref=pd_bxgy_p_img_a/104-6567272-5427102
Oct 23, 2007 | Mitsuba DV500 Camcorder
Pictures reddish or orange
Although normal room lights (tungsten lights) appear white to our eyes, their light is actually much "warmer" than daylight, giving a reddish or orange color to pictures. This happens with digital and film cameras. To prevent or lessen this reddish or orange color: If your digital camera has a selectable White Balance mode (check your camera's User's Guide) and you are not using the camera or external flash, set the White Balance mode for "Tungsten" light. If your pictures are reddish even when you use the camera flash or external flash, the room lighting is overpowering the flash. Try setting the White Balance mode for "Tungsten" and continue to use the flash. If your camera does not have a selectable White Balance mode, use the camera flash or external flash when taking pictures in lighting that makes your pictures turn out reddish or orange. If you can, turn down or turn off one of the room lights (without making the room too dark), or move your subject so that it is not being hit directly by the room lights. If you can, when taking pictures in the daytime, try opening any drapes that might be covering windows. Letting in natural daylight improves the color quality of the lighting.
Aug 29, 2005 | Kodak EasyShare One Digital Camera
Cameras Logo
24 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
